GT2, GT3 and GT5 Timing Gear Creator
eaguirre
Postby eaguirre » Thu Apr 25, 2019 3:38 am
* New code attached (version 1.4)
- Fixing bugs related to size of top and base
- Adding code to keep dialog upfront main window (thanks mario52 !)
Screen Shot 2019-04-30 at 8.38.47 AM.png (20.36 KiB) Viewed 3173 times
* New code attached (version 1.3)
- Adding key for shaft hub
- Fixing issue with top
- Fixing issue with shaft (now values are in diameter)
* New code attached (version 1.2)
Hi I created a GT2, GT3, GT5 gear macro for my personal use and I wanted to share it. I posted an early version in the French Forum, but I added some new features (like the shaft hole (circle or hexagon) a base and top).
I attached some images and the source code.
Hope it helps,
eaguirre
Screen Shot 2019-04-24 at 10.38.02 PM.png (25.82 KiB) Viewed 3439 times
# -*- coding: utf-8 -*-
# 						Copyright (c) 2019 - Emilio Aguirre
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
# of the Software, and to permit persons to whom the Software is furnished to do so,
# subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all
# copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
# INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR
# PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
# LIABLEFOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
# TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE
# USE OR OTHER DEALINGS IN THE SOFTWARE.
__title__   = "GT2/GT3/GT5 Timing Gear Creator"
__author__  = "eaguirre"
__version__ = "1.4"
__date__    = "30/04/2019"
__url__     = "http://www.emilioaguirre.com"
__Comment__ = "GT2/GT3/GT5 Gear Creator Macro (any gear size from 5 to 360 teeth)"
__Communication__ = "info@emilioaguirre.com"
import math
import Part
import sys
import time
import FreeCAD, FreeCADGui
import Sketcher, PartDesign
import ProfileLib.RegularPolygon
from FreeCAD import Base
try:
    _fromUtf8 = QtCore.QString.fromUtf8
except AttributeError:
    def _fromUtf8(s):
        return s
try:
    _encoding = QtGui.QApplication.UnicodeUTF8
    def _translate(context, text, disambig):
        return QtGui.QApplication.translate(context, text, disambig, _encoding)
        return QtGui.QApplication.translate(context, text, disambig)
# QT Window Class
class GTWnd(object):
	def __init__(self, MainWindow):
		self.shaft = True
		self.isCircle = True
		self.shaft_diameter = 5.0
		self.hgear = 6.0
		self.base_height = 1.0
		self.base_diameter = 6.37
		self.top_height = 1.0
		self.top_diameter = 6.37
		self.addBase = False
		self.addTop = False
		self.max_shaft_diameter = 100.0
		self.teeth = 20
		self.w = 300.0
		self.h = 340.0
		self.addKey = False
		self.key_b = 2
		self.key_h = 2
		self.t1 = 1.2
		self.t2 = 1
		# UI Definition
		self.window = MainWindow
		MainWindow.setObjectName(_fromUtf8("MainWindow"))
		MainWindow.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint)
		MainWindow.resize(self.w, self.h)
		self.central_wdgt = QtGui.QWidget(MainWindow)
		self.central_wdgt.setObjectName(_fromUtf8("centralWidget"))
		# UI Elements
		self.typeLbl = QtGui.QLabel(self.central_wdgt)
		self.typeLbl.setGeometry(QtCore.QRect(self.w*0.05, self.h*0.01, 150, 16))
		self.typeLbl.setObjectName("typeLbl")
		self.gt_type = QtGui.QComboBox(self.central_wdgt)
		self.gt_type.addItems(["GT2", "GT3", "GT5"])
		self.gt_type.setGeometry(QtCore.QRect(self.w*0.45, self.h*0.01, 95, 20))
		self.gt_type.setObjectName(_fromUtf8("gt_type"))
		self.gt_type.currentIndexChanged.connect(self.on_gt_type_change)
		self.teethLbl = QtGui.QLabel(self.central_wdgt)
		self.teethLbl.setGeometry(QtCore.QRect(self.w*0.05, self.h*0.08, 150, 16))
		self.teethLbl.setObjectName("teethLbl")
		self.num_teeth = QtGui.QSpinBox(self.central_wdgt)
		self.num_teeth.setGeometry(QtCore.QRect(self.w*0.45, self.h*0.08, 100, 22))
		self.num_teeth.setMinimum(5)
		self.num_teeth.setMaximum(360)
		self.num_teeth.setSingleStep(1)
		self.num_teeth.setValue(int(self.teeth))
		self.num_teeth.setObjectName(_fromUtf8("num_teeth"))
		self.num_teeth.valueChanged.connect(self.on_num_teeth_changed)
		self.rangeLbl = QtGui.QLabel(self.central_wdgt)
		self.rangeLbl.setGeometry(QtCore.QRect(self.w*0.80, self.h*0.08, 150, 16))
		self.rangeLbl.setObjectName("typeLbl")
		self.heightLbl = QtGui.QLabel(self.central_wdgt)
		self.heightLbl.setGeometry(QtCore.QRect(self.w*0.05, self.h*0.16, 150, 16))
		self.heightLbl.setObjectName("heightLbl")
		self.hgearear = QtGui.QDoubleSpinBox(self.central_wdgt)
		self.hgearear.setGeometry(QtCore.QRect(self.w*0.45, self.h*0.16, 100, 22))
		self.hgearear.setMinimum(0.01)
		self.hgearear.setMaximum(100.0)
		self.hgearear.setSingleStep(0.01)
		self.hgearear.setValue(float(self.hgear))
		self.hgearear.setObjectName(_fromUtf8("hgearear"))
		self.hgearear.valueChanged.connect(self.on_hgearear_valuechanged)
		self.mmLbl = QtGui.QLabel(self.central_wdgt)
		self.mmLbl.setGeometry(QtCore.QRect(self.w*0.80, self.h*0.16, 32, 16))
		self.mmLbl.setObjectName("mmLbl")
		# Shaft Information
		self.checkShaft = QtGui.QCheckBox("Shaft diameter", self.central_wdgt)
		self.checkShaft.setGeometry(QtCore.QRect(self.w*0.05, self.h*0.25, 200, 25))
		self.checkShaft.setChecked(self.shaft)
		self.checkShaft.clicked.connect(self.on_checkShaft_clicked)
		self.diameter_shaft = QtGui.QDoubleSpinBox(self.central_wdgt)
		self.diameter_shaft.setGeometry(QtCore.QRect(self.w*0.45, self.h*0.25, 100, 22))
		self.diameter_shaft.setMinimum(0.01)
		self.diameter_shaft.setMaximum(100.0)
		self.diameter_shaft.setSingleStep(0.01)
		self.diameter_shaft.setValue(self.shaft_diameter)
