FreeCAD python object not being entering execute.
keithsloan52
Post by keithsloan52 »
I have a number of FreeCAD python objects implemented, but with one the execute function does not get entered. I am struggling to see why
as things are very similar in all implementations, so looking for suggestions on how to track the problem down.
yorik
Founder
Re: FreeCAD python object not being entering execute.
Post by yorik »
Most obvious reason would be that the object (the python class) is not properly set as the object's Proxy. Check that the obj.Proxy property actually contains your python class. Usually that is done by setting obj.Proxy = self in the classes __init__.py function
keithsloan52
yorik wrote: Thu Jul 11, 2019 2:47 pm Most obvious reason would be that the object (the python class) is not properly set as the object's Proxy. Check that the obj.Proxy property actually contains your python class. Usually that is done by setting obj.Proxy = self in the classes __init__.py function
Thanks but obj.Proxy = self is already in __init__.py function Any other ideas?
