I want to get the approximate radius of a BSpline surface. My first thought was unwrapping it. Using the smallest bounding box dimension doesn't work if the flattened face orientation isn't parallel to the coodinate system axis, so one could use the minimum Volume BoundingBox from Mesh.
Is there a better way to aquire the radius?
[SOLVED] Approximate BSpline Surface radius
- BSplines_surface_radius.PNG (10.96 KiB) Viewed 825 times
- rounding_bSpline_surface.brep
- (302.53 KiB) Downloaded 31 times
FreeCAD rookie
Re: Approximate BSpline Surface radius
What about using the inverse of the minimum and maximum curvature value at a given point?
s=App.ActiveDocument.ActiveObject.Shape.Face1.Surface
c=s.uIso(0.1)
Part.show(c.toShape())
c.centerOfCurvature(0.5)
c.curvature(0.5)
circle=Part.Circle()
circle.Center=c.centerOfCurvature(0.5)
circle.Radius=1/c.curvature(0.5)
pnt=s.value(0.1,0.5)
Part.show(Part.Vertex(pnt))
sph=Part.Sphere()
sph.Center=circle.Center
sph.Radius=circle.Radius
Part.show(sph.toShape())
you may also have a look at Caliper of Mnaipulator WB
https://forum.freecadweb.org/viewtopic. ... 54#p257476
- wandererfan
It's about curves, not surfaces, but there might be some hints here: https://forum.freecadweb.org/viewtopic. ... le+bsplinebrst wrote: ↑Fri Jun 14, 2019 9:24 am I want to get the approxiamte radius of a BSpline surface. My first thought was unwrapping it. Using the smallest bounding box dimension doesn't work if the flattened face orientation isn't parallel to the coodinate system axis, so one could use the minimum Volume BoundingBox from Mesh.
In Path workbench a tesselation with arc is performed, because GCodes know only straight lines and arcs. Perhaps you can use something from there.
Thanks Werner! That's exactly what i was looking for. I didn't know about uIso.wmayer wrote: ↑Fri Jun 14, 2019 10:04 am What about using the inverse of the minimum and maximum curvature value at a given point?
s=App.ActiveDocument.ActiveObject.Shape.Face1.Surface c=s.uIso(0.1) Part.show(c.toShape()) c.centerOfCurvature(0.5) c.curvature(0.5) circle=Part.Circle() circle.Center=c.centerOfCurvature(0.5) circle.Radius=1/c.curvature(0.5) pnt=s.value(0.1,0.5) Part.show(Part.Vertex(pnt)) sph=Part.Sphere() sph.Center=circle.Center sph.Radius=circle.Radius Part.show(sph.toShape())
- result.PNG (9.11 KiB) Viewed 683 times
FreeCAD rookie
