Yes. If I got you right you do all this by scripting. So, it's up to you to set the tip of the body to the mirror object.
You can e.g. enable the macro recording to print all executed Python into to the console window. There you should find a line which assigns the mirror to the body tip.
App.newDocument("Unbenannt")
App.activeDocument().addObject('PartDesign::Body','Body')
Gui.activeView().setActiveObject('pdbody', App.activeDocument().Body)
App.activeDocument().Body.newObject('Sketcher::SketchObject','Sketch')
App.activeDocument().Sketch.Support = (App.activeDocument().XY_Plane, [''])
App.activeDocument().Sketch.MapMode = 'FlatFace'
Gui.activeDocument().setEdit('Sketch')
import PartDesignGui
ActiveSketch = App.ActiveDocument.getObject('Sketch')
geoList = []
geoList.append(Part.LineSegment(App.Vector(-19.859026,13.610367,0),App.Vector(21.382137,13.610367,0)))
geoList.append(Part.LineSegment(App.Vector(21.382137,13.610367,0),App.Vector(21.382137,-11.657660,0)))
geoList.append(Part.LineSegment(App.Vector(21.382137,-11.657660,0),App.Vector(-19.859026,-11.657660,0)))
geoList.append(Part.LineSegment(App.Vector(-19.859026,-11.657660,0),App.Vector(-19.859026,13.610367,0)))
App.ActiveDocument.Sketch.addGeometry(geoList,False)
conList = []
conList.append(Sketcher.Constraint('Coincident',0,2,1,1))
conList.append(Sketcher.Constraint('Coincident',1,2,2,1))
conList.append(Sketcher.Constraint('Coincident',2,2,3,1))
conList.append(Sketcher.Constraint('Coincident',3,2,0,1))
conList.append(Sketcher.Constraint('Horizontal',0))
conList.append(Sketcher.Constraint('Horizontal',2))
conList.append(Sketcher.Constraint('Vertical',1))
conList.append(Sketcher.Constraint('Vertical',3))
App.ActiveDocument.Sketch.addConstraint(conList)
Gui.getDocument('Unbenannt').resetEdit()
App.activeDocument().Body.newObject("PartDesign::Pad","Pad")
App.activeDocument().Pad.Profile = App.activeDocument().Sketch
App.activeDocument().Pad.Length = 10.0
Gui.activeDocument().hide("Sketch")
Gui.ActiveDocument.Pad.ShapeColor=Gui.ActiveDocument.Body.ShapeColor
Gui.ActiveDocument.Pad.LineColor=Gui.ActiveDocument.Body.LineColor
Gui.ActiveDocument.Pad.PointColor=Gui.ActiveDocument.Body.PointColor
Gui.ActiveDocument.Pad.Transparency=Gui.ActiveDocument.Body.Transparency
Gui.ActiveDocument.Pad.DisplayMode=Gui.ActiveDocument.Body.DisplayMode
Gui.activeDocument().setEdit('Pad', 0)
Gui.Selection.clearSelection()
App.ActiveDocument.Pad.Length = 10.000000
App.ActiveDocument.Pad.Length2 = 100.000000
App.ActiveDocument.Pad.Type = 0
App.ActiveDocument.Pad.UpToFace = None
App.ActiveDocument.Pad.Reversed = 0
App.ActiveDocument.Pad.Midplane = 0
App.ActiveDocument.Pad.Offset = 0.000000
Gui.activeDocument().resetEdit()
App.activeDocument().Body.newObject('Sketcher::SketchObject','Sketch001')
App.activeDocument().Sketch001.Support = (App.ActiveDocument.Pad,["Face6"])
App.activeDocument().Sketch001.MapMode = 'FlatFace'
Gui.activeDocument().setEdit('Sketch001')
Gui.activateWorkbench('SketcherWorkbench')
ActiveSketch = App.ActiveDocument.getObject('Sketch001')
if ActiveSketch.ViewObject.RestoreCamera:
ActiveSketch.ViewObject.TempoVis.saveCamera()
geoList = []
geoList.append(Part.LineSegment(App.Vector(-13.274072,9.593348,0),App.Vector(-8.626629,9.593348,0)))
geoList.append(Part.LineSegment(App.Vector(-8.626629,9.593348,0),App.Vector(-8.626629,6.547125,0)))
geoList.append(Part.LineSegment(App.Vector(-8.626629,6.547125,0),App.Vector(-13.274072,6.547125,0)))
geoList.append(Part.LineSegment(App.Vector(-13.274072,6.547125,0),App.Vector(-13.274072,9.593348,0)))
App.ActiveDocument.Sketch001.addGeometry(geoList,False)
conList = []
App.ActiveDocument.Sketch001.addConstraint(conList)
Gui.activateWorkbench('PartDesignWorkbench')
App.getDocument('Unbenannt').recompute()
App.activeDocument().Body.newObject("PartDesign::Pad","Pad001")
App.activeDocument().Pad001.Profile = App.activeDocument().Sketch001
App.activeDocument().Pad001.Length = 10.0
Gui.activeDocument().hide("Sketch001")
Gui.ActiveDocument.Pad001.ShapeColor=Gui.ActiveDocument.Body.ShapeColor
Gui.ActiveDocument.Pad001.LineColor=Gui.ActiveDocument.Body.LineColor
Gui.ActiveDocument.Pad001.PointColor=Gui.ActiveDocument.Body.PointColor
Gui.ActiveDocument.Pad001.Transparency=Gui.ActiveDocument.Body.Transparency
Gui.ActiveDocument.Pad001.DisplayMode=Gui.ActiveDocument.Body.DisplayMode
Gui.activeDocument().setEdit('Pad001', 0)
App.ActiveDocument.Pad001.Length = 10.000000
App.ActiveDocument.Pad001.Length2 = 100.000000
App.ActiveDocument.Pad001.Type = 0
App.ActiveDocument.Pad001.UpToFace = None
App.ActiveDocument.Pad001.Reversed = 0
App.ActiveDocument.Pad001.Midplane = 0
App.ActiveDocument.Pad001.Offset = 0.000000
Gui.activeDocument().hide("Pad")
App.activeDocument().Body.newObject("PartDesign::Mirrored","Mirrored")
App.activeDocument().Mirrored.Originals = [App.activeDocument().Pad001,]
App.activeDocument().Mirrored.MirrorPlane = (App.activeDocument().Sketch001, ["V_Axis"])
Gui.ActiveDocument.Mirrored.ShapeColor=Gui.ActiveDocument.Body.ShapeColor
Gui.ActiveDocument.Mirrored.LineColor=Gui.ActiveDocument.Body.LineColor
Gui.ActiveDocument.Mirrored.PointColor=Gui.ActiveDocument.Body.PointColor
Gui.ActiveDocument.Mirrored.Transparency=Gui.ActiveDocument.Body.Transparency
Gui.ActiveDocument.Mirrored.DisplayMode=Gui.ActiveDocument.Body.DisplayMode
Gui.activeDocument().setEdit('Mirrored', 0)
App.activeDocument().Body.Tip = App.activeDocument().Mirrored
Gui.activeDocument().show("Mirrored")
App.ActiveDocument.Mirrored.MirrorPlane = (App.ActiveDocument.Sketch001, ["V_Axis"])
App.ActiveDocument.Mirrored.Originals = [App.ActiveDocument.Pad001,]
Gui.activeDocument().hide("Pad001")
