addEventCallPivy - type of event
Chri1
Postby Chri1 » Thu Oct 10, 2019 9:52 am
Hi
I am able, to make an observer by using addEventCall.
Apparently its better to use addEventCallPivy. Really, why?
I made an "Soevent" and don't know, how to recognize, which event has happened:
With addEventCall I used:
if arg["Type"] == "SoKeyboardEvent":
But with addEventCallPivy?
(The step after this I know:
inp = arg.getEvent().getKey()
if inp == coin.SoKeyboardEvent.ESCAPE:
vocx
Re: addEventCallPivy - type of event
Postby vocx » Thu Oct 10, 2019 6:58 pm
Hi
I'm also trying to figure things out. In some DraftGui function I see something like this.
self.view = Draft.get3DView()
self.callbackMove = self.view.addEventCallbackPivy(coin.SoLocation2Event.getClassTypeId(), self.move)
def move(self, event_cb):
    event = event_cb.getEvent()
    mousepos = event.getPosition().getValue()
    ctrl = event.wasCtrlDown()
    self.point = Gui.Snapper.snap(mousepos, active=ctrl)
It seems the callback passes event_cb to move(), and the information is extracted from this even_cb class.
The Gui.Snapper.snap() is a function that uses the Draft snapper to return a point attached to the Draft grid, if applicable. I guess it's optional, and if you don't need it, you can use self.point = mousepos directly.
See this as well, Pivy_trackers 2D geometry library. It's an attempt to abstract the 2D trackers that are present in particular in DrafrTrackers.py.
Joel_graff
Postby Joel_graff » Fri Oct 11, 2019 9:41 am
There are two ways to add event callbacksm using either addEventCallback() or addEventCallbackPivy(). Either one is fine. Just a note: if you want to ever remove the event callback you've added, you need to save the object reference these functions return and use that (instead of the original callback function itself). This has to do with the way it's implemented in pivy.
The issue in your particular case appears to be testing for the event type. addEventCallback() returns everything in a nice Python dictionary, whereas addEventCallbackPivy() returns what you'd get if you were using coin3d directly in C++.
Example:
def my_keyboard_callback(self, so_event_cb):
    print(so_event_cb.getEvent().getClassTypeId())
def add_event_callback(self):
    Gui.ActiveDocument.ActiveView.addEventCallbackPivy(coin.SoKeyboardEvent().getClassTypeId(), self.my_keyboard_callback)
Note your callback must be part of a class object. Static methods (with no self parameter), so far as I know, will not work.
Refer to the https://grey.colorado.edu/coin3d/classS ... Event.html for more information on what to do with the event returned by getEvent(), if you haven't already.
looo
Postby looo » Fri Oct 11, 2019 10:23 am
hmm, I don't think there is such a limitation. At least if you use a coin.SoEvenCallback node:
from pivy import coin
sg = Gui.ActiveDocument.ActiveView.getSceneGraph()
class test_class(object):
    @staticmethod
    def test1(*args):
        print("this is a static-function")
        print([arg for arg in args])
    @classmethod
    def test2(*args):
        print("this is a class-function")
    def test3(*args):
        print("this is a object-fuction")
    def __init__(self, sg):
        self.cb_node = coin.SoEventCallback()
        sg += self.cb_node
        self.cb1 = self.cb_node.addEventCallback(coin.SoLocation2Event.getClassTypeId(), test_class.test1, "extra arg")
        self.cb2 = self.cb_node.addEventCallback(coin.SoLocation2Event.getClassTypeId(), test_class.test2, "extra arg")
        self.cb3 = self.cb_node.addEventCallback(coin.SoLocation2Event.getClassTypeId(), self.test3, "extra arg")
test_obj = test_class(sg)
results in:
['extra arg', <pivy.coin.SoEventCallback; proxy of <Swig Object of type 'SoEventCallback *' at 0x7f3ad1db5360> >]
[<class '__main__.test_class'>, 'extra arg', <pivy.coin.SoEventCallback; proxy of <Swig Object of type 'SoEventCallback *' at 0x7f3ad1db5360> >]
[<__main__.test_class object at 0x7f3ad1dc05c0>, 'extra arg', <pivy.coin.SoEventCallback; proxy of <Swig Object of type 'SoEventCallback *' at 0x7f3ad1db5360> >]
only the passed arguments differ.
Joel_graff
Postby Joel_graff » Fri Oct 11, 2019 1:56 pm
Good to know. I tried it once a couple weeks ago and it failed, but didn’t put a lot of effort into sorting out why. Obviously messed something up...
Chri1
Postby Chri1 » Sat Oct 12, 2019 12:14 pm
Either one is fine.
I'll stay at addEventCallback()
Somehow it seems more handy for me ...
Incidentally, I just noticed that I forgot on "back" in my post (addEventCallback)
Thanks to all of you
