Macro_Connect_And_Sweep
ghioan
Postby ghioan » Thu Apr 04, 2019 1:18 pm
Hi! I want to use Macro_Connect_And_Sweep in freecad 0.18 but it do not working, but in freecad 0.17 it working. Do you know a similar macro that working in freecad 0.18?
Mod Edit: OP is referring to Macro_Connect_And_Sweep
Reason: added link to macro in question
mario52
Re: Macro_Connect_And_Sweep
Postby mario52 » Fri Apr 05, 2019 2:30 pm
hi
modify the line 79 adding parenthesis (compatible Python 3: print())
print( "Path for the icons : " , path )
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
ghioan
Postby ghioan » Sat Apr 06, 2019 7:48 am
thank you!
michael.h
Postby michael.h » Tue Jun 18, 2019 7:36 am
Hi Marco!
The modified version on GitHub doesn't work for me on 0.18 either.
The Freecad.log says
Err: Select twoo objects (1 object(s) selected)
although I have selected the two Endpoints (which works in 0.17).
Any ideas?
Michael
Postby Kunda1 » Tue Jun 18, 2019 8:32 am
Offtopic: the macro itself isn't on the wiki but in a gist
https://gist.githubusercontent.com/mari ... ep.FCMacro
There are some typos in it. Where do i submit them? Is it better for these type of macros to be available in the FreeCAD-addons repo ?
mario52
Postby mario52 » Tue Jun 18, 2019 11:34 am
Hi michael.h
thanks for apreciate my litle macro,
the macro work with 0.16, 0.17, 0.18, 0.18 pre, 0.19 (16993Git), 0.19 (16687Git)
the only little problem "Recompute" with Lune , i have corrected it now (ver 0.6)
Hi Marco!
for this error (1 object(s) selected), you must select 2 points or 2 objects or one point and one object
tray this (2 objects) and please report if you have again one error
mario
michael.h
Postby michael.h » Wed Jun 19, 2019 10:49 am
Hi Mario,
I still got the same error. Please see the attached video I made showing the problem.
Maybe I'm doing something wrong, but it works like charm with 0.17 but not with 0.18 16110 (Git).
https://drive.google.com/open?id=1OoHp2 ... 8uu4tG8hic
mario52
Postby mario52 » Thu Jun 20, 2019 9:18 am
Hi
thanks for report
i use the code
import FreeCADGui, Draft
sel = FreeCADGui.Selection.getSelection()
print(len(sel))
two points selected in the same line (object) :
< and 0.17 give 2
0.18 and > give 1
change in FC or bug ??
pending my correction you can create a point at the begin and end line and select the two points
i work to the correction
thanks
mario
mario52
Postby mario52 » Wed Jun 26, 2019 5:55 pm
hi
i have upgrade my macro (available with AddonManager), i separate the mode:
1: Object to Object
2: Object to SubObject
3: SubObject to SubObject (by default)
and if one object wire line arc is selected the forme is created in the direction of the object
example selected
line = point begin to point end (or edge) (as point to point)
arc = angle begin to angle end (as point to point)
example animated on the wiki
now the macro is adapted for the body (in case if the body is not in 0,0,0 points)
mario
