How to run Addon Manager in Headless mode?
sgrogan
Re: How to run Addon Manager in Headless mode?
Postby sgrogan » Thu Oct 24, 2019 9:08 pm
Kunda1 wrote:
Wed Oct 23, 2019 11:12 pm
Could this be used on any of the addons ?
Looks like it would work for updates.
To avaoid a restart maybe some code could be lifted from here https://github.com/FreeCAD/FreeCAD/blob ... CADInit.py?
Great thread btw, I'm learning a lot from vocx :)
Postby Kunda1 » Thu Oct 24, 2019 10:54 pm
likewise :)
BTW, a nice little hack to help me test workbench updates.
git reset --hard HEAD~1
This will drop the most recent git commit so that the repo is trailing master by 1 commit and therefore requires an update.
sgrogan
Postby sgrogan » Thu Oct 24, 2019 11:25 pm
gitpython is pretty cool
repo.git.reset('--hard','origin/master~1')
vocx
Postby vocx » Fri Oct 25, 2019 12:36 am
I mean, as long as the external workbenches and macros are collected in Git repositories it sounds like the Addon Manager should basically wrap around the gitpython functions. However, it seems that GitPython is entirely optional. I wonder if it makes sense to not use gitpython. It seems using this module would greatly simplify this headless mode that Kunda tries to implement. Of course, it's one more dependency, but, well, perhaps it's an important and basic one that it just makes sense to use it.
sgrogan
Postby sgrogan » Fri Oct 25, 2019 12:53 am
You're exactly correct. Now gitpython is the default with .zip fall back. The fall back was because of Windows and problems with py2. With py3 this is no longer an issue and the .7z, .AppImage, and .dmg's support gitpython for py3.
Your instincts are correct though. I think the BIM and Parts Library addons both need gitpython, I'm not sure how well the .zip fall back works.
Now gitpython is not a hard dependency so maybe it should be wrapped in a try/except block.
@vocx, TIA for the education on this matter.
Postby Kunda1 » Fri Oct 25, 2019 3:39 am
painfully slow, but it's happening
script can now auto-update all addons at the moment
pdbpp's prettyprint function is awesome.
Postby Kunda1 » Fri Oct 25, 2019 11:46 am
Noticed a bug a while ago in the Addon Manager and am trying to get around it using the headless script.
Postby Kunda1 » Fri Oct 25, 2019 12:45 pm
Milestone: This revision when run will auto-update all addons from the CLI
To test:
wget https://gist.githubusercontent.com/luzpaz/f3bfaaef8aaec9c66b96e0941f6ed7a5/raw/185540a1d1cdb55955c6cb84346c76a7598de6e5/AddonMangerHeadless.py
freecadcmd -c AddonManagerHeadless.py
Postby Kunda1 » Fri Oct 25, 2019 8:57 pm
Adopting yorik's code makes it seem like it's a simple thing. 2 things I'm learning:
1) I appreciate everyone who codes and contributes to FC
2) programming is quite a mental exercise, especially when learning it.
Was able to install addons which is cool...
next is to remove them.
The code quality is going to be crappy, y'all. Just sayin'
Postby Kunda1 » Fri Oct 25, 2019 9:01 pm
BTW, Since it's a gist, feel free to 'fork it and work it' if you want :)