		self.diameter_shaft.setObjectName(_fromUtf8("diameter_shaft"))
		self.diameter_shaft.valueChanged.connect(self.on_diameter_shaft_valuechanged)
		self.mm2Lbl = QtGui.QLabel(self.central_wdgt)
		self.mm2Lbl.setGeometry(QtCore.QRect(self.w*0.8, self.h*0.25, 32, 16))
		self.mm2Lbl.setObjectName("mm2Lbl")
		self.radioCircle = QtGui.QRadioButton("Circle",self.central_wdgt)
		self.radioCircle.move(self.w*0.25, self.h*0.33)
		self.radioCircle.setChecked(self.isCircle)
		self.radioCircle.clicked.connect(self.on_radioCircle_clicked)
		self.checkKeyHub = QtGui.QCheckBox("Key hub", self.central_wdgt)
		self.checkKeyHub.setGeometry(QtCore.QRect(self.w*0.55, self.h*0.33, 200, 25))
		self.checkKeyHub.setChecked(self.addKey)
		self.checkKeyHub.clicked.connect(self.on_checkKeyHub_clicked)
		self.checkKeyHub.hide()
		self.radioHex = QtGui.QRadioButton("Hexagon",self.central_wdgt)
		self.radioHex.move(self.w*0.25, self.h*0.38)
		self.radioHex.setChecked(not self.isCircle)
		self.radioHex.clicked.connect(self.on_radioHex_clicked)
		# Base information
		self.checkBase = QtGui.QCheckBox("Add base", self.central_wdgt)
		self.checkBase.move(self.w*0.05, self.h*0.45)
		self.checkBase.setChecked(self.addBase)
		self.checkBase.clicked.connect(self.on_checkBase_clicked)
		self.heightBaseLbl = QtGui.QLabel(self.central_wdgt)
		self.heightBaseLbl.setGeometry(QtCore.QRect(self.w*0.4, self.h*0.45, 32, 16))
		self.heightBaseLbl.setObjectName("heightBaseLbl")
		self.heightBaseLbl.hide()
		self.height_base = QtGui.QDoubleSpinBox(self.central_wdgt)
		self.height_base.setGeometry(QtCore.QRect(self.w*0.45, self.h*0.45, 100, 22))
		self.height_base.setMinimum(0.01)
		self.height_base.setMaximum(100.0)
		self.height_base.setSingleStep(0.5)
		self.height_base.setValue(self.base_height)
		self.height_base.setObjectName(_fromUtf8("height_base"))
		self.height_base.valueChanged.connect(self.on_height_base_valuechanged)
		self.height_base.hide()
		self.mm3Lbl = QtGui.QLabel(self.central_wdgt)
		self.mm3Lbl.setGeometry(QtCore.QRect(self.w*0.8, self.h*0.45, 32, 16))
		self.mm3Lbl.setObjectName("mm3Lbl")
		self.mm3Lbl.hide()
		self.radiusBaseLbl = QtGui.QLabel(self.central_wdgt)
		self.radiusBaseLbl.setGeometry(QtCore.QRect(self.w*0.4, self.h*0.54, 32, 16))
		self.radiusBaseLbl.setObjectName("radiusBaseLbl")
		self.radiusBaseLbl.hide()
		self.diameter_base = QtGui.QDoubleSpinBox(self.central_wdgt)
		self.diameter_base.setGeometry(QtCore.QRect(self.w*0.45, self.h*0.54, 100, 22))
		self.diameter_base.setMinimum(self.shaft_diameter)
		self.diameter_base.setMaximum(500.0)
		self.diameter_base.setSingleStep(0.5)
		self.diameter_base.setValue(self.base_diameter)
		self.diameter_base.setObjectName(_fromUtf8("diameter_base"))
		self.diameter_base.valueChanged.connect(self.on_diameter_base_valuechanged)
		self.diameter_base.hide()
		self.mm4Lbl = QtGui.QLabel(self.central_wdgt)
		self.mm4Lbl.setGeometry(QtCore.QRect(self.w*0.8, self.h*0.54, 32, 16))
		self.mm4Lbl.setObjectName("mm4Lbl")
		self.mm4Lbl.hide()
		# Top information
		self.checkTop = QtGui.QCheckBox("Add top", self.central_wdgt)
		self.checkTop.move(self.w*0.05, self.h*0.63)
		self.checkTop.setChecked(self.addBase)
		self.checkTop.clicked.connect(self.on_checkTop_clicked)
		self.heightTopLbl = QtGui.QLabel(self.central_wdgt)
		self.heightTopLbl.setGeometry(QtCore.QRect(self.w*0.4, self.h*0.63, 32, 16))
		self.heightTopLbl.setObjectName("heightTopLbl")
		self.heightTopLbl.hide()
		self.height_top = QtGui.QDoubleSpinBox(self.central_wdgt)
		self.height_top.setGeometry(QtCore.QRect(self.w*0.45, self.h*0.63, 100, 22))
		self.height_top.setMinimum(0.01)
		self.height_top.setMaximum(100.0)
		self.height_top.setSingleStep(0.5)
		self.height_top.setValue(self.base_height)
		self.height_top.setObjectName(_fromUtf8("height_top"))
		self.height_top.valueChanged.connect(self.on_height_top_valuechanged)
		self.height_top.hide()
		self.mm5Lbl = QtGui.QLabel(self.central_wdgt)
		self.mm5Lbl.setGeometry(QtCore.QRect(self.w*0.8, self.h*0.63, 32, 16))
		self.mm5Lbl.setObjectName("mm5Lbl")
		self.mm5Lbl.hide()
		self.radiusTopLbl = QtGui.QLabel(self.central_wdgt)
		self.radiusTopLbl.setGeometry(QtCore.QRect(self.w*0.4, self.h*0.72, 32, 16))
		self.radiusTopLbl.setObjectName("radiusTopLbl")
		self.radiusTopLbl.hide()
		self.diameter_top = QtGui.QDoubleSpinBox(self.central_wdgt)
		self.diameter_top.setGeometry(QtCore.QRect(self.w*0.45, self.h*0.72, 100, 22))
		self.diameter_top.setMinimum(self.shaft_diameter)
		self.diameter_top.setMaximum(500.0)
		self.diameter_top.setSingleStep(0.5)
		self.diameter_top.setValue(self.top_diameter)
		self.diameter_top.setObjectName(_fromUtf8("diameter_top"))
		self.diameter_top.valueChanged.connect(self.on_diameter_top_valuechanged)
		self.diameter_top.hide()
		self.mm6Lbl = QtGui.QLabel(self.central_wdgt)
		self.mm6Lbl.setGeometry(QtCore.QRect(self.w*0.8, self.h*0.72, 32, 16))
		self.mm6Lbl.setObjectName("mm6Lbl")
		self.mm6Lbl.hide()
		self.createBtn = QtGui.QPushButton(self.central_wdgt)
		self.createBtn.setGeometry(QtCore.QRect(self.w*0.65, self.h*0.81, 80, 28))
		self.createBtn.setObjectName(_fromUtf8("Create"))
		self.createBtn.clicked.connect(self.on_create_clicked)
		self.cancelBtn = QtGui.QPushButton(self.central_wdgt)
		self.cancelBtn.setGeometry(QtCore.QRect(self.w*0.2, self.h*0.81, 80, 28))
		self.cancelBtn.setObjectName(_fromUtf8("cancel"))
		self.cancelBtn.clicked.connect(self.on_cancel_clicked)
		# Set UI elements to window
		MainWindow.setCentralWidget(self.central_wdgt)
		# Set strings to UI
		self.retranslateUi(MainWindow)
