FreeCAD .FCStd importer for Blender 2.80
Re: FreeCAD .FCStd importer for Blender 2.80
i currently use:
blender
FreeCAD
system python
and the paths in blender addon-preferences:
and as fare as i can tel it works
blender
$ ~/mydata/tools/blender/blender-2.93.1-linux-x64/blender --version
Blender 2.93.1
build date: 2021-06-22
build time: 23:38:50
build commit date: 2021-06-22
build commit time: 05:57
build hash: 1b8d33b18c2f
build platform: Linux
build type: release
build c flags: -Wall -Wcast-align -Werror=implicit-function-declaration -Werror=return-type -Werror=vla -Wstrict-prototypes -Wmissing-prototypes -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wlogical-op -Wundef -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Wformat-signedness -Wrestrict -Wnonnull -Wabsolute-value -Wuninitialized -Wredundant-decls -Wshadow -Wno-error=unused-but-set-variable -Wimplicit-fallthrough=5 -fuse-ld=gold -std=gnu11 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2 -D_GLIBCXX_USE_CXX11_ABI=0
build c++ flags: -Wuninitialized -Wredundant-decls -Wall -Wno-invalid-offsetof -Wno-sign-compare -Wlogical-op -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Werror=return-type -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wundef -Wformat-signedness -Wrestrict -Wno-suggest-override -Wuninitialized -Wundef -Wmissing-declarations -Wimplicit-fallthrough=5 -fuse-ld=gold -std=c++17 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2 -D_GLIBCXX_USE_CXX11_ABI=0
build link flags: -Wl,--version-script='/home/blender/git/blender-v293/blender.git/source/creator/blender.map'
build system: CMake
blender console window:
#~ PYTHON INTERACTIVE CONSOLE 3.9.2 (default, Feb 25 2021, 12:19:39) [GCC 9.3.1 20200408 (Red Hat 9.3.1-2)]
#~ Builtin Modules: bpy, bpy.data, bpy.ops, bpy.props, bpy.types, bpy.context, bpy.utils, bgl, blf, mathutils
#~ Convenience Imports: from mathutils import *; from math import *
#~ Convenience Variables: C = bpy.context, D = bpy.data
OS: Ubuntu 20.04.3 LTS (KDE/plasma)
Version: 0.20.
Branch: unknown
Hash: 582c26ea8b5f9d85957a6cb1bf798839fa2ce94c
Python version: 3.8.10
Qt version: 5.12.8
OCC version: 7.5.2
$ python3 --version
Python 3.8.10
path to FreeCAD lib: /usr/lib/freecad-daily-python3/lib/FreeCAD.so
path to system python modules: /usr/lib/python3/dist-packages/
Actually I surprised why blender and freecad never match in python. I am on windows 10 and never able to export or import
I know this is a necro bump...
Just curious as to the status of this.
Not much activity on the github for it.
Was the Python mismatch issue ever resolver for new Blender versions?
Hey yorik, maybe this could also be a GSoC project?!
it still works fine, i use it all the time, but the python version issue, i'm afraid it's unsolvable...
you cannot import a python module that was compiled with another python version. that's how python works.
the only way to work around this would be to make the two processes independant, to separate them completely and communicate through some sort of socket.. bu. that would be so overkill and bring so many other issues
it's mostly a packaging issue.. we shoud have more packages available of both apps with different python versions. there is the additional difficulty that blender packages python entirely and doesn't rely on the system one. note that for ex if you use a linux distro that has both apps, and use distro-provided packages, you won't have problems.
about a gsoc, why not, but i don't see a possible solution here...
Re: FreeCAD .FCStd importer for Blender 3.1.0
I just tried the current blender official `3.1.0` and FreeCAD release and a (older) daily:
Free-CAD daily 0.20
Free-CAD 0.19
Blender
and both freecad versions are working
i can only test on linux - so do not now if the situation on windows or macos is different...
@yorik great it is working for you
if anyone needs a feature that is not working please leave a issue and let me know - or in best case write a pull request
as i only sometimes use this i only will do new things as i need them... time is flying... and so much things i like to do
if there is a actual need i try my best to help
some of the open issues would need a good rethinking what is really helpful / needed...
some only need some testcases or simple isolation of the phenomena so its easier to fix..
