[Solved] PySide2.QtNetwork module missing
I have an issue loading my workbench into FreeCAD on Ubuntu 18.04. I am getting this error:
No module named 'PySide2.QtNetwork'
File "<string>", line 83, in Initialize
File "/usr/share/freecad/Mod/Animate/Server.py", line 38, in <module>
import communication as com
File "/usr/share/freecad/Mod/Animate/communication.py", line 41, in <module>
from PySide2.QtNetwork import QTcpServer, QTcpSocket, QAbstractSocket, \
I tried to add PySide2 using python -m pip install PySide2 but it lead into this issue https://forum.freecadweb.org/viewtopic. ... 30#p309808 rendering all workbenches useless.
Any idea how to add just PySide2.QtNetwork so that my workbench would work on Ubuntu? (On windows everything runs 0k)
Thanks
Thanks
Re: PySide2.QtNetwork module missing
And why do you do that?JiriVALASEK wrote: ↑Tue Oct 01, 2019 8:42 pm Hi,
Ubuntu has all this available in repositories. See Install on Unix; add the stable PPA.
Then you can install a bunch of Pyside modules.
aptitude search python3-pyside
i python3-pyside2.qt3dcore - Python bindings for Qt5 3DCore module (Python 3)
i python3-pyside2.qt3dinput - Python bindings for Qt5 3DInput module (Python 3)
i python3-pyside2.qt3dlogic - Python bindings for Qt5 3DLogic module (Python 3)
i python3-pyside2.qt3drender - Python bindings for Qt5 3DRender module (Python 3)
i python3-pyside2.qtcharts - Python bindings for Qt5 Charts module (Python 3)
i python3-pyside2.qtconcurrent - Python bindings for Qt5 Concurrent module (Python 3)
i python3-pyside2.qtcore - Python bindings for Qt5 core module (Python 3)
i python3-pyside2.qtgui - Python bindings for Qt5 Gui module (Python 3)
i python3-pyside2.qthelp - Python bindings for Qt5 Help module (Python 3)
i python3-pyside2.qtlocation - Python bindings for Qt5 Location module (Python 3)
i python3-pyside2.qtmultimedia - Python bindings for Qt5 Multimedia module (Python 3)
i python3-pyside2.qtmultimediawidgets - Python bindings for Qt5 MultimediaWidgets module (Python 3)
i python3-pyside2.qtnetwork - Python bindings for Qt5 Network module (Python 3)
i python3-pyside2.qtopengl - Python bindings for Qt5 OpenGL module (Python 3)
i python3-pyside2.qtpositioning - Python bindings for Qt5 Positioning module (Python 3)
i python3-pyside2.qtprintsupport - Python bindings for Qt5 PrintSupport module (Python 3)
i python3-pyside2.qtqml - Python bindings for Qt5 Qml module (Python 3)
i python3-pyside2.qtquick - Python bindings for Qt5 Quick module (Python 3)
i python3-pyside2.qtquickwidgets - Python bindings for Qt5 QuickWidgets module (Python 3)
i python3-pyside2.qtscript - Python bindings for Qt5 Script module (Python 3)
i python3-pyside2.qtscripttools - Python bindings for Qt5 ScriptTools module (Python 3)
i python3-pyside2.qtsensors - Python bindings for Qt5 Sensors module (Python 3)
i python3-pyside2.qtsql - Python bindings for Qt5 Sql module (Python 3)
i python3-pyside2.qtsvg - Python bindings for Qt5 Svg module (Python 3)
i python3-pyside2.qttest - Python bindings for Qt5 Test module (Python 3)
i python3-pyside2.qttexttospeech - Python bindings for Qt5 TextToSpeech module (Python 3)
i python3-pyside2.qtuitools - Python bindings for Qt5 UiTools module (Python 3)
i python3-pyside2.qtwebchannel - Python bindings for Qt5 WebChannel module (Python 3)
i python3-pyside2.qtwebenginecore - Python bindings for Qt5 WebEngineCore module (Python 3)
i python3-pyside2.qtwebenginewidgets - Python bindings for Qt5 WebEngineWidgets module (Python 3)
i python3-pyside2.qtwebsockets - Python bindings for Qt5 WebSockets module (Python 3)
i python3-pyside2.qtwidgets - Python bindings for Qt5 Widgets module (Python 3)
i python3-pyside2.qtx11extras - Python bindings for Qt5 X11Extras module (Python 3)
i python3-pyside2.qtxml - Python bindings for Qt5 Xml module (Python 3)
i python3-pyside2.qtxmlpatterns - Python bindings for Qt5 XmlPatterns module (Python 3)
sudo apt install python3-pyside2.qtnetwork
I thought that when some python module is missing/incomplete the best way would be to reinstall it through pip, I had no idea that you can install python modules using apt-get.vocx wrote: ↑Tue Oct 01, 2019 9:29 pmAnd why do you do that?JiriVALASEK wrote: ↑Tue Oct 01, 2019 8:42 pm Hi,
This is exactly what I needed. Thanks.vocx wrote: ↑Tue Oct 01, 2019 9:29 pm Presumably what you want is thisCode: Select all
OP, if and when your issue is fixed/answered, please mark the thread topic title [Solved]. Thanks!
That's the whole point of using Ubuntu. It has packages for popular software. What you cannot find in the repositories, that you install by other methods.JiriVALASEK wrote: ↑Wed Oct 02, 2019 5:07 am ...I had no idea that you can install python modules using apt-get.
Re: [Solved] PySide2.QtNetwork module missing
The dependency to `python3-pyside2.qtnetwork` should be added to the FreeCAD package on Ubuntu. Who is actually responsible for it?
Thanks,
Gaël
Thanks,
Gaël
