https://github.com/FreeCAD/FreeCAD-addons/issues/141
Macros work on FreeCAD 16 , 17 but not on 18
Re: Macros work on FreeCAD 16 , 17 but not on 18
hi Dany welcome
actual version "01.14" upgraded the "2019/05/03"
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
OS: Windows 10 (10.0)
Version: 0.19.17271 (Git)
Hash: 2d8f7ef2b47a335f99036bf328f51da1e6d015d9
Python version: 3.6.8
Qt version: 5.12.1
mario
What's the problem at home the macro work (all version)
Qt version: 5.6.2
Qt version: 5.12.1
mario
Will I be able to still run Python2 macors on FC 0.17,0.16 and the new Python3 Macros on FC0.18 all installed on the same machien?
OK - thanks much. Where can I find and install the "AddonManger" (github?)?
default in your FreeCAD
just open Tools>>Addon manager
Dose NOT WORK
I installed the screw maker 1 2, it was successfuly installed in the new AppData>Roaming>Freecad>Macro but when I tried to execute it I got the following massage:
:(unicode error)'utf-8' codec can't decode byte 0xb0 in position 87: invalid start byte",("C:Useres/דני/AppData/Roaming/FreeCAD/Macro/scre_maker1_2.FCMacro',4846,-1,'"""\n)
Similar errors I get when trying to install and execute other macros.
Still stuck
I think you best can start with a fresh macro / mod folder
rename current marcro folder create a new one and download all needed macros/ workbenches again.
In the end if a macro or wb isn't ported to python3 it don't work...
Guys -
I must be doing something wrong!
I uninstalled FC0.18 and re-installed it from fresh.
Installed macros using Tools>Addon manager:
* crank simul
* screw maker 1_2
* spring
Nothing works.
Can someone tell me what am I missing?
Thnx in advance.
While theoretical such user names should work, it's better to avoid special characters for the username. I guess one day this will work, but this is not tomorrow
Please note that the "asterisk" (*) I put in my post is NOT part of the macro.
Can someone tell me how can I tell if a macro is Python 3 compatible or not?
THNX!!
