macro for hiding geometric constraints
aster94
Postby aster94 » Sat Oct 26, 2019 4:30 pm
hello,
I wrote a macro to hide all geometric constraints and show only measures (i.e. angle, radius, diameter, distances)
here a video showing its use: https://streamable.com/jhtdu
import FreeCAD
__title__="Macro_HideGeometryConstraints"
__author__ = "aster94"
__url__     = "https://github.com/aster94"
__version__ = "0.0.1"
__date__    = "26/10/2019"
try:
	sketch_name = Gui.ActiveDocument.getInEdit().Object.Name
	valid_constraints = ['Diameter', 'Radius', 'Angle', 'Distance']
	constraints = list(Gui.ActiveDocument.getInEdit().Object.Constraints) # Get all the constraints of the active sketch
	for cnt, constraint in enumerate(constraints):
		#print(constraint)
		if any([c in str(constraint) for c in valid_constraints]):
			#print(constraint)
			App.ActiveDocument.getObject(sketch_name).setVirtualSpace(cnt, True) # Show
		else:
			App.ActiveDocument.getObject(sketch_name).setVirtualSpace(cnt, False) # Hide
except Exception:
    None
and to show again all constraints
import FreeCAD
__title__="Macro_ShowAllConstraints"
try:
	constraint_count = App.ActiveDocument.Sketch001.ConstraintCount
	for c in range(constraint_count):
		App.ActiveDocument.getObject(sketch_name).setVirtualSpace(c, True)
except Exception:
    None
Any suggestion is well accepted since it is my very first script in FreeCAD
I would like to submit to https://github.com/FreeCAD/FreeCAD-macros what do you think about?
openBrain
Re: macro for hiding geometric constraints
Postby openBrain » Sat Oct 26, 2019 5:31 pm
As a blocking point, your 2nd macro will only work on Sketch001, which isn't convenient. :)
openBrain
Postby openBrain » Sat Oct 26, 2019 6:27 pm
Here a feedback where I commented changes. ;)
try:
	sk = Gui.ActiveDocument.getInEdit().Object # instanciate sketch itself for future use
	constraints = list(sk.Constraints) # to be checked but I think '.Constraints' already returns a list
			sk.setVirtualSpace(cnt, True) # Show
		else:
			sk.setVirtualSpace(cnt, False) # Hide
except Exception:
    pass # instead of 'None'
import FreeCAD
try:
	constraint_count = sk.ConstraintCount
		sk.setVirtualSpace(c, True)
except Exception:
    pass
I didn't check this code, but you should be able to see the idea. ;)
aster94
Postby aster94 » Sun Oct 27, 2019 1:11 pm
ahahahah yep, I missed it :lol:
here the updated versions
import FreeCAD
try:
	constraints = sk.Constraints # Get all the constraints of the active sketch
		#print(constraint)
		if any([item in str(constraint) for item in valid_constraints]):
		else:
except Exception:
    pass
import FreeCAD
try:
except Exception:
    pass
aster94
Postby aster94 » Sun Nov 10, 2019 6:12 pm
may i upload these to github?
Postby Kunda1 » Sun Nov 10, 2019 7:14 pm
yes please
upload them to https://github.com/FreeCAD/FreeCAD-macros/
openBrain
Postby openBrain » Sun Nov 10, 2019 7:20 pm
Well read the Readme there so your header is compliant with requirements. ;)
Also the Wiki page shall exists. Better also if you propose icons with your macros.
IMO it would be good that both macros are grouped in only one. ;)
aster94
Postby aster94 » Sun Nov 10, 2019 8:47 pm
mmmmm the only way i can think about to make the two macro in only one would be to have a flag variable outside the macro, but i guess that this is not possible, is it?
Also i wasn't able to find a way from python to know if a constrain is visible or not. I mean that there are cases in which
would make a constraint not visible. Is it possible to check if a constraint is visible or not?
openBrain
Postby openBrain » Sun Nov 10, 2019 8:59 pm
isHidden=sk.getVirtualSpace(cnt)
To get both in one macro, I'd implement a logic like : if at least one constraint hidden then show all else hide geometric constraints. ;)
aster94
Postby aster94 » Sun Nov 10, 2019 9:27 pm
Great, far away easier, i was trying to access the same with
sk.Constraints[1].IsInVirtualSpace
but it wasn't working for some strange reason :?
During the next days I will send an updated version of the macro
EDIT 1:Anyway your isHidden unfortunatelly won't work in 100% of cases, if this button (https://www.freecadweb.org/wiki/Sketche ... rtualSpace) is pressed the result would be anyway true. Do you see any work around?
EDIT 2: from the wiki it says "move some constraints to virtual space two" then i guess (i am not checking the code) that the python function getVirtualSpace can return only boolean values and 2 is a valid true. Would it be possible to make this function return an int?
