Starting and controlling FreeCAD from external console
JiriVALASEK
Postby JiriVALASEK » Wed Apr 17, 2019 7:54 pm
Does anyone know, if there is a way how to start FreeCAD with GUI, open a workbench, run some commands/MACRO from a python console or for example MATLAB?
I'd like to do some visualizations in FreeCAD based on computations from MATLAB/python/Julia script. The ideal would be to be able to control the GUI online from outside, but being able to start FreeCAD GUI, open a file and run a MACRO would be sufficient.
Thanks
mario52
Re: Starting and controlling FreeCAD from external console
Postby mario52 » Sat Apr 20, 2019 10:13 am
hi
maybe Embedding_FreeCAD for include FreeCAD ...
here command Python for execute FreeCAD
import os  # executer un programme externe
os.startfile("C:/Program Files/FreeCAD 0.17/bin/FreeCAD.exe")
here for execute FreeCAD and the macro if the .FCMacro is associate to FreeCAD
os.startfile("C:/Users/Your_User_name/AppData/Roaming/FreeCAD/Macro/Macro_Window_fonts_Single.FCMacro")
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
galou_breizh
Postby galou_breizh » Sun Apr 21, 2019 8:42 am
Ahoj,
you can either directly start FreeCAD (with GUI), IIRC with `FreeCAD macro_name.FCMacro` and use the full featured embedded Python console or use the FreeCAD kernel for Jupyter (https://github.com/looooo/jupyter_freecad_kernel) for a more pleasant interaction with Python.
For Matlab it can be more difficult but not impossible because some people already managed to interact with FreeCAD from Javascript though some server running within FreeCAD. I don't know anything ready for Matlab.
Cheers,
Gaël
Jee-Bee
Postby Jee-Bee » Mon Apr 22, 2019 8:05 am
numpy and matplotlib (both are python packages for numerical computing) should working with FreeCAD
Matplotlib isn't added by default i think. but some workbenches use it so it should be possible.
https://www.numpy.org
https://matplotlib.org
JiriVALASEK
Postby JiriVALASEK » Mon Apr 22, 2019 9:41 am
Thanks for help,
I found a way to do what I need using a custom workbench and a server.
galou_breizh
Postby galou_breizh » Mon Apr 29, 2019 7:08 pm
Nice! Glad you solved your problem. If your workbench is something general, could you consider sharing it and documenting its use?
Thanks,
Gaël
JiriVALASEK
Postby JiriVALASEK » Thu Oct 10, 2019 6:53 am
Thanks,
Gaël
Hi, I just finished it - https://github.com/JiriValasek/Animate - this is it. The server tool does exactly what I wanted.
microelly2
Postby microelly2 » Thu Oct 10, 2019 7:15 am
Thank you for sharing this.
mario52
Postby mario52 » Thu Oct 10, 2019 9:41 am
hi
good macro thank for sharing
for install it with AddonManager you must replace
FreeCAD.getHomePath()
by
FreeCAD.getUserAppDataDir()
in this mode your addon is usable directly with many instalation of FreeCAD ( os Windows)
(what I have done)
thanks
mario
Postby Kunda1 » Thu Oct 10, 2019 1:17 pm
sort of related, but more as a joke: If you're really interested in controlling FreeCAD externally:
https://forum.freecadweb.org/viewtopic.php?f=24&t=29988& (FrontPanel Simulation WB)
