how to shift a point from surface?
silent_missile
Postby silent_missile » Tue Oct 08, 2019 3:21 pm
hello, I have some problems, please give me some guidance.
here is a free surface like NURBS, and a free curve like B-Spline
they intersect, so there is an intersection point
now I need to shift this intersection point from the surface for some distance to get a new point, the law of the shift is normal to the surface at the intersection point
if I program the NIURBS algorithm, it's too complected, also python is slower than c++, so I hope FreeCAD has some api to do this, finally output the xyz coordinate value of the point
I checked the wiki but can't find the api, please tell me how to do this.
DeepSOIC
Re: how to shift a point from surface?
Postby DeepSOIC » Tue Oct 08, 2019 4:36 pm
1. ubtain u,v values for your intersection point.
This can be in a return value of distToShape method, which you may be using to computer the intersection. If you are doing it somehow differently, you can obtain u,v values with u,v = a_face.Surface.parameter(point_in_3d_as_App_Vector)
2. compute the normal:
n = a_face.Surface.normal(u,v)
3. compute the moved point:
p_moved = point_in_3d_as_App_Vector + n*5.5 #shift away from surface by 5.5 mm
It may be a good idea to normalize the normal vector before that, just in case.