		#  Key Size Chart Standard Metric Keys/Keyways Engineering
		self.metric_keys = [
			{'over':6,'upto':8,'b':2,'h':2,'t1':1.2,'t2':1,'r':0.08},
			{'over':8,'upto':10,'b':3,'h':3,'t1':1.8,'t2':1.4,'r':0.08},
			{'over':10,'upto':12,'b':4,'h':4,'t1':2.5,'t2':1.8,'r':0.08},
			{'over':12,'upto':17,'b':5,'h':5,'t1':3,'t2':2.3,'r':0.16},
			{'over':17,'upto':22,'b':6,'h':6,'t1':3.5,'t2':2.8,'r':0.16},
			{'over':22,'upto':30,'b':8,'h':7,'t1':4,'t2':3.3,'r':0.16},
			{'over':30,'upto':38,'b':10,'h':8,'t1':5,'t2':3.3,'r':0.25},
			{'over':38,'upto':44,'b':12,'h':8,'t1':5,'t2':3.3,'r':0.25},
			{'over':44,'upto':50,'b':14,'h':9,'t1':5.5,'t2':3.8,'r':0.25},
			{'over':50,'upto':58,'b':16,'h':10,'t1':6,'t2':4.3,'r':0.25},
			{'over':58,'upto':65,'b':18,'h':11,'t1':7,'t2':4.4,'r':0.25},
			{'over':65,'upto':75,'b':20,'h':12,'t1':7.5,'t2':4.9,'r':0.40},
			{'over':75,'upto':85,'b':22,'h':14,'t1':9,'t2':5.4,'r':0.40},
			{'over':85,'upto':95,'b':25,'h':14,'t1':9,'t2':5.4,'r':0.40},
			{'over':95,'upto':110,'b':28,'h':16,'t1':10,'t2':6.4,'r':0.40},
			{'over':110,'upto':130,'b':32,'h':18,'t1':11,'t2':7.4,'r':0.40},
			{'over':130,'upto':150,'b':36,'h':20,'t1':12,'t2':8.4,'r':0.70},
			{'over':150,'upto':170,'b':40,'h':22,'t1':13,'t2':9.4,'r':0.70},
			{'over':170,'upto':200,'b':45,'h':25,'t1':15,'t2':10.4,'r':0.70},
			{'over':200,'upto':230,'b':50,'h':28,'t1':17,'t2':11.4,'r':0.70}
		# Gear Data
		# pitch - distance between two teeth
		# u     - pitch differential. The radial distance between pitch diameter
		#		  and pulley outer diameter is called pitch differential.
		# h     - Tooth height
		# H     - Belt height
		# r0	- Inner circle radius
		# r1    - Side circle radius that define the side of a tooth
		# rs    - Small circle radius that define the corner of a tooth
		# offset- Offset of the side circle center
		# name  - Gear name
		# group - Type of Gear
		# GT2 Gear Data
		self.gt2 = {'pitch':2.0,
			'u':0.254,
			'h':0.75,
			'H':1.38,
			'r0':0.555,
			'r1':1.0,
			'rs':0.15,
			'offset':0.40,
			'name':'GT2',
			'group':'GT'
		# GT3 Gear Data
		self.gt3 = {'pitch':3.0,
			'u':0.381,
			'h':1.14,
			'H':2.40,
			'r0':0.85,
			'r1':1.52,
			'rs':0.25,
			'offset':0.61,
			'name':'GT3',
			'group':'GT'
		# GT5 Gear Data
		self.gt5 = {'pitch':5.0,
			'u':0.5715,
			'h':1.93,
			'H':3.81,
			'r0':1.44,
			'r1':2.57,
			'rs':0.416,
			'offset':1.03,
			'name':'GT5',
			'group':'GT'
	def circle_intersect_vline(self,x,r):
		y = math.sqrt((r*r) - (x*x))
		return y
	def polar(self, angle, radio, pt):
			Convert from polar coordinates (Theta, radius) to
			cartesian coordinates. The result is added to the
			given vector pt
		p = App.Vector(0,0,0)
		p[0] = pt[0] + (radio * math.cos(math.radians(angle)))
		p[1] = pt[1] + (radio * math.sin(math.radians(angle)))
		return p
	def get_middle_vector(self,v1, v2, m):
			Find the middle vector between two vectors.
		return (v1 + v2).normalize() * m
	def gt_tooth(self, step, data):
			Calculate the coordinates of the GT tooth vertices.
			(the teeth of the gear, not the teeth of the timing belt)
			This calculates the right size of the previous tooth
			and the left side of the next tooth
		up = App.Vector(0,0,1)
		zero = App.Vector(0,0,0)
		r = (data['dr0'] - data['h']) + data['r0']
		c0 = self.polar(step, r, zero)
		cm = self.polar(step, r - data['r0'], zero)
		pt = self.polar(step, data['dr0'],zero)
		ptn = pt.cross(up).normalize()
		ptd = App.Vector(pt).normalize() * -1
		pr = pt + (ptn * data['offset'])
		pl = pt + (ptn * -data['offset'])
		a = data['r1']/2
		b = a * math.sqrt(3)
		cl = pr + (ptn * -b) + (ptd * a)
		cl0 = pr + (ptn * -(data['r1']+data['rs']))
		cl1 = pr + (ptn * -data['r1']) + (ptd * data['rs'])
		ecl = cl0 + (ptd * data['rs'])
		cl2 = ecl + self.get_middle_vector(cl0 - ecl, cl1 - ecl, data['rs'])
		cl3 = pr + self.get_middle_vector(cl - pr, cl1 - pr, data['r1'])
		cr = pl + (ptn * b)  + (ptd * a)
		cr0 = pl + (ptn * (data['r1']+data['rs']))
		cr1 = pl + (ptn * data['r1']) + (ptd * data['rs'])
		ecr = cr0 + (ptd * data['rs'])
		cr2 = ecr + self.get_middle_vector(cr0 - ecr, cr1 - ecr, data['rs'])
		cr3 = pl + self.get_middle_vector(cr - pl, cr1 - pl, data['r1'])
