I wonder why it is not possible possible to use App::PropertyLinkList as a standard list.
object_1.property.append(object_2)
object_1.property.pop()
object_1.property.clear()
Etc…
Apparently when we use a standard list method it affects a copy of the list and not the list stored in the property.
- Is there any reason that we cannot directly modify the list ?
- If not. Would it be easy and desirable to change this behavior
