who can help with a script or a existing tool to create a number of points around a sphere?
Important is, that all points should have the same distance to each other.
Type in the sphere diameter and the number of points, and the script should do the job.
https://forum.freecadweb.org/viewtopic. ... 08#p269208
Thank you so much and best regards
Wilfried
Who can help with a script to create a number of points around a sphere?
Re: Who can help with a script to create a number of points around a sphere?
Hi. I'm not sure that it's possible what you are asking.
If I remember well there are just 5 regular solids possible in 3d.
Try "tesselation of sphere" in your favorite search engine.
Why dont you use the Geodesic macro. It is also available via the Add-On Tool. You can Input the Diameter and get a dome with a number of vertexes. Its structure is very regular. The vertexes are lying on a sphere with the given Diameter.
There is the frequency parameter. Here is a table with the frequency Parameter and the resulting vertexes:
Frequency Vertexes
4 162
5 252
6 362
Ulrich
Frequency Vertexes
4 162
5 252
6 362
Ulrich
Some food for thoughts [1][2]. In [1] there are a few pieces of code that can be easily converted with "bolting-on" FreeCAD code to create spheres.
The result attached.
[2] could be easily implemented by simple 'physics' engine:
- throw points in random locations
- calculate forces (Coulomb's law)
- move the point in force direction by a (small) distance depending on the value of force
- recalculate and check is locations are "stable"
[1] https://stackoverflow.com/questions/960 ... 68#9606368
[2] https://www.mathpages.com/home/kmath005/kmath005.htm
# -*- coding: utf-8 -*-
# Macro Begin: /home/przemo/.FreeCAD/sp1.FCMacro +++++++++++++++++++++++++++++++++++++++++++++++++
import FreeCAD
import Part
import math
import random
def fibonacci_sphere(samples=1,randomize=True):
rnd = 1.
if randomize:
rnd = random.random() * samples
points = []
offset = 2./samples
increment = math.pi * (3. - math.sqrt(5.));
for i in range(samples):
y = ((i * offset) - 1) + (offset / 2);
r = math.sqrt(1 - pow(y,2))
phi = (i % samples) * increment
x = math.cos(phi) * r
z = math.sin(phi) * r
points.append([x,y,z])
return points
App.ActiveDocument.addObject("Part::Sphere",'base')
App.ActiveDocument.ActiveObject.Label = 'base'
FreeCAD.getDocument("Unnamed").getObject('base').Radius = '1 mm'
p = fibonacci_sphere(samples=120, randomize=False)
i =0
for s in p:
name = 'sp_{}'.format(i)
App.ActiveDocument.addObject("Part::Sphere",name)
App.ActiveDocument.ActiveObject.Label = name
FreeCAD.getDocument("Unnamed").getObject(name).Placement = App.Placement(App.Vector(s[0],s[1],s[2]),App.Rotation(App.Vector(0,0,1),0))
FreeCAD.getDocument("Unnamed").getObject(name).Radius = '0.2 mm'
i += 1
Gui.SendMsgToActiveView("ViewFit")
- Zrzut ekranu z 2018-11-19 22-06-25.png (342.78 KiB) Viewed 1055 times
Hi Ulrich,ulrich1a wrote: ↑Mon Nov 19, 2018 8:39 pm Why dont you use the Geodesic macro. It is also available via the Add-On Tool. You can Input the Diameter and get a dome with a number of vertexes. Its structure is very regular. The vertexes are lying on a sphere with the given Diameter.
Frequency Vertexes
4 162
5 252
6 362
Ulrich
thank you so much. I didn't know there was such a macro. It's great and very helpful.
Best regards
Wilfried