		return [cr0, cr2, cr1, cr1, cr3, cr, cr, cm, cl, cl, cl3, cl1, cl1, cl2, cl0]
	def create_gear(self, doc, data):
			Create the geometry of the gear. Each tooth is a sequence of arcs
			(3 points non coincidental vertices).
		teeth = data['teeth']
		angle = 360.0/teeth
		gear = []
		for idx in range(teeth):
			step = angle * idx
			t = None
			if data['group'] == "GT":
				t = self.gt_tooth(step, data)
			else:
				raise Exception("Invalid group %s" % data['group'])
			if len(gear)>0:
				doc.SketchGear.addGeometry(Part.LineSegment(gear[-1], t[0]))
			gear.extend(t)
			for idx in range(0,len(t)-1,3):
				doc.SketchGear.addGeometry(Part.ArcOfCircle(t[idx], t[idx+1], t[idx+2]))
		doc.SketchGear.addGeometry(Part.LineSegment(gear[-1], gear[0]))
		doc.recompute()
	def create_key(self, d, z):
		y1 = (d - self.t1) + (self.key_h/2)
		y2 = (d + self.t2)
		yb = self.circle_intersect_vline(-self.key_b/2,d)
		pt = self.polar(90.0, yb, App.Vector(0,0,z))
		c1 = self.polar(180, self.key_b/2, pt)
		c4 = self.polar(0, self.key_b, c1)
		pt = self.polar(90.0, y2, App.Vector(0,0,z))
		c2 = self.polar(180, self.key_b/2 ,pt)
		c3 = self.polar(0,self.key_b, c2)
		c5 = self.polar(270, d, App.Vector(0,0,z))
		return [c1,c2,c3,c4,c5]
	def create(self, data):
			Creating the Freecad elements inside a new document
		progress_bar = Base.ProgressIndicator()
		progress_bar.start("Running creating  gear...", 0)
		FreeCAD.newDocument(data['name'])
		doc = FreeCAD.ActiveDocument
		App.activeDocument().addObject('PartDesign::Body','Gear')
		Gui.activeView().setActiveObject('pdbody', App.activeDocument().Gear)
		App.activeDocument().Gear.newObject('Sketcher::SketchObject','SketchGear')
		App.activeDocument().SketchGear.Support = (App.activeDocument().XY_Plane, [''])
		App.activeDocument().SketchGear.MapMode = 'FlatFace'
		App.activeDocument().SketchGear.Placement = App.Placement(
									App.Vector(0.000000,0.000000,0.000000),
									App.Rotation(0.000000,0.000000,0.000000,1.000000))
		App.activeDocument().recompute()
		self.create_gear(doc, data)
		d = float(self.shaft_diameter/2)
		if self.shaft:
			if self.isCircle:
				if self.addKey:
					c = self.create_key(d, 0)
					keyLst = []
					keyLst.append(Part.LineSegment(c[0],c[1]))
					keyLst.append(Part.LineSegment(c[1],c[2]))
					keyLst.append(Part.LineSegment(c[2],c[3]))
					doc.SketchGear.addGeometry(keyLst,False)
					doc.SketchGear.addGeometry(Part.ArcOfCircle(c[3],c[4],c[0]))
				else:
					doc.SketchGear.addGeometry(Part.Circle(App.Vector(0,0,0),
							 App.Vector(0,0,1),
							 d))
			else:
				ProfileLib.RegularPolygon.makeRegularPolygon(
					'SketchGear',6,App.Vector(0.000000,0.000000,0),
					App.Vector(d,0,0),False)
		App.activeDocument().Gear.newObject("PartDesign::Pad","Pad")
		App.activeDocument().Pad.Profile = App.activeDocument().SketchGear
		App.activeDocument().Pad.Profile = doc.SketchGear
		App.activeDocument().Pad.Length = float(self.hgear)
		Gui.activeDocument().hide("SketchGear")
		Gui.activeDocument().resetEdit()
		# Add base to the Gear
		if self.addBase:
			App.activeDocument().Gear.newObject('Sketcher::SketchObject','SketchBase')
			App.activeDocument().SketchBase.Support = (App.activeDocument().XY_Plane, [''])
			App.activeDocument().SketchBase.MapMode = 'FlatFace'
			App.activeDocument().SketchBase.Placement = App.Placement(
			doc.SketchBase.addGeometry(Part.Circle(App.Vector(0,0,-float(self.base_height)),
								 App.Vector(0,0,1),
								 self.base_diameter))
			if self.shaft:
				if self.isCircle:
					if self.addKey:
						c = self.create_key(d, -float(self.base_height))
						keyLst = []
						doc.SketchBase.addGeometry(keyLst,False)
						doc.SketchBase.addGeometry(Part.ArcOfCircle(c[3],c[4],c[0]))
					else:
						doc.SketchBase.addGeometry(Part.Circle(App.Vector(0,0,0),
								 App.Vector(0,0,1),
								 d))
				else:
						'SketchBase',6,App.Vector(0.000000,0.000000,-float(self.base_height)),
						App.Vector(self.shaft_diameter/2,0,0),False)
			App.activeDocument().Gear.newObject("PartDesign::Pad","PadBase")
			App.activeDocument().PadBase.Profile = App.activeDocument().SketchBase
			App.activeDocument().PadBase.Profile = doc.SketchBase
