At this time the dialog is already working: if you wish to try it, just copy the files of the folder in your macros path and then type
import dialog4
Now, I'd like to move the section so that its CenterOfMass lies in the origin but somehow this code doesn't work in the execute() method:
p = Part.makePolygon([p1,p2,p3,p4,p5,p6,p1])
s = Part.Face(p)
v=s.CenterOfMass.negative()
s.translate(v) # to move the c.o.m. in (0,0,0). Why does it not work?
obj.Shape = s
The strange thing is that if I type each line in python console to a) create the polygon and b) create the face and c) translate the face and finally d) Part.show(s), it DOES work!
Is there a difference in the .execute() method from the Part.show() command that makes the .translate() operation uneffective?
Suggestions are welcome. Thanks in advance.
