Get 3rd party dependency version info via python?
Postby Kunda1 » Thu Oct 31, 2019 5:59 pm
How can I get the version info of the following depedencies via python?
OCC
Netgen
Vtk
graphviz
expat
coin
pivy
boost
netcdf
hdf5
eigen
xerces-c
ccx
gmsh
freetype
ifcopenshell
ifcplusplus
opencamlib
pysolar
orocos-kdl
pcl-pointcloud
paraview
libredwg
Re: Get 3rd party dependency version info via python?
Postby Kunda1 » Sun Nov 03, 2019 12:09 pm
bump
Syres
Postby Syres » Sun Nov 03, 2019 1:00 pm
bump
The best I can do @Kunda1 is point you in the direction of the CfdOF Check Dependencies section of CfdTools.py (so any thanks need to be sent in @oliveroxtoby direction), https://github.com/jaheyns/CfdOF/blob/m ... ls.py#L653
You'll notice down at line 801 Oliver has done the Paraview check but it would appear with all these external binaries it can be a bit messy being as polite as possible.
Hope that's of use.
Postby Kunda1 » Sun Nov 03, 2019 2:43 pm
The best I can do @Kunda1...
Thanks.
Looks like they're using the OpenFoam environment to primarily check the version of those dependencies. Nonetheless, this is useful.
Cheers!
sgrogan
Postby sgrogan » Tue Nov 05, 2019 11:26 pm
There is ThirdPartyLibraries.html in the doc directory.
There is some extended version info there.
In the Gui; Help > About FreeCAD > Libraries Tab
"fight the good fight"
Postby Kunda1 » Wed Nov 06, 2019 4:37 pm
https://github.com/FreeCAD/FreeCAD/blob ... aries.html
looks like it's a static page. Doesn't pull version info, AFAICT.
sgrogan
Postby sgrogan » Wed Nov 06, 2019 10:16 pm
I guess it doesn't come from the html, but the Library tab in the GUI gives some additional version info over the std_about (boost and zlib) don't know where it comes from.
Also remember this https://forum.freecadweb.org/viewtopic. ... 76#p187448
The script needs to be ported to PY3/QT5 and then get the clipboard into a list or something.
Postby Kunda1 » Fri Nov 08, 2019 9:03 pm
Thanks!
looo
Postby looo » Fri Nov 08, 2019 10:08 pm
Some of the requested:
>>> import pivy
>>> import vtk
>>> import ifcopenshell
>>> import ocl
>>> pivy.__version__
'0.6.5a3'
>>> vtk.vtkVersion.GetVTKSourceVersion().split(" ")[-1]
'8.2.0'
>>> ifcopenshell.version
0.6.0b0
>>> ocl.version()
'2019.07'
calculix, gmsh:
>>> import subprocess as sub
>>> sub.run(["ccx", "-v"], stdout=sub.PIPE).stdout.decode("utf8").strip().split(" ")[-1]
'2.15'
>>> sub.run(["gmsh", "--version"], stderr=sub.PIPE).stderr.decode("utf8").strip()
'4.4.1'
Postby Kunda1 » Sat Nov 09, 2019 5:13 pm