			App.activeDocument().PadBase.Length = float(self.base_height)
			Gui.activeDocument().hide("SketchBase")
		# Add Top to the Gear
		if self.addTop:
			App.activeDocument().Gear.newObject('Sketcher::SketchObject','SketchTop')
			#App.activeDocument().SketchTop.Support = (App.activeDocument().XY_Plane, [''])
			App.activeDocument().SketchTop.MapMode = 'FlatFace'
			App.activeDocument().SketchTop.Placement = App.Placement(
										App.Vector(0.000000,0.000000,float(self.hgear)),
			doc.SketchTop.addGeometry(Part.Circle(App.Vector(0,0,0),
								 App.Vector(0,0,1),
								 self.top_diameter))
			if self.shaft:
				if self.isCircle:
					if self.addKey:
						keyLst = []
						doc.SketchTop.addGeometry(keyLst,False)
						doc.SketchTop.addGeometry(Part.ArcOfCircle(c[3],c[4],c[0]))
					else:
								 App.Vector(0,0,1),
								 d))
				else:
						'SketchTop',6,App.Vector(0.000000,0.000000,0),
			App.activeDocument().Gear.newObject("PartDesign::Pad","PadTop")
			App.activeDocument().PadTop.Profile = App.activeDocument().SketchTop
			App.activeDocument().PadTop.Profile = doc.SketchTop
			App.activeDocument().PadTop.Length = float(self.top_height)
			Gui.activeDocument().hide("SketchTop")
		Gui.SendMsgToActiveView("ViewFit")
		progress_bar.stop()
	def retranslateUi(self, window):
			Setting the UI text
		window.setWindowTitle(_translate("MainWindow", "GT2/GT3/GT5 Gear Creator",
				 None))
		self.createBtn.setText(_translate("MainWindow", "Create", None))
		self.cancelBtn.setText(_translate("MainWindow", "Exit", None))
		self.teethLbl.setText(QtGui.QApplication.translate("MainWindow",
						 "No. of teeth:", None))
		self.heightLbl.setText(QtGui.QApplication.translate("MainWindow",
						 "Height gear:", None))
		self.typeLbl.setText(QtGui.QApplication.translate("MainWindow",
						 "Pick type of gear:", None))
		self.mmLbl.setText(QtGui.QApplication.translate("MainWindow",
						 "mm", None))
		self.mm2Lbl.setText(QtGui.QApplication.translate("MainWindow",
						 "mm", None))
		self.mm3Lbl.setText(QtGui.QApplication.translate("MainWindow",
						 "mm", None))
		self.mm4Lbl.setText(QtGui.QApplication.translate("MainWindow",
						 "mm", None))
		self.mm5Lbl.setText(QtGui.QApplication.translate("MainWindow",
						 "mm", None))
		self.mm6Lbl.setText(QtGui.QApplication.translate("MainWindow",
						 "mm", None))
		self.rangeLbl.setText(QtGui.QApplication.translate("MainWindow",
						 "(5 ~ 360)", None))
		self.checkShaft.setText(QtGui.QApplication.translate("MainWindow",
						 "Add shaft\r\n(Diameter)", None))
		self.radioHex.setText(QtGui.QApplication.translate("MainWindow",
						 "Hexagon", None))
		self.heightBaseLbl.setText(QtGui.QApplication.translate("MainWindow",
						 "H:", None))
		self.radiusBaseLbl.setText(QtGui.QApplication.translate("MainWindow",
						 "D:", None))
		self.heightTopLbl.setText(QtGui.QApplication.translate("MainWindow",
						 "H:", None))
		self.radiusTopLbl.setText(QtGui.QApplication.translate("MainWindow",
						 "D:", None))
		self.checkKeyHub.setText(QtGui.QApplication.translate("MainWindow",
						 "Add key hub", None))
	def update_max_shaft_diameter(self):
		info = None
		type_gear = str(self.gt_type.currentText())
		if type_gear== "GT2":
			info = dict(self.gt2)
		elif type_gear == "GT3":
			info = dict(self.gt3)
		else:
			info = dict(self.gt5)
		self.max_shaft_diameter = ((self.teeth * info['pitch'])/ math.pi)/2
		self.diameter_shaft.setMaximum(self.max_shaft_diameter)
						'Add shaft\r\n(max ' +
						'{0:.2f}'.format(self.max_shaft_diameter) + ' mm)',
						 None))
		self.diameter_base.setValue(self.max_shaft_diameter)
		self.diameter_top.setValue(self.max_shaft_diameter)
	def update_key_hub(self):
		if self.shaft_diameter >= 6:
			found = False
			for idx in range(len(self.metric_keys)):
				k = self.metric_keys[idx]
				if self.shaft_diameter >= k['over'] and self.shaft_diameter < k['upto']:
					self.key_b = k['b']
					self.key_h = k['h']
					self.t1 = k['t1']
					self.t2 = k['t2']
					found = True
						 "Add key hub\r\n(b:%d h:%d)" % (self.key_b,self.key_h), None))
					break
			if not found:
				msg = 'Cound not found a valid key values for shaft radius: %s' % shaft_diameter
