Error converting from .3ds to .stl using import3DS: "Unknownchunk object"
umardastgir
Re: Error converting from .3ds to .stl using import3DS: "Unknownchunk object"
Postby umardastgir » Tue Apr 30, 2019 4:09 am
Either method doesn't work. Already tried it out. Reason is the same mentioned by NormadC
openBrain
Postby openBrain » Tue Apr 30, 2019 7:10 am
And the 'FreeCADCmd -v' command definitively lacks some verbosity...
I wonder if it's possible to use PySide to call the About box slot that copies the FC info to the clipboard.
sgrogan
Postby sgrogan » Tue Apr 30, 2019 10:52 pm
How about running this from the FreeCAD/bin directory
python -c "import FreeCAD;print(';'+' '.join(FreeCAD.Version()[:3]))"
or
freecadcmd -v
