Python editor autocomplete
Hi all,
Autocomplete does not seem to be working when using the FreeCAD built in editor. Is there some setting that I need to change? It does work for the console.
Thanks
Thanks
- Joel_graff
Re: Python editor autocomplete
Autocomplete should just work...
I don't know anything about this specific problem, but you can help identify issues by doing two things:
1. Start FreeCAD from the command line / terminal. If there's any output identifying errors / warnings, copy / paste that into a message here.
2. With FreeCAD running, select Help -> About and click the 'Copy to Clipboard' button, then paste the results into a message. That will provide the details about your FreeCAD configuration...
No errors appear when running from the command line. It does print something in the report view:
This is my installation information:
Autocomplete does work when writing in the Console, but it does not work in the editor. Are you sure it is also supposed to work in the editor?
Run Gui init script
Init: Running FreeCADGuiInit.py start script...
Init: Searching modules...
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Sketcher... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\ReverseEngineering... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Show(InitGui.py not found)... ignore
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Image... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Surface... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\PartDesign... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Measure(InitGui.py not found)... ignore
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Ship... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Plot... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\MeshPart... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\OpenSCAD... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Fem... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Spreadsheet... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Start... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Points... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Draft... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Test... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Import... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\TechDraw... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Tux... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Complete... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Web... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Material... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Raytracing... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Mesh... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Path... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Part... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Arch... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Robot... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\AddonManager... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Idf(InitGui.py not found)... ignore
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Inspection... done
Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Drawing... done
Init: Loading FreeCAD GUI
Init: Running FreeCADGuiInit.py start script... done
Init: Activating default workbench StartWorkbench
Loading GUI of Web module... done
Loading GUI of Start module... done
Loading Start module... done
not a freecad file: .STEP
QNetworkAccessFileBackendFactory: URL has no schema set, use file:// for files
Init: Showing main window
Main window restored
Show main window
Toolbars restored
3Dconnexion device not attached.
Init: Entering event loop
Init: Processing command line files
Version: 0.17.13509 (Git)
Branch: releases/FreeCAD-0-17
Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7
Python version: 2.7.14
OCC version: 7.2.0
Locale: English/Belgium (en_BE)
To my knowledge it's not working in the editor (console only).
For me, the editor is just a python colored text editor.
- Joel_graff
Ah, I think I had assumed you were referring to the console - I never think of the macro editor as I never use it. I do all of my development in an IDE outside of FreeCAD, usually.
Anyway, it appears the editor doesn't support auto-complete. :/
Okay, I guess this can be closed then. Thanks anyway guys!
you could open a ticket on the tracker and link back to this thread + notate in this thread what ticket number you created.
BTW, we recommend using version 0.18
How do configure for autocomplete in external editor?Joel_graff wrote: ↑Fri Mar 22, 2019 4:22 pmAutocomplete should just work...
Checkout https://forum.freecadweb.org/viewtopic.php?f=8&t=40673
Although it seems that autocomplete is not fully supported.
