Hi everyone, I'm a newbie in FreeCAD. I am trying to create a 3D object from python script using Part Module.
I have created 3 solid objects (solid0, solid1, solid2) (the solid1 and solid2 are solid1's holes) .
When I apply solid0.cut(solid2), it's ok
But if I apply solid0.cut(solid1), The result is
I don't know what is the error. And this is the script to create solid0, solid1 and solid2 [/url].
Thank you for the help!
Help operator in Part Module
- solid1_2.PNG (6.51 KiB) Viewed 532 times
- solid_cut2.PNG (7.32 KiB) Viewed 532 times
- solid_cut.PNG (8.04 KiB) Viewed 532 times
- solid0.PNG (6.49 KiB) Viewed 532 times
Re: Help operator in Part Module
Perhaps it's only a visibility issue?
If I run your script on a new empty document the first line yields already an error:
NameError: name 'Base' is not defined
ah I forgot import Base. I have updated script already.chrisb wrote: ↑Tue Jan 22, 2019 9:53 am Perhaps it's only a visibility issue?
If I run your script on a new empty document the first line yields already an error:Code: Select all
Traceback (most recent call last): File "<input>", line 1, in <module> NameError: name 'Base' is not defined
it's not only visibility. Because when I export to a dxf and import to AutoCAD. it's same
Hello everyone, Please give me advice if you have any idea
