[Bug] FreeCAD headless running 'modules freecad' crashes console
Postby Kunda1 » Wed Oct 30, 2019 5:55 pm
Using FreeCAD_0.19-18614-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
How to recreate:
1. freecadcmd -c
2. help()
3. modules freecad
Example:
$ freecadcmd -c
[FreeCAD Console mode <Use Ctrl-D (i.e. EOF) to exit.>]
>>> help()
Welcome to Python 3.7's help utility!
If this is your first time using Python, you should definitely check out
the tutorial on the Internet at https://docs.python.org/3.7/tutorial/.
Enter the name of any module, keyword, or topic to get help on writing
Python programs and using Python modules.  To quit this help utility and
return to the interpreter, just type "quit".
To get a list of available modules, keywords, symbols, or topics, type
"modules", "keywords", "symbols", or "topics".  Each module also comes
with a one-line summary of what it does; to list the modules whose name
or summary contain a given string such as "spam", type "modules spam".
help> modules freecad
Here is a list of modules whose name or summary contains 'freecad'.
If there are any, enter a module name to get more help.
FreeCAD - The functions in the FreeCAD module allow working with documents.
__FreeCADBase__ - The Base module contains the classes for the geometric basics
InitGui - TabBar widget for FreeCAD.
TabBar_Gui - TabBar widget for FreeCAD.
BimCommands - This module contains FreeCAD commands for the BIM workbench
BimCurtainWall - This module contains FreeCAD commands for the BIM workbench
BimDiff - This module contains FreeCAD commands for the BIM workbench
BimIfcElements - This module contains FreeCAD commands for the BIM workbench
BimIfcProperties - This module contains FreeCAD commands for the BIM workbench
BimIfcQuantities - This module contains FreeCAD commands for the BIM workbench
BimLayers - Layers manager for FreeCAD
BimMaterial - This module contains FreeCAD commands for the BIM workbench
BimNudge - This module contains FreeCAD commands for the BIM workbench
BimPreflight - This module contains FreeCAD commands for the BIM workbench
BimProject - This module contains FreeCAD commands for the BIM workbench
BimReextrude - This module contains FreeCAD commands for the BIM workbench
BimSetup - This module contains FreeCAD commands for the BIM workbench
BimUnclone - This module contains FreeCAD commands for the BIM workbench
BimViews - This module contains FreeCAD commands for the BIM workbench
BimWelcome - This module contains FreeCAD commands for the BIM workbench.
BimWindows - This module contains FreeCAD commands for the BIM workbench
IconThemesGui - Icon themes for FreeCAD.
IconThemesLegacy - Icon themes for FreeCAD.
NavigationIndicatorGui - Navigation indicator for FreeCAD.
PersistentToolbars - Persistent toolbars for FreeCAD.
PersistentToolbarsGui - Persistent toolbars for FreeCAD.
  File "<stdin>", line 1, in <module>
  File "/home/beast/bin/squashfs-root/usr/lib/python3.7/_sitebuiltins.py", line 103, in __call__
    return pydoc.help(*args, **kwds)
  File "/home/beast/bin/squashfs-root/usr/lib/python3.7/pydoc.py", line 1896, in __call__
    self.interact()
  File "/home/beast/bin/squashfs-root/usr/lib/python3.7/pydoc.py", line 1923, in interact
    self.help(request)
  File "/home/beast/bin/squashfs-root/usr/lib/python3.7/pydoc.py", line 1942, in help
    self.listmodules(request.split()[1])
  File "/home/beast/bin/squashfs-root/usr/lib/python3.7/pydoc.py", line 2078, in listmodules
    apropos(key)
  File "/home/beast/bin/squashfs-root/usr/lib/python3.7/pydoc.py", line 2172, in apropos
    ModuleScanner().run(callback, key, onerror=onerror)
  File "/home/beast/bin/squashfs-root/usr/lib/python3.7/pydoc.py", line 2133, in run
    loader = spec.loader
AttributeError: 'NoneType' object has no attribute 'loader'
Re: [Bug] FreeCAD headless running 'modules freecad' crashes console
Postby Kunda1 » Wed Oct 30, 2019 6:25 pm
It worked on 0.18.4
3.7.4 (default, Oct 4 2019, 06:57:26)
[GCC 9.2.0]
$ freecadcmd --version
FreeCAD 0.18 Revision: 16145 (Git)
$ freecadcmd -c
FreeCAD 0.18, Libs: 0.18R16145 (Git)
(c) Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
>>> import sys
>>> print(sys.version)
[GCC 9.2.0]
>>> help()
importJSON - FreeCAD JSON exporter
importWebGL - FreeCAD webgl exporter
FreeCAD
FreeCADGui
libFreeCADApp
libFreeCADBase
libFreeCADGui
freecad
/home/foo/.local/lib/python3.7/site-packages/astroid/interpreter/_import/spec.py:12: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module's documentation for alternative uses
/home/foo/.local/lib/python3.7/site-packages/isort/pie_slice.py:362: DeprecationWarning: Using or importing the ABCs from 'collections' instead of from 'collections.abc' is deprecated, and in 3.8 it will stop working
/usr/lib/python3.7/site-packages/IPython/kernel/__init__.py:13: ShimWarning: The `IPython.kernel` package has been deprecated since IPython 4.0.You should import from ipykernel or jupyter_client instead.
/usr/lib/python3.7/pkgutil.py:92: RemovedInDjango30Warning: The django.db.backends.postgresql_psycopg2 module is deprecated in favor of django.db.backends.postgresql.
