Created Part is InYourFace [solved]
iplayfast
Postby iplayfast » Fri Nov 08, 2019 8:33 pm
Hello all, I'm working on a Cycloidal drive library, and am having a few issues.
1. When the parts are created, it is created very close the the screen (in your face), and you have to zoom out to see it.
2. I'm getting strange errors
cycloidbox.py(130)<class 'TypeError'>: function takes at most 5 arguments (6 given)
generated by
	doc.recompute()
/home/chris/.FreeCAD/Mod/CycloidGearBox/cycloidbox.py(275)<class 'TypeError'>: function takes at most 5 arguments (6 given)
/home/chris/.FreeCAD/Mod/CycloidGearBox/cycloidbox.py(275)<class 'TypeError'>: function takes at most 4 arguments (5 given)
generated by
 Shape = cycloidFun.generateEccentricShaft(H)
        self.Object.Shape = Shape
Line 275 is the self.Object.Shape = Shape line.
Notice that the same assignment gives different argument errors for the one assignment!
Could this have something to do with json encoding?
Code is at https://github.com/iplayfast/CycloidGearBox
Any help is appreciated.
OS: Linux Mint 19.2 (X-Cinnamon/cinnamon)
Version: 0.19.18694 (Git) AppImage
Hash: c3ba04183e016e15410d84bae4d00556d22c7da5
Python version: 3.7.3
Qt version: 5.12.5
iplayfast
Re: Created Part is InYourFace
Postby iplayfast » Fri Nov 08, 2019 8:53 pm
I've solved problem #2 (although I don't know why those particular errors were generated).
So now just need it to not be In My face!
Postby chrisb » Fri Nov 08, 2019 9:53 pm
Have a look at the macro FCCamera (or its code).
iplayfast
Postby iplayfast » Sat Nov 09, 2019 5:34 pm
Thanks, not directly helpful, but it pointed me to what to search for.
I ended up with:
FreeCADGui.SendMsgToActiveView('ViewFit')
DeepSOIC
Re: Created Part is InYourFace [solved]
Postby DeepSOIC » Sat Nov 09, 2019 8:54 pm
This is an interesting problem. I've added a setting in preferences for the default camera zoom not so long ago, I think your freecad version is recent enough to include it. Setting it to the typical sizes of objects you're dealing with a bit of margin with should help a bit. But that doesn't solve the problem when default size of created object isn't anything like your setting.
In Lattice2, I created a rather sophisticated module called "autosize" to drive default sizes and placements of new Lattice2 objects to suit the current camera. I plan on taking that module into FreeCAD, but as I am quite busy with ConstraintSolver now, don't expect it any time soon.
iplayfast
Postby iplayfast » Sat Nov 09, 2019 9:05 pm
ViewFit was the easy straightforward solution.
