app:: property link meaning?
ebrahim raeyat
Postby ebrahim raeyat » Tue Jun 25, 2019 7:18 pm
I develop punch software and convert it to "punch" object. I want to add punch faces to punch object as a property, but i don't know what kind of property i must to use for it. my faces are type of "Part.Face"
this is output error:
AttributeError: Attribute (Name: facess) error: 'type in list must be 'DocumentObject', not Part.Face'
what means this properties ?!! i searched about those, it seems those are magical !!
App::PropertyLink
App::PropertyLinkChild
App::PropertyLinkGlobal
App::PropertyLinkSub
App::PropertyLinkSubChild
App::PropertyLinkSubGlobal
App::PropertyLinkList
App::PropertyLinkListChild
App::PropertyLinkListGlobal
App::PropertyLinkSubList
App::PropertyLinkSubListChild
App::PropertyLinkSubListGlobal
when the program load, i able to add faces to punch object by click on faces property and select them. thanks
ebrahim raeyat
Re: app:: property link meaning?
i can add those by this code, but this way when i want to use them, i must to obtain them by name from the ActiveDocument. i want to know is there an easier way to do this?
faces = []
for f in intersection_faces:
    face = App.ActiveDocument.addObject("Part::Feature", "face")
    face.Shape = f
    faces.append(face.Name)
punch.faces = faces
when i want to use them:
for face_name in obj.faces:
    f = FreeCAD.ActiveDocument.getObject(face_name)
intersection_faces are type of Part.Face
ebrahim raeyat
Postby ebrahim raeyat » Tue Jun 25, 2019 7:20 pm
This is related post:
https://forum.freecadweb.org/viewtopic.php?f=24&t=31813
Chris_G
Postby Chris_G » Tue Jun 25, 2019 8:37 pm
App::PropertyLink
I didn't know there was so many Link properties.
From what I know, if you want your featurepython object to link to subshapes (vertex, edge, face) of other objects, you have the following options :
- App::PropertyLinkSub links to a single subshape of a document object :
featurepython.linkProperty = [AnotherObject, "Face1"]
- App::PropertyLinkSubList links to a list of subshapes :
featurepython.linkProperty = [(AnotherObject1, ("Face1", "Edge3")), (AnotherObject2, ("Face5", ))]
ebrahim raeyat
Postby ebrahim raeyat » Wed Aug 14, 2019 6:11 pm
Excuse me i am late, thank you so much.
Cyril
Postby Cyril » Fri Apr 03, 2020 10:20 am
I know that your post is pretty old but I find the question useful.
PropertyLink is pretty understandable but for subtypes I found an explanation in source code here :
* @brief Defines different scopes for which a link can be valid
* The scopes defined in this enum describe the different possibilities of where a link can point to.
* Local: links are valid only within the same GeoFeatureGroup as the linkowner is in or in none.
* Child: links are valid within the same or any sub GeoFeatureGroup
* Global: all possible links are valid
* Hidden: links are not included in dependency calculation
I blog about HVAC / BIM / Energy : pythoncvc.net. If you like you can follow the RSS feed.
ebrahim raeyat
Postby ebrahim raeyat » Fri Apr 03, 2020 8:05 pm
@Cyril, very thanks.
paullee
Postby paullee » Tue May 12, 2020 6:55 pm
Thanks Chris_G and Cyril.
I drop into App::PropertyLinkGlobal when I have a look at Draft.py _PathArray.
It seem some properties are not in the Scripted Object wiki ?
vocx
Postby vocx » Tue May 12, 2020 7:54 pm
Obviously. There are many outdated pages in the wiki, and scripted objects is one of them.
Personally, I would place the properties in the property page, and link that one where is needed.
In the source code, properties are located in various src/App/Property* files.
#include "Property.h"
#include "PropertyContainer.h"
#include "PropertyUnits.h"
#include "PropertyFile.h"
#include "PropertyLinks.h"
#include "PropertyPythonObject.h"
#include "PropertyExpressionEngine.h"
They are initialized in src/App/Application.cpp.
