FCCircularText Macro fails
HI,
I've been learning FreeCad and designing all sorts of small parts, I wanted to be able to do a circular engraving in text on one part to personalize it.
I searched and found out about the FCCircularText macro and installed it through the Addon Manager. I followed the tutorial, but every time I try to invoke the macro (macro -> macros -> select in panel -> execute) I get the following error:
: ("(unicode error) 'utf-8' codec can't decode byte 0xb0 in position 1: Invalid start byte", ('C:\Users\...\FCCircularText.FCMacro', 796,51,None))
I get this in both FreeCad .17 and .18 Both on the same machine (the error message in .17 is not exactly the same, but I am assuming that .18 is the relevant case).
Windows 10 on an i5 2 core, 4 thread
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
Other info: 16GB system, plenty of free memory, I tried it from both the part and draft workbenches.
Any ideas appreciated!
Steve
Qt version: 5.6.2
Steve
Re: FCCircularText Macro fails
After addon manager has installed macro via git, it looks like that:
line 795 and pending:
But it should look like that:
Please update with editor and save it
if verPython.major < 3:
self.DS_InclinaisonX.setSuffix(unicode(" �"))
self.DS_InclinaisonY.setSuffix(unicode(" �"))
self.DS_InclinaisonZ.setSuffix(unicode(" �"))
else:
self.DS_InclinaisonX.setSuffix(unicode(" °"))
self.DS_InclinaisonY.setSuffix(unicode(" °"))
self.DS_InclinaisonZ.setSuffix(unicode(" °"))
else:
Awesome! Thanks! That did it!
Steve
Steve
@UR_ cool, btw are you planning to submit a PR to fix this?
hi
i have modified my macro FCCircularText and FCInfo i change the "°" with chr(176)
also :
chr(178) #exposant 2
chr(179) #exposant 3
chr(181) #micro
now the download is good but the problem stay for the other macros contend "éçà... "
mario
also :
chr(181) #micro
mario
- quotelawrence
I have also had a problem with using the circular text app, after becoming familiar with the regular text I tried using the circular to a medallion, same shape but now engraving on a radius pattern the text appears fine everything looks good, no errors no issues, but I then go to Path to write the g-code and the Job will not appear, and in the lower message it states the shape is not valid, though the shape has been valid in other programs could someone possibly make a short tutorial video on the steps, for creating (1) part, (2) entering circular text (3) Path and establishing Job opens and allows the user to continue to set tooling, depth and speeds. the usual videos are so beneficial for my learning experience and I wish to say thanks for your work on Freecad it has been fabulous
hi
thanks for appreciate my macro
i think your problem is with the Stick font and the Path workbench
try with other font for testing, if you do not have error give your file with the Stick font as example and post in Path/CAM forum
mario
mario
Hi Guys,
A little off subject, but how do I get the FC Circular Text Macros Icon on desktop toolbar?
I've downloaded the DeskTop Icon FCCircularTextButtom.png (yes it says buttom and not Button), but when I click Tools, Customize, Macro;
(1), Pixmat. it's not there.
(2), Pixmat, Icon Folder's, + symbol, Desktop (where I saved the .png image). It's Greyed-out and can't choose/select it.
Any ideas?
Dizzwold.
OS: OS X El Capitan (10.11)
Version: 0.18.16146 (Git)
Branch: (HEAD detached at 0.18.4)
Python version: 3.6.7
Qt version: 5.6.2
Any ideas?
Dizzwold.
Qt version: 5.6.2
hi
see here maybe one solution [Gelöst]Anpassung der Werkzeugleisten
or tray copy the image file in other directory and give the new path in the "Choice icon" window and maybe restart FreeCAD
mario
no idea
mario
Hi Mario52,
Where are the other icons stored?
Dizzwold.
Dizzwold.