@drmacro feel free suport it!
i just went through the issues and tried to add the correct labels...
i think i have to clean up there a bit - and again - help is welcome
sunny greetings
stefan
Free-CAD daily 0.20
OS: Ubuntu 21.04 (KDE/plasma)
Version: 0.20.
Branch: unknown
Hash: 4acef3f14fe694f28f7935108d36341b8df83a39
Python version: 3.9.5
Qt version: 5.15.2
OCC version: 7.5.2
build in python console:
Python 3.9.5 (default, Nov 18 2021, 16:00:48)
[GCC 10.3.0] on linux
>>> App.Version()[4]
'2022/01/26 04:18:00'
Version: 0.19.
Branch: unknown
Hash: 0d9536ed3e8c7f40197b5606e1b7873625e1d6fe
Qt version: 5.15.2
OCC version: 7.5.2
# build in python console:
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> App.Version()[4]
'2021/07/21 08:10:00'
Blender:
version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash: c77597cd0e15, type: release
build date: 2022-03-09, 00:34:48
platform: 'Linux-5.11.0-50-generic-x86_64-with-glibc2.33'
Python:
version: 3.10.2 (main, Jan 27 2022, 14:00:16) [GCC 9.3.1 20200408 (Red Hat 9.3.1-2)]
sunny greetings
stefan
I have are problem:
OS
blender
freecad
import FreeCAD
File "<blender_console>", line 1, in <module>
ImportError: /opt/blender/3.3/scripts/addons/././libboost_regex.so.1.74.0: undefined symbol: _ZN6icu_706LocaleC1ERKS0_
OS: Gentoo Base System release 2.7 x86_64
Kernel: 4.19.94
Shell: bash 5.0.18
Resolution: 1680x1050
WM: IceWM 3.1.0 (linux-gnu/x86_64)
WM Theme: erizo
Theme: Adwaita-dark [GTK2/3]
Icons: ePapirus [GTK2/3]
Terminal: tilda
CPU: Intel i3 540 (4) @ 3.0GHz [45.0°on]
GPU: AMD ATI Radeon HD 5550/5570/5630/6390/6490/7570
GPU: Intel Core Processor
Memory: 2884MiB / 3619MiB (79%)
GPU Driver: i915
CPU Usage: 8%
Locale: ru_RU.utf8
blender --version
Blender 3.3.1
build date: 2022-10-05
build time: 00:14:35
build commit date: 2022-10-04
build commit time: 18:35
build hash: b292cfe5a936
build type: release
build c flags: -Wall -Werror=implicit-function-declaration -Werror=return-type -Werror=vla -Wstrict-prototypes -Wmissing-prototypes -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wlogical-op -Wundef -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Wformat-signedness -Wrestrict -Wnonnull -Wabsolute-value -Wuninitialized -Wredundant-decls -Wshadow -Wno-error=unused-but-set-variable -Wimplicit-fallthrough=5 -std=gnu11 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2 -D_GLIBCXX_USE_CXX11_ABI=0
build c++ flags: -Wuninitialized -Wredundant-decls -Wall -Wno-invalid-offsetof -Wno-sign-compare -Wlogical-op -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Werror=return-type -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wundef -Wformat-signedness -Wrestrict -Wno-suggest-override -Wuninitialized -Wundef -Wmissing-declarations -Wimplicit-fallthrough=5 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2 -D_GLIBCXX_USE_CXX11_ABI=0
build link flags: -Wl,--version-script='/home/blender/git/blender-v330/blender.git/source/creator/symbols_unix.map'
build system: CMake
FreeCAD 0.20.1 Revision: 29410 (Git)
/opt/freecad/usr/bin/python
Python 3.10.5 | packaged by conda-forge | (main, Jun 14 2022, 07:04:59) [GCC 10.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import FreeCAD
Assembly4 workbench (v0.12.4) loaded
>>> print("FreeCAD version:", FreeCAD.Version())
FreeCAD version: ['0', '20', '1', '29410 (Git)', 'Unknown', '2022/08/10 11:44:09', '(HEAD detached at 0.20.1)', 'f5d13554ecc7a456fb6e970568ae5c74ba727563']
path to FreeCAD lib: /opt/freecad/usr/lib/FreeCAD.so
path to system python modules: /usr/lib/python3.10/site-packages/
