[Solved]Projection of Wire on Mesh
HakanSeven12
Postby HakanSeven12 » Thu May 09, 2019 9:12 pm
How can I create a parallel projection of a wire on a mesh surface like this?
(Green line is mesh, red one is projected wire and black one is first wire)
Joel_graff
Re: Projection of Wire on Mesh
Postby Joel_graff » Fri May 10, 2019 3:23 am
@microelly2 can probably answer that one.
microelly2 wrote: ping
jbi
Postby jbi » Sat May 11, 2019 8:09 am
maybe a solution would be : Extrude a wire or edge with Part -> convert to mesh via STL -> mesh.intersect(STL)
microelly2
Postby microelly2 » Sat May 11, 2019 2:20 pm
First convert the mesh to a part
than you can apply the makeParallelProjection method to each face and your wire
>>> f=App.ActiveDocument.Box.Shape.Face1
>>> f.makeParallelProjection.__doc__
'Parallel projection of an edge or wire on this shape\nmakeParallelProjection(shape, dir)\n '
>>> f.makePerspectiveProjection.__doc__
'Perspective projection of an edge or wire on this shape\nmakePerspectiveProjection(shape, pnt)\n '
see for more discussion here
https://forum.freecadweb.org/viewtopic.php?t=5360
Site Admin
Postby wmayer » Tue May 14, 2019 1:24 pm
git commit c60658f3f
shape = ...
mesh = ...
projectionDir = App.Vector(...)
import MeshPart
import Part
polylines = MeshPart.projectShapeOnMesh(shape, mesh, projectionDir)
for i in polylines:
    Part.show(Part.makePolygon(i))
HakanSeven12
Postby HakanSeven12 » Tue May 14, 2019 2:42 pm
I will try it when next 0.19_pre build is available :)
HakanSeven12
Postby HakanSeven12 » Sun May 19, 2019 10:15 am
shape = ...
mesh = ...
import MeshPart
import Part
for i in polylines:
I tried it. If all wire points drop on mesh its create projection wires. But if wire points does not drop on mesh its return empty list.
Site Admin
Postby wmayer » Sun May 19, 2019 5:11 pm
HakanSeven12
Postby HakanSeven12 » Sun May 19, 2019 5:30 pm
I will try it in the next windows build
HakanSeven12
Postby HakanSeven12 » Tue May 28, 2019 11:33 am
git commit b17a784e3
I tried. We talked about it but for topic:
Funchtion is creating projection if wire edge down on mesh, but if wire edge lie outside of mesh projection wire dont extend to mesh border.
Like this(Black one is original wire under mesh and red one is projected wire)
