Permission denied error when writing to transient filepath
Joel_graff
Post by Joel_graff »
So I'm trying to write to a transient file in FreeCAD. Unfortunately, when I try to open it for writing with the following code:
>>> with open(App.ActiveDocument.TransientDir + '/alignment.xml', 'w', encoding='UTF-8') as _f:
... 	print(_f)
I get the error:
PermissionError: [Errno 13] Permission denied: 'C:\\Users\\GRAFFJC\\AppData\\Local\\Temp\\FreeCAD_Doc_cfdd3cb9-5e3f-48c6-b645-105141669846_a1475c_5068/alignment.xml'
I've checked and I have full permissions to the file under my username, so I'm a bit perplexed as to why this is happening. I've successfully done this before, so it must a change I made, but I don't know what else would cause that error.
Syres
Re: Permission denied error when writing to transient filepath
Post by Syres »
Is there not a filename.LOCK file in the TEMP folder from an old process that didn't close cleanly in the recent past, hence giving the permission denied error?
Joel_graff
Syres wrote: Wed Apr 17, 2019 3:37 pm Is there not a filename.LOCK file in the TEMP folder from an old process that didn't close cleanly in the recent past, hence giving the permission denied error?
The only lock file I see is 'FreeCAD_5068.lock' in the parent folder. In the transient folder the only file that is there is the file I'm trying to overwrite.
Joel_graff
So here's an example FeaturePython class that demonstrates the error.
I'm trying to write to the XML in the onDocumentRestored event. Maybe that's not allowed? Nevertheless, I get the same error if I try to open the file for writing from the FreeCAD python console, or even the python console launched from a terminal window.
I get the error following the steps below in the Python console:
1. Call create()
2. Save the file
3. Close the file, then reopen it.
Notes:
- Step 1 should create 'my_file.txt' in the user home directory
- Step 3 tries to write to the transient file location, which triggers the 'Permission Denied' error.
import datetime
import FreeCAD as App
def create():
    file_path = App.getHomePath() + 'my_file.txt'
    with open(file_path, ''w', encoding='UTF-8') as _f:
        _f.write('Initial write at ' + str(datetime.datetime.now()))
    obj = App.ActiveDocument.addObject("App::FeaturePython", 'TransientFpo')
    fpo = TransientFpo(obj)
    obj.filepath = file_path
class TransientFpo():
    def __init__(self, obj):
        Default Constructor
        obj.Proxy = self
        self.Type = "TransientFpo"
        self.Object = obj
        obj.addProperty(
            'App::PropertyFileIncluded', 'filepath', '').filepath = ''
        self.init = True
    def __getstate__(self):
        return self.Type
    def __setstate__(self, state):
        if state:
            self.Type = state
    def onDocumentRestored(self, obj):
        with open(App.ActiveDocument.TransientDir + '/my_file.txt', 'w', encoding='UTF-8') as _f:
            _f.write('updated at ' + str(datetime.datetime.now()))
Founder
Post by wmayer »
With your code snippet I can reproduce this problem.
I don't know how it happens but the file my_file.txt inside the transient directory is marked as read-only. But when I extract the file my_file.txt from the zip file then it is not marked as read-only. So, at some point during the restore the file attribute must be changed.
EDIT:
It's the assignment to the property that changes the file attribute.
import datetime
doc=App.ActiveDocument
obj=doc.addObject("App::FeaturePython","Feature")
obj.addProperty("App::PropertyFileIncluded","File")
    _f.write('initialized at ' + str(datetime.datetime.now()))
# after this the file is read-only
obj.File=doc.TransientDir+"/alignment.xml"
# raises a permission error
For more details see: https://github.com/FreeCAD/FreeCAD/blob ... e.cpp#L181
So, as soon as a file is assigned to a property of a feature it's marked read-only to make the undo/redo working and that nobody unauthorized modifies it.
So, if you are sure about what you do you can remove the write-protection, write to it and restore the protection afterwards.
Joel_graff
wmayer wrote: Tue May 28, 2019 1:34 pm So, if you are sure about what you do you can remove the write-protection, write to it and restore the protection afterwards.
Hmmm... os.chmod() looks like it will do it. According to the Python docs, Windows will honor stat.S_IWRITE and stat.S_IREAD, which controls user-level read / write permissions... I think. :)
Thanks!
