Bounding box for .stl mesh
umardastgir
Post by umardastgir »
I am working on a project to input an .stl mesh and calculate the volume and bounding box using a python script. I believe FreeCAD has a python console that spits out a code for whatever operation someone performs. I turned the bounding box attribute to true and a bounding box appeared with the appropriate dimensions. The following line of code appeared in the console:
FreeCADGui.getDocument("Unnamed").getObject("out").BoundingBox = True
Although this command displays the bounding box, how can I extract the individual dimensions?
Re: Bounding box for .stl mesh
You don't get the BoundingBox from the GUI, use the active document instead, e.g. for a Cube named "Box" I get the BoundingBox with
App.ActiveDocument.Box.Shape.BoundBox
mario52
Post by mario52 »
hi
try Macro_BoundingBox_Tracing
and see Code_snippets#Search_and_data_extraction
objs = FreeCADGui.Selection.getSelection()                                 # select object with getSelection()
if len(objs) >= 1:
    if hasattr(objs[0], "Shape"):
        s = objs[0].Shape
    elif hasattr(objs[0], "Mesh"):      # upgrade with wmayer thanks #http://forum.freecadweb.org/viewtopic.php?f=13&t=22331
        s = objs[0].Mesh
    elif hasattr(objs[0], "Points"):
        s = objs[0].Points
#sel = FreeCADGui.Selection.getSelection()                                 # select object with getSelection()
#boundBox_= sel[0].Shape.BoundBox                                          # BoundBox of the object
boundBox_= s.BoundBox                                          # BoundBox of the object
App.Console.PrintMessage("boundBox_      : "+str(boundBox_)+"\n")
boundBoxLX  = boundBox_.XLength                                           # Length x boundBox rectangle
boundBoxLY  = boundBox_.YLength                                           # Length y boundBox rectangle
boundBoxLZ  = boundBox_.ZLength                                           # Length z boundBox rectangle
boundBoxDiag= boundBox_.DiagonalLength                                    # Diagonal Length boundBox rectangle
App.Console.PrintMessage("boundBoxLX     : "+str(boundBoxLX)+"\n")
App.Console.PrintMessage("boundBoxLY     : "+str(boundBoxLY)+"\n")
App.Console.PrintMessage("boundBoxLZ     : "+str(boundBoxLZ)+"\n")
App.Console.PrintMessage("boundBoxDiag   : "+str(boundBoxDiag)+"\n\n")
mario
umardastgir
Thanks a lot for your response! How do I calculate the volume though?
kisolre
Post by kisolre »
umardastgir wrote: Tue May 21, 2019 4:11 pm Thanks a lot for your response! How do I calculate the volume though?
X*Y*Z ?
Or did you mean the volume of the STL? It should first become a solid I think.
umardastgir
Volume of the part (stl mesh). And I also need the surface area.
I have done the following:
FreeCAD.getDocument("Unnamed").Objects[0].Mesh.Area
FreeCAD.getDocument("Unnamed").Objects[0].Mesh.Volume
And this does give me the area and volume, but is this the right approach?
openBrain
Post by openBrain »
umardastgir wrote: Tue May 21, 2019 5:39 pm Volume of the part (stl mesh). And I also need the surface area.
Seems correct to me. But nothing better than checking to be sure. Just model a 1 m3 cube, export to STL, then reimport and check your macro on it.
schupin
Post by schupin »
I think Mesh.Volume on meshes returns nothing ?
I had to code something by myself to do it on the center of mass macro.
Then, you can use the center of mass macro : https://forum.freecadweb.org/viewtopic. ... 30#p270248
Just select your mesh and press the compute button, it will give you the mass (depending on the density you entered).
If you want the volume, you can :
  • choose en density of 1
  • or export the result in a .csv file (there is button for that). You''ll get the volume in a collumn
