For example in this script :
from PySide import QtGui, QtCore
# UI Class definitions
class ExampleModalGuiClass(QtGui.QDialog):
def __init__(self):
super(ExampleModalGuiClass, self).__init__()
self.initUI()
def initUI(self):
self.result = userCancelled
# create our window
# define window xLoc,yLoc,xDim,yDim
self.setGeometry( 250, 250, 400, 350)
self.setWindowTitle("Our Example Modal Program Window")
self.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint)
# set up lists for pop-ups
self.popupItems1 = ("pizza","apples","candy","cake","potatoes")
# set up pop-up menu
self.popup1 = QtGui.QComboBox(self)
self.popup1.addItems(self.popupItems1)
self.popup1.setCurrentIndex(self.popupItems1.index("cake"))
self.popup1.activated[str].connect(self.onPopup1)
self.popup1.move(210, 115)
# cancel button
cancelButton = QtGui.QPushButton('Cancel', self)
cancelButton.clicked.connect(self.onCancel)
cancelButton.setAutoDefault(True)
cancelButton.move(150, 280)
# OK button
okButton = QtGui.QPushButton('OK', self)
okButton.clicked.connect(self.onOk)
okButton.move(260, 280)
# now make the window visible
self.show()
def onPopup1(self, selectedText):
if self.label3.text().isspace():
self.label3.setText(selectedText)
else:
self.label3.setText(self.label3.text()+","+selectedText)
def onCancel(self):
self.close()
def onOk(self,text):
self.result = userOK
reply = QtGui.QMessageBox.information(None,"","")
# Constant definitions
userCancelled = "Cancelled"
userOK = "OK"
# code ***********************************************************************************
form = ExampleModalGuiClass()
form.exec_()
