referring to this thread [new feature] Bspline knots
I learned that
So what I would need in my user case is to break a part a Bspline into sub-splines all of the same degree (in my need 3), but with always the same number of control points (in my need 4 .Chris_G wrote: ↑Wed Apr 12, 2017 9:39 am It is always possible to increase the degree of a BSpline curve, while keeping its exact shape.
The algorithm will ( usually ? always ? I'm not sure ) add 1 control point for each degree increase step.
On the other hand, in the general case, there is no way to decrease the degree of the curve AND keep the original shape.
This is because I noticed that KiCAD, when importing a DXF file with a complex Bspline, always breaks it in sub-splines, all with degree = 3 and 4 control points.
I'm attaching a Bspline imported from a dxf file in FC and the counter part imported by KiCAD and then re-exported broken in sub-splines.
The question is:
Is it possible to break the first single spline sketch into multi-splines sketch within the degree=3 and with 4 control points by using a python script?
I'm attaching the FC file with the two Sketches and the images of the differences.
