Boolean null and universal sets
AdrianBowyer
Post by AdrianBowyer »
A feature request.
When writing Python to build shapes it'd be very useful to have the Universal and Null sets available in the Part API. (I suspect these are already used internally.) Then one could write:
a = Part.Null()
for i in range(0, n):
 a = a.fuse(MyShapeThatDependsOnN(n))
or
a = Part.Universal()
 a = a.common(MyShapeThatDependsOnN(n))
Both would also be useful in conditional code:
a = SomeShape()
if n > 0:
 b = MyShapeThatDependsOnN(n)
else:
 b = Part.Null()
a = a.fuse(b)
Re: Boolean null and universal sets
Post by Kunda1 »
bumping this for more disussion
Founder
Post by wmayer »
Part.Shape() delivers the null shape. A universal shape doesn't exist, only a half-space solid is supported by the kernel.
The best what you can do to have a universal shape is creating a sphere with a very high radius:
Part.makeSphere(1e10)
AdrianBowyer
wmayer wrote: Thu Oct 01, 2020 6:35 pm Part.Shape() delivers the null shape. A universal shape doesn't exist, only a half-space solid is supported by the kernel.
Sadly that doesn't work. The first piece of code in my original post then gives the error:
<class 'Part.OCCError'>: Base shape is null
AdrianBowyer
AdrianBowyer wrote: Thu Aug 05, 2021 9:51 am
I use this to make the null set, which is horrible, but which works:
def NullSet():
 a = Part.makeBox(1, 1, 1)
 a.translate(Base.Vector(10, 10, 10))
 return a.common(Part.makeBox(1, 1, 1))
Post by Kunda1 »
AdrianBowyer wrote: Thu Aug 05, 2021 9:57 am
def NullSet():
Hello @AdrianBowyer, It's excellent to see you on this forum! Just a quick question, what version of FreeCAD are you using? (please copy/paste About) Thanks!
AdrianBowyer
Kunda1 wrote: Thu Aug 05, 2021 9:59 am Hello @AdrianBowyer, It's excellent to see you on this forum! Just a quick question, what version of FreeCAD are you using? (please copy/paste About) Thanks!
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.24291 (Git) AppImage
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
Founder
Post by wmayer »
git commit 666f67f8d9
Allows you to write:
a = Part.Shape() # Null shape
b = Part.makeBox(1,1,1)
c = b.cut(a)
c.isNull()
c = a.cut(b)
c.isNull()
c = a.fuse(b)
c.isNull()
c = b.fuse(a)
c.isNull()
c = a.common(b)
c.isNull()
c = b.common(a)
c.isNull()
AdrianBowyer
Hi!
That doesn't work, I'm afraid. It gives a
error, by which it means the shape is undefined. The CSG null set is a perfectly well defined shape - empty space.
Founder
Post by wmayer »
Have you built the latest version that includes these changes?
