use freecad python module of Windows dev version
sgrogan
Re: use freecad python module of Windows dev version
Post by sgrogan »
Maybe try this?
>>> import platform
>>> print(platform.sys.version)
3.6.6 | packaged by conda-forge | (default, Jul 26 2018, 11:48:23) [MSC v.1900 64 bit (AMD64)]
The output here is for your version of FreeCAD's python.
"fight the good fight"
bernd
Post by bernd »
sgrogan wrote: Tue Aug 21, 2018 11:07 am Maybe try this?
>>> import platform
Allplan
3.6.1 (v3.6.1:69c0db5, Mar 21 2017, 18:41:36) [MSC v.1900 64 bit (AMD64)]
The FreeCAD I try to import
so this should be fine IMHO
I'd be courious what Werners tools will find, but this will take some time.
Founder
Post by wmayer »
Python 3.6.1 and 3.6.6 are binary compatible and built with the same compiler for the same platform.
But when loading the FreeCAD module it's important that FreeCAD uses the Python dll of Allplan and that it doesn't load its own one (not sure if the OS does this anyway).
bernd
Post by bernd »
gave it another try with FreeCAD 0.19 and Allplan 2018, same crash of Allplan. Further investigation is needed ...
Founder
Post by wmayer »
What happens when you copy the Python dll of FreeCAD and replace (save the original dll to restore it afterwards) that of Allplan? Does it start or does it crash immediately?
bernd
Post by bernd »
wmayer wrote: Tue Jun 04, 2019 7:47 pm What happens when you copy the Python dll of FreeCAD and replace (save the original dll to restore it afterwards) that of Allplan? Does it start or does it crash immediately?
- renamed python36.dll from FreeCAD bin dirctory
- copied python36.dll from Allplan pgr directroy into FreeCAD bin directory
- start Allplan try to import FreeCAD
- same problem, Allplan crashes at the same point
