Draw two boxes, but only can see one
johnwang
Postby johnwang » Tue Jan 29, 2019 1:59 am
I am using this code to draw many boxes (Set at 2 in code). It created Shape and Shape001 on the list, but I could only see one box.
Is it the same problem as this one (https://forum.freecadweb.org/viewtopic.php?f=22&t=33715) that my code can't find the the second Shape001 to make box?
Thanks for help
Regards,
John
from FreeCAD import Base
import Part
Vx=[]
Vy=[]
Vz=[]
np=4
Vx.append(0)
Vy.append(10)
Vz.append(0)
Vx.append(30)
Vy.append(10)
Vz.append(0)
Vx.append(30)
Vy.append(-10)
Vz.append(0)
Vx.append(0)
Vy.append(-10)
Vz.append(0)
V=[]
L=[]
E=[]
W=[]
F=[]
P=[]
n=2
for i in range(n):
    for j in range(np):
	    V.append(Base.Vector(Vx[j]+i*100,Vy[j],Vz[j]))
    for j in range(np-1):
	    L.append(Part.LineSegment(V[j],V[j+1]))
    L.append(Part.LineSegment(V[np-1],V[0]))
    for j in range(np):
	    E.append(L[j].toShape())
    W.append(Part.Wire(E))
    F.append(Part.Face(W[i]))
    P.append(F[i].extrude(Base.Vector(0,0,10)))
    Part.show(P[i])
mario52
Re: Draw two boxes, but only can see one
Postby mario52 » Tue Jan 29, 2019 1:06 pm
hi
the 2 shape are in the same position
try this
import Part
Vx=[]
Vy=[]
Vz=[]
np=4
Vx.append(0)
Vy.append(10)
Vz.append(0)
Vx.append(30)
Vy.append(10)
Vz.append(0)
Vx.append(30)
Vy.append(-10)
Vz.append(0)
Vx.append(0)
Vy.append(-10)
Vz.append(0)
V=[]
L=[]
E=[]
W=[]
F=[]
P=[]
n=10
distancex = distancey = distancez = anglex = angley = anglez = 0.0    ##
for i in range(n):
    for j in range(np):
    for j in range(np):
    P[i].Placement.Base.x = distancex    ## choice x placement
    P[i].Placement.Base.y = distancey    ## choice y placement
    P[i].Placement.Base.z = distancez    ## choice z placement
# or    P[i].Placement.Base = (distancex, distancey, distancez)  ##
    P[i].Placement.Rotation = FreeCAD.Rotation(anglex, angley, anglez)  ## choice placement rotation
    Part.show(P[i])
    distancex += 10.0    ## choice x increment
    distancey += 10.0    ## choice y increment
    distancez += 10.0    ## choice z increment
    anglex += 10.0    ## choice x increment
    angley += 10.0    ## choice y increment
    anglez += 10.0    ## choice z increment
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
johnwang
Postby johnwang » Wed Jan 30, 2019 2:03 am
Hi mario,
I use "+i*100 " in V.append(Base.Vector(Vx[j]+i*100,Vy[j],Vz[j])) to try to change position, but seems not work.
I want the boxes in different size.
John
