[Solved]Applying SoReorganizeAction on a scenegraph
kwahoo
Postby kwahoo » Thu Oct 03, 2019 9:01 pm
Hi!
Based on https://grey.colorado.edu/coin3d/classS ... ction.html I would like to simplify a scenegraph to get a VBO-friendly one. I tried:
from pivy.coin import SoSeparator
from pivy.coin import SoReorganizeAction
rootScene = SoSeparator()
rootScene.ref()
sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()#get active scenegraph
rootScene.addChild(sg)
sor = SoReorganizeAction
sor.apply(rootScene)
Solved:
sor = SoReorganizeAction()
but got an error:
  File "<stdin>", line 1, in <module>
  File "/usr/lib/python3/dist-packages/pivy/coin.py", line 13292, in apply
    return _coin.SoReorganizeAction_apply(self, *args)
NotImplementedError: Wrong number or type of arguments for overloaded function 'SoReorganizeAction_apply'.
  Possible C/C++ prototypes are:
    SoReorganizeAction::apply(SoNode *)
    SoReorganizeAction::apply(SoPath *)
    SoReorganizeAction::apply(SoPathList const &,SbBool)
    SoReorganizeAction::apply(SoPathList const &)
How can I pass scenegraph to SoReorganizeAction?
SoSeparator inherits SoNode, but then the prototype shouldn't be SoReorganizeAction::apply(SoNode * root) as shown here?
Re: Applying SoReorganizeAction on a scenegraph
Postby wmayer » Fri Oct 04, 2019 8:29 am
I guess this is a pivy bug. There are a few classes of Coin3d which are not properly wrapped with swig. Maybe you can ask looo since he maintains the pivy sources and has fixed several bugs already.
looo
Postby looo » Fri Oct 04, 2019 9:17 am
Not sure if it is really a bug or if this is the normal way how swig works. I guess we need to extend the SoReorganizeAction::apply function to also support other classes which inherits from SoNode.
@kwahoo please create an issue: https://github.com/FreeCAD/pivy/issues
Postby wmayer » Fri Oct 04, 2019 9:39 am
If you create e.g. an SoSearchAction then it also works with pivy to traverse the passed node using the apply() function. Only with SoReorganizeAction it doesn't seem to work.
looo
Postby looo » Fri Oct 04, 2019 10:58 am
I will have a look. The python code for both of the functions looks the same:
class SoAction(object):  # base class of SoSearchAction
    def apply(self, *args) -> "void":
        r"""
        apply(SoAction self, SoNode root)
        apply(SoAction self, SoPath path)
        apply(SoAction self, SoPathList pathlist, SbBool obeysrules=0)
        apply(SoAction self, SoAction beingApplied)
        return _coin.SoAction_apply(self, *args)
class SoReorganizeAction(SoSimplifyAction):
        r"""
        apply(SoReorganizeAction self, SoNode root)
        apply(SoReorganizeAction self, SoPath path)
        apply(SoReorganizeAction self, SoPathList pathlist, SbBool obeysrules=0)
looo
Postby looo » Fri Oct 04, 2019 11:01 am
Btw.: There seems to be a problem with the code snippet. I guess one must call the apply function on the object and not on the class of SoReorganizeAction. So this works for me:
rootScene.ref()
sor = SoReorganizeAction()  # !!!!!
Postby wmayer » Fri Oct 04, 2019 11:15 am
Yes, you're right!
When correcting the code snippet accordingly no error message occurs any more. Sorry for the noise!
kwahoo
Re: [Solved]Applying SoReorganizeAction on a scenegraph
Postby kwahoo » Fri Oct 04, 2019 4:33 pm
Wow, that was fast!
How could I miss that :/ Thank you everyone for your help. Have a nice weekend!
