As a result of the failure all values of the trajectory are NaN, the Duration, the Length and the positions at every time. An exception is never raised.
The weird thing is, the success or failure of the calculation seems to depend on the exact element values of the position vectors.
In the example below two sets of points are used:
set1: {(0, 0, 0), (500, 500, 500), (1000, 1000, 1000)}
set2: {(0, 0, 0), (600, 600, 600), (1200, 1200, 1200)}
With set1 the trajectory becomes invalid (all values Nan, but no exception), set2 leads to a perfectly valid trajectory.
I think the problem is inside the KD-library used to build the trajectory.
My guess is the Path_RoundedComposite::Add method. But I don't have the FreeCAD sources set up in a development environment and therefore can not debug it.
The following Python code leads to the mentioned problem (first the Python console output I received in FreeCad 0.17 or 0.18-pre. The raw code is below).
One can see that the first point set leads to an invalid trajectory (without exceptions) while the second set succeeds as expected:
from FreeCAD import Placement,Vector,Rotation
>>> from Robot import Trajectory, Waypoint
>>> t=Trajectory()
>>> t.insertWaypoints(Waypoint(Placement(Vector(0.0,0,0.0),Rotation()), type="LIN", cont=False))
Trajectory [size:1 length:0 duration:0 ]
>>> t.insertWaypoints(Waypoint(Placement(Vector(500.0,500.0,500.0),Rotation()), type="LIN", cont=True))
Trajectory [size:2 length:866.03 duration:5.8857 ]
>>> t.insertWaypoints(Waypoint(Placement(Vector(1000.0,1000.0,1000.0),Rotation()), type="LIN", cont=False))
Trajectory [size:3 length:-1.#IND duration:-1.#IND ]
>>> t.Duration
nan
>>> t.Length
nan
>>> t.position(0)
Placement [Pos=(-1.#IND,-1.#IND,-1.#IND), Yaw-Pitch-Roll=(-1.#IND,-1.#IND,-1.#IND)]
>>> t=Trajectory()
>>> t.insertWaypoints(Waypoint(Placement(Vector(600.0,600.0,600.0),Rotation()), type="LIN", cont=True))
Trajectory [size:2 length:1039.2 duration:6.4474 ]
>>> t.insertWaypoints(Waypoint(Placement(Vector(1200.0,1200.0,1200.0),Rotation()), type="LIN", cont=False))
Trajectory [size:3 length:2078.5 duration:9.118 ]
>>> t.Duration
9.11802822781911
>>> t.Length
2078.460969082653
>>> t.position(0)
Placement [Pos=(0,0,0), Yaw-Pitch-Roll=(0,0,0)]
t=Trajectory()
t.insertWaypoints(Waypoint(Placement(Vector(0.0, 0.0, 0.0),Rotation()), type="LIN", cont=False))
t.insertWaypoints(Waypoint(Placement(Vector(500.0, 500.0, 500.0),Rotation()), type="LIN", cont=True))
t.insertWaypoints(Waypoint(Placement(Vector(1000.0, 1000.0, 1000.0),Rotation()), type="LIN", cont=False))
t.Duration
t.Length
t.position(0)
t=Trajectory()
t.insertWaypoints(Waypoint(Placement(Vector(600.0, 600.0, 600.0),Rotation()), type="LIN", cont=True))
t.insertWaypoints(Waypoint(Placement(Vector(1200.0, 1200.0, 1200.0),Rotation()), type="LIN", cont=False))
t.Duration
t.Length
t.position(0)
FreeCAD OS: Windows 10
Version: 0.17.13522 (Git)
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.14
OCC version: 7.2.0
Version: 0.18.15805 (Git)
Hash: f431226bb827d960588485fbae5b5c072c7b640c
OCC version: 7.2.0
