FeaturePython / Scripted Object question
Joel_graff
Postby Joel_graff » Mon Feb 11, 2019 1:59 pm
I have a custom feature python object with a custom function and property. If I create the object, the property is exposed, but the function is not. I have a need to run a FeaturePython object function directly from outside the object itself (rather than letting it be called from execute() or some other event callback).
As I understand FPO's, I don't think that's possible. But just in case I'm wrong, I thought I'd ask.
You can find the FreeCAD Trails workbench for transportation engineering on my github at:
https://www.github.com/joelgraff/freecad.trails
Chris_G
Re: FeaturePython / Scripted Object question
Postby Chris_G » Mon Feb 11, 2019 3:06 pm
You should be able to call your function through the Proxy object :
my_FPO.Proxy.my_function()
Joel_graff
Postby Joel_graff » Mon Feb 11, 2019 5:44 pm
Gotcha. Works as expected. Thanks.