				self.errorDialog(msg)
				self.addKey = False
		else:
			self.addKey = False
	# 		UI widgets callbacks
	def on_gt_type_change(self,idx):
		App.Console.PrintMessage("Current index %d selection changed %s\r\n" %
				(idx,self.gt_type.currentText()))
		self.update_max_shaft_diameter()
	def on_num_teeth_changed(self,value):
		App.Console.PrintMessage("%s Number of Teeths\r\n" % value)
		self.teeth = value
	def errorDialog(self,msg):
		diag = QtGui.QMessageBox(QtGui.QMessageBox.Warning, 'Error in macro MessageBox',
								 msg)
		diag.setWindowModality(QtCore.Qt.ApplicationModal)
		diag.exec_()
	def on_create_clicked(self):
		if self.teeth>=5 and self.teeth<=360:
			App.Console.PrintMessage("Creating Gear %s \r\n" % self.gt_type.currentText())
				data = dict(self.gt2)
				data = dict(self.gt3)
			else:
				data = dict(self.gt5)
			data['teeth'] = self.teeth
			data['d'] = (data['teeth'] * data['pitch'])/ math.pi
			data['d0'] = data['d'] - (2 * data['u'])
			data['dr0'] = data['d0']/2
			App.Console.PrintMessage("pitch %s \r\n" % data['pitch'])
			App.Console.PrintMessage("teeth %s \r\n" % data['teeth'])
			App.Console.PrintMessage("u %s \r\n" % data['u'])
			App.Console.PrintMessage("d %s \r\n" % data['d'])
			App.Console.PrintMessage("d0 %s \r\n" % data['d0'])
			App.Console.PrintMessage("dr0 %s \r\n" % data['dr0'])
			self.create(data)
		else:
			msg = 'The number of teeth should be between 5 and 360!'
	def on_cancel_clicked(self):
		App.Console.PrintMessage("Exit Gear Generator\r\n")
		self.window.hide()
	def on_hgearear_valuechanged(self, value):
		App.Console.PrintMessage(str(value)+
									" height gear\r\n")
		self.hgear = value
	def on_radioCircle_clicked(self):
		if self.shaft_diameter >= 6 and self.isCircle:
			self.checkKeyHub.show()
			self.update_key_hub()
	def on_radioHex_clicked(self):
		self.isCircle = False
		self.checkKeyHub.setChecked(False)
	def on_diameter_shaft_valuechanged(self, value):
									" Shaft radius\r\n")
		if value <= self.max_shaft_diameter:
			self.shaft_diameter = value
			if self.base_diameter < self.shaft_diameter:
				self.base_diameter = self.shaft_diameter
			if self.top_diameter < self.shaft_diameter:
				self.top_diameter = self.shaft_diameter
			else:
		else:
			self.shaft_diameter = self.max_shaft_diameter
			msg = 'The shaft radius should be less than: %s' % self.max_shaft_diameter
	def on_height_base_valuechanged(self, value):
									" Height base\r\n")
		self.base_height = value
	def on_diameter_base_valuechanged(self, value):
									" Radius base\r\n")
		self.base_diameter = value
	def on_height_top_valuechanged(self, value):
									" Height top\r\n")
		self.top_height = value
	def on_diameter_top_valuechanged(self, value):
									" Radius top\r\n")
		self.top_diameter = value
	def on_checkShaft_clicked(self):
		self.shaft = not self.shaft
		if self.shaft:
			self.radioCircle.show()
			self.radioHex.show()
			self.diameter_shaft.show()
			self.mm2Lbl.show()
		else:
			self.radioCircle.hide()
			self.radioHex.hide()
			self.diameter_shaft.hide()
			self.mm2Lbl.hide()
	def on_checkKeyHub_clicked(self):
		self.addKey = not self.addKey
		if self.addKey:
	def on_checkBase_clicked(self):
		self.addBase = not self.addBase
		if self.addBase:
			self.height_base.show()
			self.diameter_base.show()
			self.heightBaseLbl.show()
			self.radiusBaseLbl.show()
			self.mm3Lbl.show()
			self.mm4Lbl.show()
		else:
			self.mm3Lbl.hide()
			self.mm4Lbl.hide()
	def on_checkTop_clicked(self):
		self.addTop = not self.addTop
		if self.addTop:
			self.height_top.show()
			self.diameter_top.show()
			self.heightTopLbl.show()
			self.radiusTopLbl.show()
			self.mm5Lbl.show()
			self.mm6Lbl.show()
		else:
			self.mm5Lbl.hide()
			self.mm6Lbl.hide()
# Create and display the main window
MainWindow = QtGui.QMainWindow()
ui = GTWnd(MainWindow)
MainWindow.show()
Screen Shot 2019-04-25 at 9.18.55 PM.png (21.7 KiB) Viewed 3307 times
Screen Shot 2019-04-25 at 9.20.00 PM.png (23.59 KiB) Viewed 3307 times
Screen Shot 2019-04-25 at 9.19.11 PM.png (33.21 KiB) Viewed 3307 times
renatorivo
Re: GT2, GT3 and GT5 Timing Gear Creator
Postby renatorivo » Thu Apr 25, 2019 7:53 am
Hi. Thanks for sharing!
