[SOLVED] "command not done" when doing Wiki tutorial
sdaau_ml
Post by sdaau_ml »
Hi all,
OS: Ubuntu 18.04.1 LTS
Version: 0.18.15379 (Git)
Hash: 3290c36d28551875f02333c2e01af80e38b8ad02
Python version: 2.7.15rc1
In my FreeCAD, I'm trying to do this tutorial: https://www.freecadweb.org/wiki/Manual: ... g_geometry
I just copy/pasted the lines from the second part of the tutorial, so I literally have just this at the moment:
V1 = FreeCAD.Vector(0,10,0)
V2 = FreeCAD.Vector(30,10,0)
V3 = FreeCAD.Vector(30,-10,0)
V4 = FreeCAD.Vector(0,-10,0)
L1 = Part.Line(V1,V2)
L2 = Part.Line(V4,V3)
VC1 = FreeCAD.Vector(-10,0,0)
C1 = Part.Arc(V1,VC1,V4)
VC2 = FreeCAD.Vector(40,0,0)
C2 = Part.Arc(V2,VC2,V3)
E1 = Part.Edge(L1)
E2 = Part.Edge(L2)
E3 = Part.Edge(C1)
E4 = Part.Edge(C2)
W = Part.Wire([E1,E4,E2,E3])
I try to run this code in FreeCAD Python console; I get:
>>> execfile("/path/to/testUnion.FCMacro")
  File "/path/to/testUnion.FCMacro", line 52, in <module>
Part.OCCError: BRep_API: command not done
As far as I can see from 0002110: BRep_API: command not done - FreeCAD Tracker, this is a message from OpenCascade if it cannot complete an operation - for instance, if it gets invalid objects as input.
Then again, I'm not trying to be creative here - I'm just copy pasting from a tutorial ?! So what am doing wrong - why won't this run?
Jee-Bee
Re: "command not done" when doing Wiki tutorial
Post by Jee-Bee »
try
L1 = Part.LineSegment(V1,V2)
L2 = Part.LineSegment(V4,V3)
E1 = Part.Edge(L1)
E2 = Part.Edge(L2)
E3 = Part.Edge(C1)
E4 = Part.Edge(C2)
Part.Line is pre 0.16 code... I guess this was forgotten. Part.Line is now infinite line
sdaau_ml
Post by sdaau_ml »
Thanks a ton, @Jee-Bee:
Jee-Bee wrote: Sat Dec 22, 2018 4:49 pm
Yes, that works! Thanks again!
sdaau_ml wrote: Sat Dec 22, 2018 5:02 pm L2 = Part.LineSegment(V4,V3)
I changed the wiki without testing. Could you please verify that I found all relevant places and report back?
