lattice2, error
bernd
lattice2, error
Postby bernd » Thu Jul 11, 2019 7:23 pm
- start FreeCAD, make a new document, change to lattice2
- click on icon PolarArray --> a polar array is created
- double click on the obj in tree view
- click on ok
- error message ...
  File "/home/hugo/.FreeCAD/Mod/lattice2/lattice2AttachablePlacement.py", line 93, in unsetEdit
    if not (mode == EDIT_ATTACHMENT or (mode == 0 and always_edit_attachment)): raise NotImplementedError()
<class 'NameError'>: name 'always_edit_attachment' is not defined
DeepSOIC wrote: ping
DeepSOIC
Re: lattice2, error
Postby DeepSOIC » Fri Jul 12, 2019 12:50 pm
Acknowledged, https://github.com/DeepSOIC/Lattice2/issues/31
Thanks for reporting.
DeepSOIC
Re: lattice2, error
Postby DeepSOIC » Fri Jul 12, 2019 12:53 pm
Oh, wait. I can't reproduce. Wat tha? I remember it happening to me...
DeepSOIC
Re: lattice2, error
Postby DeepSOIC » Fri Jul 12, 2019 12:55 pm
Looks like it was fixed quite some time ago.
https://github.com/DeepSOIC/Lattice2/co ... a6369cde7c
bernd
Re: lattice2, error
Postby bernd » Fri Jul 12, 2019 4:42 pm
but updated lattice2 by addon manager just before making the post.
DeepSOIC
Re: lattice2, error
Postby DeepSOIC » Fri Jul 12, 2019 5:07 pm
Ha, I forgot about "click on ok" part of your how-to :oops: .
DeepSOIC
Re: lattice2, error
Postby DeepSOIC » Fri Jul 12, 2019 5:11 pm
bernd
Re: lattice2, error
Postby bernd » Fri Jul 12, 2019 6:24 pm
:D
next problem ...
- make a linear latice placement
- change the count of objects
- it will change the count and make the object longer, but the length poperty is still the old one althought the length is munch longer because the step between the objects did not change.
- even a recompute keeps the old length
- or the other way around, just change the length property does not change anything
DeepSOIC
Re: lattice2, error
Postby DeepSOIC » Fri Jul 12, 2019 8:03 pm
the length poperty
I don't have any "Length" property. Did you mean "Span End"?
If you did, it actually doesn't change for a reason. The reason being "Alignment" property. It's mainly there if you want to have an array with a fixed step and fixed number of occurrences to have different alignment on that edge.
bernd
Re: lattice2, error
Postby bernd » Fri Jul 12, 2019 8:40 pm
got it ... Your picture describes it very very well. Justify is what I need.