It works well in FreeCAD 0.17
In FreeCAD 0.18 it returns an error and does not create the gear. Am I wrong?
OS: Windows 8.1
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
Locale: Italian/Italy (it_IT)
Jee-Bee
Postby Jee-Bee » Thu Apr 25, 2019 8:03 am
kisolre
Postby kisolre » Thu Apr 25, 2019 8:09 am
Seems Py2/Py3 incompatibility : https://stackoverflow.com/questions/171 ... n-python-3
Since FreeCAD is moving to Py3 probably the macro should be made compatible with Py3.
vocx
Postby vocx » Thu Apr 25, 2019 3:36 pm
Just use range() instead of xrange().
Unless you are iterating over a million elements, there is no point in using xrange() (even in Python 2). This is one of those optimizations that aren't really needed prematurely.
eaguirre
Postby eaguirre » Thu Apr 25, 2019 9:01 pm
My bad I just installed the version 18.1 and here is the new code with the fix (yes xrange does not work in python3)
eaguirre
__version__ = "1.2"
__date__    = "25/04/2019"
import math
import Part
import sys
import time
try:
    def _fromUtf8(s):
        return s
try:
# QT Window Class
		self.shaft = True
		self.shaft_radius = 2.0
		self.hgear = 6.0
		self.base_radius = 6.37
		self.top_radius = 6.37
		self.addTop = False
		self.max_radius_shaft = 100.0
		self.teeth = 20
		self.w = 300.0
		self.h = 320.0
		# UI Definition
		# UI Elements
		self.teethLbl.setGeometry(QtCore.QRect(self.w*0.05, self.h*0.09, 150, 16))
		self.num_teeth.setGeometry(QtCore.QRect(self.w*0.45, self.h*0.09, 100, 22))
		self.rangeLbl.setGeometry(QtCore.QRect(self.w*0.80, self.h*0.09, 150, 16))
		self.heightLbl.setGeometry(QtCore.QRect(self.w*0.05, self.h*0.18, 150, 16))
		self.hgearear.setGeometry(QtCore.QRect(self.w*0.45, self.h*0.18, 100, 22))
		self.mmLbl.setGeometry(QtCore.QRect(self.w*0.80, self.h*0.18, 32, 16))
		# Shaft Information
		self.checkShaft = QtGui.QCheckBox("Shaft hole", self.central_wdgt)
		self.checkShaft.setGeometry(QtCore.QRect(self.w*0.05, self.h*0.27, 200, 25))
		self.radio_shaft = QtGui.QDoubleSpinBox(self.central_wdgt)
		self.radio_shaft.setGeometry(QtCore.QRect(self.w*0.45, self.h*0.27, 100, 22))
		self.radio_shaft.setMinimum(0.01)
		self.radio_shaft.setMaximum(100.0)
		self.radio_shaft.setSingleStep(0.01)
		self.radio_shaft.setValue(self.shaft_radius)
		self.radio_shaft.setObjectName(_fromUtf8("radio_shaft"))
		self.radio_shaft.valueChanged.connect(self.on_radio_shaft_valuechanged)
		self.mm2Lbl.setGeometry(QtCore.QRect(self.w*0.8, self.h*0.27, 32, 16))
		self.radioCircle.move(self.w*0.45, self.h*0.36)
		self.radioHex.move(self.w*0.7, self.h*0.36)
		# Base information
		self.mm3Lbl.hide()
		self.radius_base = QtGui.QDoubleSpinBox(self.central_wdgt)
		self.radius_base.setGeometry(QtCore.QRect(self.w*0.45, self.h*0.54, 100, 22))
		self.radius_base.setMinimum(self.shaft_radius)
		self.radius_base.setMaximum(500.0)
		self.radius_base.setSingleStep(0.5)
		self.radius_base.setValue(self.base_radius)
		self.radius_base.setObjectName(_fromUtf8("radius_base"))
		self.radius_base.valueChanged.connect(self.on_radius_base_valuechanged)
		self.radius_base.hide()
		self.mm4Lbl.hide()
		# Top information
		self.checkTop.move(self.w*0.05, self.h*0.7)
		self.mm5Lbl.hide()
		self.radius_top = QtGui.QDoubleSpinBox(self.central_wdgt)
		self.radius_top.setGeometry(QtCore.QRect(self.w*0.45, self.h*0.72, 100, 22))
		self.radius_top.setMinimum(self.shaft_radius)
		self.radius_top.setMaximum(500.0)
		self.radius_top.setSingleStep(0.5)
		self.radius_top.setValue(self.top_radius)
		self.radius_top.setObjectName(_fromUtf8("radius_top"))
		self.radius_top.valueChanged.connect(self.on_radius_top_valuechanged)
		self.radius_top.hide()
		self.mm6Lbl.hide()
		# Set strings to UI
		# Gear Data
		# h     - Tooth height
		# H     - Belt height
		# name  - Gear name
		# GT2 Gear Data
			'u':0.254,
			'h':0.75,
			'H':1.38,
			'r0':0.555,
			'r1':1.0,
			'rs':0.15,
			'offset':0.40,
			'name':'GT2',
			'group':'GT'
		# GT3 Gear Data
			'u':0.381,
			'h':1.14,
			'H':2.40,
			'r0':0.85,
			'r1':1.52,
			'rs':0.25,
			'offset':0.61,
			'name':'GT3',
			'group':'GT'
		# GT5 Gear Data
			'u':0.5715,
			'h':1.93,
			'H':3.81,
			'r0':1.44,
			'r1':2.57,
