getObjectsByLabel - with regex?
sdaau_ml
Post by sdaau_ml »
I have read in getObjectsByLabel - FreeCAD Forum:
wmayer wrote: Thu Feb 13, 2014 4:36 pm
Or can I use this call with wildcards to get more objects?
No, you can't. If you like this can be changed to support regular expressions.
I'm not sure what they meant exactly by "this can be changed to support regular expressions." - whether I as user can change it, or whether if there are enough requests the devs might change it.
However, as far I can see from https://github.com/FreeCAD/FreeCAD/blob ... p.cpp#L430 - getObjectsByLabel only supports a plain string as an argument.
And on https://github.com/FreeCAD/FreeCAD/blob ... p.cpp#L447, it says that findObjects does accept a regex, however, it seems to search object names, not object labels.
So is there a function that I could use from Python, that does getObjectsByLabel but with a regex (without having to change C++ source code, that is)?
DeepSOIC
Re: getObjectsByLabel - with regex?
Post by DeepSOIC »
use re module from standard python library. You'll have to iterate through all objects and match their labels to a regex with your code.
Founder
Post by wmayer »
After all the OP didn't make a request that getObjectsByLabel should support regular expressions and thus it was never implemented. But as DeepSOIC already said you can do this on your own, too. And at the end it doesn't matter if you do this in your script or if it's done by FreeCAD internally.
sdaau_ml
Post by sdaau_ml »
Hi @DeepSOIC, @wmayer
Thanks a ton for the responses!
wmayer wrote: Fri Jan 11, 2019 6:58 pm After all the OP didn't make a request that getObjectsByLabel should support regular expressions and thus it was never implemented.
Ok, now I get it - much appreciated!
DeepSOIC wrote: Fri Jan 11, 2019 4:19 pm use re module from standard python library. You'll have to iterate through all objects and match their labels to a regex with your code.
That's what I wanted to know too - whether I have to iterate myself; thanks for specifying this!
wmayer wrote: Fri Jan 11, 2019 6:58 pm And at the end it doesn't matter if you do this in your script or if it's done by FreeCAD internally.
Well, it could be a regex lookup in a loop might be faster in C++ than in Python, but that's just a hunch, I don't really have any numbers to back that up. But for the kind of one-off scripts where I currently need this, it really doesn't matter. :)
