[Solved] Shape get back around origin
GlouGlou
Postby GlouGlou » Sat Nov 09, 2019 9:21 pm
I'm learning python, and I'm trying to build a parametric object like a egg.
After moved it on Z axle, and when I change a parameter It's remade around the origin.
How I can avoid that?
Ovoide.py
(1.76 KiB) Downloaded 17 times
openBrain
Re: Shape get back around origin
Postby openBrain » Sat Nov 09, 2019 9:42 pm
Salut GlouGlou,
Very challenging for learning Python. ;)
I only have a very quick look (not easy to understand without any comment in the code), but I saw this line in execute() :
matriz.append(FreeCAD.Vector(x,y,0))
In this line, Z is always set to 0.
Don't know if it's the reason, but the only clue I have for you ATM. ;)
GlouGlou
Postby GlouGlou » Sat Nov 09, 2019 9:52 pm
z still =0 because it's a 2D curve.
If you move a cube or any shape (placement), and change his parameter, it don't come back on origins.
What I have missed?
openBrain
Postby openBrain » Tue Nov 12, 2019 4:10 pm
Hi GlouGlou,
Don't have a very precise explanation ATM, but it solves the problem if I delete the 'onChanged' function (which seems useless as the 'execute' function is launched automatically as soon as a property --placement, radius, ...-- is changed). ;)
The weird thing is that when 'execute' is launched from your macro with the line :
self.execute(fp)
then the placement is reset by the line :
fp.Shape = curve.toShape()
In other cases (when 'execute' is self launched by FC), the latter line doesn't reset the placement. I can't explain why ATM... :?
DeepSOIC
Postby DeepSOIC » Tue Nov 12, 2019 4:22 pm
In execute(..), assign Placement attribute of the shape to fp.Placement before assigning the Shape property.
When FreeCAD recompute's your feature, it does that internally. However, from onChanged, it is not done implicitly, so you should do it explicitly.
openBrain
Postby openBrain » Tue Nov 12, 2019 4:28 pm
Well corroborate what happens, but not clear for me how to assign the placement.
ATM I can only see the (obviously useless) :
fp.Placement = fp.Placement
Edit : or do you mean something like :
currPlacement = fp.Placement
fp.Shape = ... # change shape here
fp.Placement = currPlacement #re-assign placement
DeepSOIC
Postby DeepSOIC » Tue Nov 12, 2019 4:36 pm
No.
This is how the end of your execute should look like:
      if fp.createFace == True:
         sh = Part.Face(Part.Wire(curve.toShape()))
      else:
         sh = curve.toShape()
      sh.Placement = fp.Placement
      fp.Shape = sh
DeepSOIC
Postby DeepSOIC » Tue Nov 12, 2019 4:38 pm
BTW, I wanted to find that piece of code in C++, but I can't. Probably, realthunder changed it. So I'm not sure about how it all works now.
openBrain
Postby openBrain » Tue Nov 12, 2019 6:06 pm
Thanks @DeepSOIC
GlouGlou
Postby GlouGlou » Tue Nov 12, 2019 7:39 pm
Thanks a lot.
next step: insert a icon inside the tree view.
