Hello everyone,
I have been looking for days for a useful answer in this forum for a while, but I just couldn't manage to get an answer.
I have about 700 fcstd files and my task is simple:
Basically, I have to do this with each of these files:
1. Open the file
2. Go to TechDraw
3. Insert New Default Page
4. Select the current object.
5. Insert multiple linked views of drawable objects
6. Add all secondary projections (preferably in a way that does not let any parts hang out of the page)
7. Export/save this page-view to a pdf/jpg/picture-file.
I wanted a macro, that allows me to open 50 files, perform the above actions for each of these files.
I am a total noob concerning Python, but I am learning. I thought, I could manage to do this on my own, but I need a lot more help than expected.
Can somebody please help me?
Convert fcstd to techdraw, then to pdf
Re: Convert fcstd to techdraw, then to pdf
You should show at least what you have tried.
Whenever you perform an action in FreeCAD, the operations are shown in the Python console. So, normally you would take these actions and copy them to a file. That's the whole point of writing macros.
For example, if I just perform the steps manually of opening the file, opening a TechDraw page, creating a projection, setting the scale, etc. I get the following output. You could do the same, and see a similar output.
The lines that start with # are comments so they don't actually do anything. They just show the actions that are occurring.
If this process is good, then you can call the same macro every time, just changing the name of the .FCstd file with your object.
Python 3.6.8 (default, Aug 20 2019, 17:12:48)
[GCC 8.3.0] on linux
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> Gui.runCommand('Std_ViewStatusBar',1)
>>> Gui.runCommand('Std_ViewStatusBar',0)
>>> Gui.runCommand('Std_Workbench',19)
>>> ### Begin command Std_New
>>> # Gui/CommandDoc.cpp(427)
>>> App.newDocument("Unnamed")
>>> App.setActiveDocument("Unnamed")
>>> App.ActiveDocument=App.getDocument("Unnamed")
>>> Gui.ActiveDocument=Gui.getDocument("Unnamed")
>>> # Gui/CommandDoc.cpp(428)
>>> Gui.activeDocument().activeView().viewDefaultOrientation()
>>> ### End command Std_New
>>> Gui.runCommand('Std_OrthographicCamera',1)
>>> ### Begin command Std_Open
>>> # Gui/Application.cpp(513)
>>> App.closeDocument('Unnamed')
>>> App.setActiveDocument("")
>>> App.ActiveDocument=None
>>> Gui.ActiveDocument=None
>>> # Gui/Application.cpp(520)
>>> import FreeCAD
>>> # Gui/Application.cpp(523)
>>> FreeCAD.open(u"/home/vocx/auto_fusion.FCStd")
>>> App.setActiveDocument("auto_fusion")
>>> App.ActiveDocument=App.getDocument("auto_fusion")
>>> Gui.ActiveDocument=Gui.getDocument("auto_fusion")
>>> ### End command Std_Open
>>> ### Begin command Std_Workbench
>>> # Gui/CommandStd.cpp(99)
>>> Gui.activateWorkbench("TechDrawWorkbench")
>>> ### End command Std_Workbench
>>> ### Begin command TechDraw_NewPageDef
>>> # Mod/TechDraw/Gui/Command.cpp(123)
>>> App.activeDocument().addObject('TechDraw::DrawPage','Page')
>>> # Mod/TechDraw/Gui/Command.cpp(124)
>>> App.activeDocument().addObject('TechDraw::DrawSVGTemplate','Template')
>>> # Mod/TechDraw/Gui/Command.cpp(126)
>>> App.activeDocument().Template.Template = '/opt/freecad-build-vocx/share/Mod/TechDraw/Templates/A4_LandscapeTD.svg'
>>> # Mod/TechDraw/Gui/Command.cpp(127)
>>> App.activeDocument().Page.Template = App.activeDocument().Template
>>> ### End command TechDraw_NewPageDef
>>> Gui.Selection.addSelection('auto_fusion','Body')
>>> ### Begin command TechDraw_ProjGroup
>>> # Mod/TechDraw/Gui/Command.cpp(563)