			'rs':0.416,
			'offset':1.03,
			'name':'GT5',
			'group':'GT'
			given vector pt
		return p
		a = data['r1']/2
		angle = 360.0/teeth
		gear = []
			step = angle * idx
			t = None
			else:
			if len(gear)>0:
			gear.extend(t)
		doc.recompute()
		if self.shaft:
			if self.isCircle:
							 App.Vector(0,0,1),
							 float(self.shaft_radius)))
			else:
					App.Vector(self.shaft_radius,0,0),False)
		if self.addBase:
								 App.Vector(0,0,1),
								 self.base_radius))
			if self.shaft:
				if self.isCircle:
								 App.Vector(0,0,1),
				else:
						'SketchBase',6,App.Vector(0.000000,0.000000,0),
			#TODO - Investigate how to take the correct edge
			#App.activeDocument().Gear.newObject("PartDesign::Fillet","Fillet")
			#App.activeDocument().Fillet.Base = (App.ActiveDocument.PadBase,["Edge364"])
			#App.ActiveDocument.Fillet.Radius = 0.2
			#App.ActiveDocument.recompute()
		if self.addTop:
			App.activeDocument().SketchTop.Support = (App.ActiveDocument.PadBase,["Face1"])
			doc.SketchTop.addGeometry(Part.Circle(App.Vector(0,0,float(self.hgear)),
								 App.Vector(0,0,1),
								 self.top_radius))
			if self.shaft:
				if self.isCircle:
								 App.Vector(0,0,1),
				else:
						'SketchBase',6,App.Vector(0.000000,0.000000,float(self.hgear)),
			#App.activeDocument().Fillet.Base = (App.ActiveDocument.PadTop,["Edge484"])
		progress_bar.stop()
			Setting the UI text
				 None))
						 "mm", None))
						 "mm", None))
						 "mm", None))
						 "mm", None))
						 "mm", None))
						 "mm", None))
						 "(5 ~ 360)", None))
						 "Add shaft", None))
						 "Hexagon", None))
						 "H:", None))
						 "r:", None))
						 "H:", None))
						 "r:", None))
	def update_max_radius_shaft(self):
		info = None
		else:
		self.max_radius_shaft = ((self.teeth * info['pitch'])/ math.pi)/2
		self.radio_shaft.setMaximum(self.max_radius_shaft)
						'{0:.2f}'.format(self.max_radius_shaft) + ' mm)',
						 None))
		self.radius_base.setValue(self.max_radius_shaft)
		self.radius_top.setValue(self.max_radius_shaft)
		self.update_max_radius_shaft()
		self.teeth = value
								 msg)
		diag.exec_()
			else:
			self.create(data)
		else:
		self.window.hide()
									" height gear\r\n")
		self.hgear = value
	def on_radio_shaft_valuechanged(self, value):
		if value <= self.max_radius_shaft:
			self.shaft_radius = value
			if self.base_radius < self.shaft_radius:
				self.base_radius = self.shaft_radius
			if self.top_radius < self.shaft_radius:
				self.top_radius = self.shaft_radius
		else:
			self.shaft_radius = max_radius
			msg = 'The shaft radius should be less than: %s' % max_radius
									" Height base\r\n")
	def on_radius_base_valuechanged(self, value):
									" Radius base\r\n")
		self.base_radius = value
									" Height top\r\n")
	def on_radius_top_valuechanged(self, value):
									" Radius top\r\n")
		self.top_radius = value
		if self.shaft:
			self.radio_shaft.show()
			self.mm2Lbl.show()
		else:
			self.radio_shaft.hide()
			self.mm2Lbl.hide()
		if self.addBase:
			self.radius_base.show()
			self.mm3Lbl.show()
			self.mm4Lbl.show()
		else:
			self.mm3Lbl.hide()
			self.mm4Lbl.hide()
		if self.addTop:
			self.radius_top.show()
			self.mm5Lbl.show()
			self.mm6Lbl.show()
		else:
			self.mm5Lbl.hide()
			self.mm6Lbl.hide()
MainWindow.show()
-alex-
Postby -alex- » Thu Apr 25, 2019 10:32 pm
Thanks a lot for this job and for sharing. Could you maybe add an option in order to select a single base or two symetric bases? I mean about two shoulders.
Postby Kunda1 » Thu Apr 25, 2019 11:00 pm
Check this out @rus
eaguirre
Postby eaguirre » Fri Apr 26, 2019 1:26 am
Go to top of the page and take the latest version of the code 1.2
I added the top and bottom and you can change the height and size of them.
-alex-
Postby -alex- » Fri Apr 26, 2019 5:03 pm
Thank you so much!
Could it be possible to get an option to select a 2 stages pulley? I could be very useful to modelise 3D printed driven pulley for reducer.
I though about this script: it could be great if it could be possible to select pulley, or gears, by mixing the gear WB features maybe?
I assume it's a hard work...
Anyway, thank you again.
