[Python] .connectEdgesToWires() not building the longest possible wire
brst
Post by brst »
Hello forum members,
I am trying to apply the solution of this thread "https://forum.freecadweb.org/viewtopic.php?f=22&t=35723".
The difference here is, that there aren't two faces now, but a face and its projection.
So the problem here is, that the length of the Wires from the face and the compound's Wire list is different from the Wires list length. The face's wire list got the OuterWire/Wire merged into one Wire.
In order to merge the OuterWire into one Wire in the projection too, I used the following code:
project = Face2.project([face1])
comp = Part.makeCompound([])
comp.add(project)
comp.Wires
comp.connectEdgesToWires()
according to the documentation, it should already merge the longest possible wire possible, but it does not, even with using a reasonable
tolerance and trying out the Shared=True and =False option
Following is my failing approach to form the longest wire manually:
outerWire = []
lenOuterWire = len(face.Wires[0].Edges)
for wire in comp.Wires[slice(None, lenOuterWire)]:
	outerWire.append(wire)
wire1 = Part.Wire(outerWire)
wire2 = Part.Wire(comp.Wires[slice(lenOuterWire,None)])
wire2.append(wire1)
#Part.OCCError: class Standard_NoSuchObject BRepFill_CompatibleWires::SameNumberByPolarMethod : the wires must be closed
wire1.isClosed()
# prints False
#The other wires are closed
wire1 = Part.Wire(outerWire, closed = True)  # didn't raise an error, but still is not closed.
wire = Part.Wire(project.Edges) # leads to Part.OCCError: BRep_API: command not done
FreeCAD rookie