>>> App.activeDocument().addObject('TechDraw::DrawProjGroup','ProjGroup')
>>> # Mod/TechDraw/Gui/Command.cpp(564)
>>> App.activeDocument().Page.addView(App.activeDocument().ProjGroup)
>>> # Mod/TechDraw/Gui/Command.cpp(569)
>>> App.activeDocument().ProjGroup.addProjection('Front')
>>> # Mod/TechDraw/Gui/Command.cpp(584)
>>> App.activeDocument().ProjGroup.Anchor.Direction = FreeCAD.Vector(-0.440,-0.375,0.816)
>>> # Mod/TechDraw/Gui/Command.cpp(586)
>>> App.activeDocument().ProjGroup.Anchor.RotationVector = FreeCAD.Vector(0.649,-0.761,-0.000)
>>> # Mod/TechDraw/Gui/Command.cpp(588)
>>> App.activeDocument().ProjGroup.Anchor.recompute()
>>> ### End command TechDraw_ProjGroup
>>> # Mod/TechDraw/Gui/TaskProjGroup.cpp(474)
>>> Gui.ActiveDocument.resetEdit()
>>> # Gui/CommandDoc.cpp(1299)
>>> App.activeDocument().recompute(None,True,True)
>>> Gui.Selection.clearSelection()
>>> Gui.Selection.addSelection('auto_fusion','Page')
>>> # Gui/propertyeditor/PropertyItem.cpp(484)
>>> FreeCAD.getDocument("auto_fusion").getObject("Page").Scale = 0.5000
>>> Gui.Selection.addSelection('auto_fusion','ProjItem')
- wandererfan
https://github.com/FreeCAD/FreeCAD/blob ... oupTest.py should get you started. It does most of the things on your list.
I'll have to think a bit about how to tell if anything is hanging off the edge of the page.
A macro that makes 50 pages of drawings is going to run for a long time. You might want to consider doing it in smaller groups.
EDIT:
Never mind, I did!
In order to close this thread, I will post my resulting code:
EDIT 2:
I almost forgot to thank you for you help/hints.
Please, be gentle to others when they have questions.
FreeCAD does not capture inputs from the TechDraw view in the python console, and the documentation within the Wiki uses obsolete python syntax.
Never mind, I did!
i = 0
templateFile = App.getResourceDir() + "Mod/TechDraw/Templates/A3_Landscape_ISO7200TD.svg"
for obj_name in App.listDocuments():
i += 1
App.setActiveDocument(obj_name)
obj = FreeCAD.ActiveDocument.Objects[0]
page = FreeCAD.ActiveDocument.addObject('TechDraw::DrawPage','page')
page.Label=obj.Label
template = FreeCAD.ActiveDocument.addObject('TechDraw::DrawSVGTemplate','Template')
template.Template = templateFile
page.Template = template
page.ViewObject.show()
featName = obj.Name
doc = App.ActiveDocument
doc.openTransaction("Create Proj Group")
groupName = 'ProjGroup'
group = FreeCAD.ActiveDocument.addObject('TechDraw::DrawProjGroup', groupName)
rc = page.addView(group)
group.Source = [obj]
frontView = group.addProjection("Front")
anchorDir = FreeCAD.Vector(0.0, 0.0, 1.0);
anchorRot = FreeCAD.Vector(1.0, 0.0, 0.0);
group.Anchor.Direction = anchorDir
group.Anchor.RotationVector = anchorRot
group.Anchor.recompute()
doc.commitTransaction()
#add additional views
leftView = group.addProjection("Left")
topView = group.addProjection("Top")
rightView = group.addProjection("Right")
rearView = group.addProjection("Rear")
BottomView = group.addProjection("Bottom")
FrontBottomLeftView = group.addProjection("FrontBottomLeft")
FrontBottomRightView = group.addProjection("FrontBottomRight")
FrontTopRightView = group.addProjection("FrontTopRight")
FrontTopLeftView = group.addProjection("FrontTopLeft")
#save the PDF
__objs__=[]
__objs__.append(page)
import FreeCADGui
FreeCADGui.export(__objs__,u"C:/Users/user_name/Desktop/target_folder/" + page.Label + "_" + str(i) + ".pdf")
del __objs__
#documentation
Thanks!
It will help me to build batch works macro with TechDraw....
Philippe
Philippe
Would someone from the TD be willing to update the wiki with the above info ?
