use freecad python module of Windows dev version
bernd
Postby bernd » Fri Aug 17, 2018 12:36 pm
At work I have a CAD software which has a Pythoninterpreter (Nemetschek Allplan). I would like to import freecad moules in this Python environment. But I use the FreeCAD windwos dev version which is just an extracted 7zip archive. How can I use all the Pythonmodules from this FreeCAD?
bernd
sgrogan
Re: use freecad python module of Windows dev version
Postby sgrogan » Fri Aug 17, 2018 9:29 pm
Hey bernd.
I think making sure the path to the modules are in your interpreters sys.path should work for .py files.
For the compiled extensions .pyd we need to determine what python version your interpreter is using.
bernd
Postby bernd » Sat Aug 18, 2018 8:40 am
which one do I need to import Part?
Site Admin
Postby wmayer » Sat Aug 18, 2018 12:41 pm
You only have to make sure that Nemetschek Allplan finds the FreeCAD.pyd file. Then you must first import FreeCAD in order to initialize the internals of FreeCAD. If your directory structure is OK FreeCAD sets up everything so that it finds its extension modules later. Afterwards you can import Part.
Trying to import Part without loading FreeCAD first is not supposed to work and leads to a crash.
bernd
Postby bernd » Sun Aug 19, 2018 7:51 pm
Thanks guys for the informations. Werner this is what I need. I will gibe it a try but it may take some time.
Since Allplan uses Python 3.x I'm lucky we gone provide Pyton 3 builds for windows. Sgrogan great :D
bernd
bernd
Postby bernd » Tue Aug 21, 2018 8:50 am
pathToFreeCAD = "C:\\0_BHA_privat\\progr\\FreeCAD_0.18.xxxxx_x64_dev_Py3_Qt5_win\\bin"
import sys
sys.path.append(pathToFreeCAD)
for p in sys.path:
    print(p)
works great but if I add an
import FreeCAD
Allplan crashes ... :shock:
Mhh since it crashes it does recognize something, means I seam on the right track ... :)
something to test the import if it works ...
ver = FreeCAD.Version()
print("FreeCAD {0}.{1}.{2}".format(ver[0],ver[1],ver[2]))
Site Admin
Postby wmayer » Tue Aug 21, 2018 9:02 am
Next step is to compare the 3rd party libraries used by both applications. It might be possible that two different versions of a library is used by the applications which in most cases won't work.
An alternative is to not import FreeCAD directly but spawn a Python process and load the FreeCAD module this way (you can also spawn FreeCADCmd.exe). In this case it doesn't matter which 3rd party libraries both applications use, especially Python2 vs. Python3.
The problem then will be how to interchange data between the processes: https://stackoverflow.com/questions/392 ... plications
bernd
Postby bernd » Tue Aug 21, 2018 9:38 am
I would like to try tackling this down. Werner do you have an idea how to get more errormessages from what is happening after import FreeCAD in Allplan, by the use of Python. Or how would you processeed ?
bernd
Site Admin
Postby wmayer » Tue Aug 21, 2018 10:14 am
When exactly does it crash? Does the terminal window return when entering "import FreeCAD"?
If you have installed Visual Studio on this computer (it doesn't matter which version) you can attach the debugger to the Allplan executable after it has crashed (don't click on "Programm schließen"). The debugger may give some further information about where the crash happens.
If you don't have VS here you can also use WinDbg which is part of the Debugging Tools for Windows. If none of them is available you can use the tool ProcessExplorer (www.sysinternals.com), select the crashing executable and create a dump file. You can choose between mini dump (small file size) and full dump (can become huge). Then you can analyse the dump file on another computer where a debugger is available.
Btw, with ProcessExplorer you see all dlls an executable has loaded and you may find conflicting versions used by Allplan and FreeCAD.
bernd
Postby bernd » Tue Aug 21, 2018 10:40 am
Wow cool a lot of informations. I will go and give them a try.
The problem with Allplan Python is, you do not have your own terminal to interact with the Python interpreter like in FreeCAD. One creates a Python file with all the code inside. In Allplan GUI you can drop your PythonPart in the Allplan drawing window. You can not interact. The only thing which is available is the Allplan trace window which prints all kind of informations including Python outputs. See earlier post wha is printed ... nothing. If import FreeCAD is omited everything runs smooth.
bernd