/usr/lib/python3.7/site-packages/iptc/util.py:39: ResourceWarning: unclosed file <_io.BufferedReader name=16>
/usr/lib/python3.7/site-packages/iptc/util.py:44: ResourceWarning: unclosed file <_io.TextIOWrapper name='/proc/sys/kernel/modprobe' mode='r' encoding='UTF-8'>
/usr/lib/python3.7/site-packages/kamene/data.py:62: ResourceWarning: unclosed file <_io.TextIOWrapper name='/etc/protocols' mode='r' encoding='UTF-8'>
/usr/lib/python3.7/site-packages/menulibre/MenulibreTreeview.py:36: PyGIDeprecationWarning: GObject.SIGNAL_RUN_LAST is deprecated; use GObject.SignalFlags.RUN_LAST instead
/usr/lib/python3.7/site-packages/menulibre/MenulibreTreeview.py:38: PyGIDeprecationWarning: GObject.SIGNAL_RUN_LAST is deprecated; use GObject.SignalFlags.RUN_LAST instead
/usr/lib/python3.7/site-packages/menulibre/MenulibreHistory.py:29: PyGIDeprecationWarning: GObject.SIGNAL_RUN_LAST is deprecated; use GObject.SignalFlags.RUN_LAST instead
/usr/lib/python3.7/site-packages/menulibre/MenulibreHistory.py:31: PyGIDeprecationWarning: GObject.SIGNAL_RUN_LAST is deprecated; use GObject.SignalFlags.RUN_LAST instead
/usr/lib/python3.7/site-packages/menulibre/MenulibreHistory.py:33: PyGIDeprecationWarning: GObject.SIGNAL_RUN_LAST is deprecated; use GObject.SignalFlags.RUN_LAST instead
/usr/lib/python3.7/site-packages/menulibre/MenulibreApplication.py:209: PyGIDeprecationWarning: GObject.SIGNAL_RUN_FIRST is deprecated; use GObject.SignalFlags.RUN_FIRST instead
/usr/lib/python3.7/site-packages/menulibre/MenulibreApplication.py:211: PyGIDeprecationWarning: GObject.SIGNAL_RUN_FIRST is deprecated; use GObject.SignalFlags.RUN_FIRST instead
/usr/lib/python3.7/site-packages/menulibre/MenulibreApplication.py:213: PyGIDeprecationWarning: GObject.SIGNAL_RUN_FIRST is deprecated; use GObject.SignalFlags.RUN_FIRST instead
/usr/lib/python3.7/site-packages/micawber/contrib/mcdjango/__init__.py:1: DeprecationWarning: Using or importing the ABCs from 'collections' instead of from 'collections.abc' is deprecated, and in 3.8 it will stop working
/usr/lib/python3.7/site-packages/gi/types.py:220: Warning: cannot register existing type 'Window'
/home/foo/.local/lib/python3.7/site-packages/logbook/more.py:41: DeprecationWarning: Flags not at the start of the expression '(\\s+)(?u)'
[2019-10-30T17:56:51Z] WARNING: DependencyWarning: /home/foo/.FreeCAD/Mod/WebTools/requests/packages/urllib3/contrib/socks.py:37: SOCKS support in urllib3 requires the installation of optional dependencies: specifically, PySocks.  For more information, see https://urllib3.readthedocs.io/en/latest/contrib.html#socks-proxies
[2019-10-30T17:56:51Z] WARNING: DeprecationWarning: /usr/lib/python3.7/site-packages/pipenv/vendor/cerberus/validator.py:14: Using or importing the ABCs from 'collections' instead of from 'collections.abc' is deprecated, and in 3.8 it will stop working
[2019-10-30T17:56:52Z] WARNING: RequestsDependencyWarning: /usr/lib/python3.7/site-packages/pipenv/vendor/requests/__init__.py:91: urllib3 (1.25.6) or chardet (3.0.4) doesn't match a supported version!
[2019-10-30T17:56:53Z] WARNING: DeprecationWarning: /usr/lib/python3.7/site-packages/qgis/core/__init__.py:121: invalid escape sequence \s
[2019-10-30T17:56:53Z] WARNING: DeprecationWarning: /usr/lib/python3.7/site-packages/qgis/core/additions/qgsfunction.py:167: invalid escape sequence \*
[2019-10-30T17:56:59Z] WARNING: wxPyDeprecationWarning: /usr/lib/python3.7/site-packages/wx/lib/pubsub/__init__.py:25: wx.lib.pubsub has been deprecated, plese migrate your code to use pypubsub, available on PyPI.
Postby Kunda1 » Thu Oct 31, 2019 3:37 pm
Can anyone confirm ?
Postby chrisb » Thu Oct 31, 2019 3:44 pm
Does it work without any Addon installed?
Postby Kunda1 » Thu Oct 31, 2019 5:39 pm
Removed all addons, and crash still occurs
Postby Kunda1 » Fri Nov 01, 2019 1:40 pm
Anyone able to reproduce?
Postby chrisb » Fri Nov 01, 2019 2:17 pm
No crash here.
OS: macOS High Sierra (10.13)
Version: 0.19.18589 (Git)
Hash: 3500451a040989d00693eab85b2a7c13ce4dad67
Python version: 3.7.3
Qt version: 5.12.5
Locale: English/Germany (en_DE)
sgrogan
Postby sgrogan » Fri Nov 01, 2019 4:47 pm
No problem here:
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18644 (Git)
Hash: 481870be2b48ef95b59acf1440b069d42b6fad23
Qt version: 5.12.1
Python version: 3.6.7
Qt version: 5.12.1
Site Admin
Postby wmayer » Sat Nov 02, 2019 10:41 am
No problem here either.
Postby Kunda1 » Sat Nov 02, 2019 1:21 pm
Thanks everyone. Has anyone tried to reproduce it on an AppImage ?
