reset (isolate) Python environment
ypsilon
Postby ypsilon » Sun Nov 25, 2018 11:45 am
The Problem I have is simple. If I run a python macro all definitions persist even after the macro has finished. This means, that if I want to change something and re-run it I have to restart FreeCad alltogether. Also if I change something in a file imported from the main macro file I have to restart, so the changes are taken into account. Is there a better way to do it? I've found the following on the bug tracker (already 7 years old), but I really don't know what to do with it.
https://www.freecadweb.org/tracker/view.php?id=528
Thanks for your help in advance
triplus
Re: reset (isolate) Python environment
Postby triplus » Mon Nov 26, 2018 12:16 pm
If you run some code in Python console. Then i guess this is the expected behavior? If you run some code as a Macro (from the Macro dialog). What exact problems do you experience after?
reload()
Site Admin
Postby wmayer » Mon Nov 26, 2018 12:31 pm
Go to the preferences under General > Macro. There is an option "Run macros in local environment".
After activating it running a macro should no longer have an impact on the global environment of the interpreter.
Jee-Bee
Postby Jee-Bee » Mon Nov 26, 2018 1:46 pm
thanks i didn't know this too... Very handy!
ypsilon
Postby ypsilon » Mon Nov 26, 2018 2:48 pm
thanks again!
HarryvL
Postby HarryvL » Sun Jan 27, 2019 5:47 pm
Werner, I have a similar issue: https://forum.freecadweb.org/viewtopic. ... 41#p282719. I looked at macro preferences and find that I had that option already checked. Is there a way to reset the interpreter and force it to reload modules imported by a macro?
Site Admin
Postby wmayer » Sun Jan 27, 2019 6:12 pm
In Py2 there is the built-in function reload() to re-import a modified file. In Py3 the function is part of the module importlib.
No idea if there are other mechanisms to reload modules. Maybe removing the entries of sys.modules?
HarryvL
Postby HarryvL » Sun Jan 27, 2019 7:01 pm
Thanks Werner, a good lead. I tried the following and it works:
import sys
if 'myModule' in sys.modules.keys():
    del(sys.modules['myModule'])
print('myModule' in sys.modules.keys()) #FALSE
import myModule as mm
print('myModule' in sys.modules.keys()) #TRUE
