Importing FreeCAD in Dynamo Python
cnirbhay
Postby cnirbhay » Wed Sep 05, 2018 6:14 pm
Hi all.
Please guide me in the following issue where I'm unable to import FreeCAD in the Python console of Dynamo, whereas I was able to import any other module from the same path. Please see the code and screenshot below:
import clr
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
import sys
sys.path.insert(0,r"E:\Softwares\FreeCAD_0.18.14014_x64_dev_win\FreeCAD_0.18.14014_x64_dev_win\bin")
import FreeCAD
Screenshot (372).png (112.64 KiB) Viewed 784 times
Thank you.
Regards,
Re: Importing FreeCAD in Dynamo Python
Postby wmayer » Wed Sep 05, 2018 8:50 pm
Either double the backslashes or replace them with slashes. Then try again.
DeepSOIC
Postby DeepSOIC » Wed Sep 05, 2018 9:55 pm
r in front of the string literal should be sufficient...
Postby wmayer » Thu Sep 06, 2018 6:09 am
Thanks for the hint. Didn't know the "r" thing.
Then cnirbhay check the Python version used by Dynamo and that of your FreeCAD version. They must match with their major and minor version number as otherwise they are not binary compatible and thus cannot be mixed in one process.
cnirbhay
Postby cnirbhay » Thu Sep 06, 2018 4:48 pm
I checked their respective Python versions also and they matched too. Please see the screenshot below:
Postby wmayer » Thu Sep 06, 2018 5:09 pm
And the architecture? Are both either 32-bit or 64-bit applications?
sgrogan
Postby sgrogan » Thu Sep 06, 2018 5:15 pm
What is the result of
import platform
print(platform.sys.version)
I suspect the compilers are different.
cnirbhay
Postby cnirbhay » Thu Sep 06, 2018 5:23 pm
Well, in that case, I got a warning in Dynamo that no module named platform found. Both the applications are 64-bit.
Screenshot (373).png (151.15 KiB) Viewed 707 times
cnirbhay
Postby cnirbhay » Fri Sep 07, 2018 4:25 pm
import platform
So, now what is the solution to it? Any hints or pointers would be great. :-)
sgrogan
Postby sgrogan » Fri Sep 07, 2018 4:58 pm
I don't know another way to get the compiler used to build python.
I suspect Dynamo's Python 2.7 is built with VC9, this is what standard Python is built with.
FreeCAD's python is built with VC12, so the 2 python's would be incompatible as they would try load different CRT's.
Maybe you can get some info from Dynamo's Help About or the like?
EDIT: I just discovered that Dynamo uses Iron Python and doesn't work with CPython compiled extensions (like FreeCAD.pyd)
see here for ex. https://forum.dynamobim.com/t/numpy-for ... cript/5394 (i.e. numpy.pyd)
So you will only be able to use pure python modules (.py files) with Dynamo apparently.
