how to get a point on a curve with specific ratio or distance?
silent_missile
Postby silent_missile » Wed Nov 06, 2019 3:29 am
Hello, I have some requirement to use FreeCAD, please help
now I need to get a point on a Part.BSpline
What I know is only the distance ratio from one end, I use help(Part.Curve) to read the comment, but I can't find any function can get a point with specific length ratio.
u parameter is an alternative, but as we all know,in NURBS, points distribution by length doesn't corresponding to the u distribution, there is much variation
I find help(Part.Edge) has a function: paramval = getParameterByLength(pos, [tolerance = 1e-7])
But Part.Curve is different from Part.Edge
actually I'm really confused the difference among Part.Curve, Part.Edge, Part.Line, can any body clarify it?
By the way, is there any way to get a curve from a BSplineSurface with specific u or v?
Chris_G
Re: how to get a point on a curve with specific ratio or distance?
Postby Chris_G » Wed Nov 06, 2019 9:11 am
Part.BSplineCurve has parameterAtDistance.
help(Part.BSplineCurve.parameterAtDistance)
There are 2 different groups of entities : geometry and topology.
Geometry entities are mathematical objects, like vectors, curves (bspline, bezier, circle, ellipse, line, etc) and surfaces (cone, cylinder, plane, bspline surface, etc)
They are invisible objects.
Part.Curve is the parent class of all the curves.
On the other hand, what you see in the 3D view are topology objects, like vertexes, edges, faces.
Vertexes, edges, faces are created on top of geometry objects.
The parent class of the topology objects is Shape.
There are also some aggregation of these 3 base types, like wires, compounds, shells, solids, compsolids.
Depending on your needs, you will work at the geometry level, or the topology level.
geom_object.toShape() is handy for converting a geometry obj to topology.
The other way, to go from topology to geometry, you would do :
my_vector = aVertex.Point
my_curve = anEdge.Curve
my_surface = aFace.Surface
my_U_isocurve = aBSplineSurface.uIso(param)
my_V_isocurve = aBSplineSurface.vIso(param)
