I'm in Part design-sketcher, from macro how to click the close button
freedman
Postby freedman » Tue Nov 12, 2019 4:25 am
While in part design-sketcher I want to add a close button to a macro, this would be the close button in sketcher-comboview-tasks. Is there a way to signal the close button is pressed?
Thanks
openBrain
Re: I'm in Part design-sketcher, from macro how to click the close button
Postby openBrain » Tue Nov 12, 2019 9:36 am
This is a bit vague without any context, but generally you can register a FilterEvent to an existing widget. ;)
DeepSOIC
Postby DeepSOIC » Tue Nov 12, 2019 11:18 am
Part-o-magic Leave command can do it. see https://github.com/DeepSOIC/Part-o-magi ... ter.py#L64
freedman
Postby freedman » Tue Nov 12, 2019 4:46 pm
DeepSOIC, thank you, that worked great.
I added this to set focus on the tree when returning to part design (in case anyone is looking) :
mw = FreeCADGui.getMainWindow()
dw= mw.findChildren(QtGui.QDockWidget)
for i in dw:
	if i.objectName() == "Combo View":
		tab = i.findChild(QtGui.QTabWidget)
		tab.setCurrentIndex(0)
Thanks all
openBrain
Postby openBrain » Tue Nov 12, 2019 6:03 pm
Thanks all
You can greatly simplify :
FreeCADGui.getMainWindow().findChild(QtGui.QDockWidget, "Combo View").findChild(QtGui.QTabWidget).setCurrentIndex(0)
freedman
Postby freedman » Wed Nov 13, 2019 1:12 am
@openBrain, thanks, I was thinking about that. I didn't have the findChild in my mental toolbox, got it now.
freedman
Postby freedman » Wed Nov 13, 2019 5:00 pm
@openBrain, I tried that line of code and it does not want to work. I researched the functions and I can't see why. It's no big deal cause I have code that works but there is something not right.
If I run from the console:
NameError: name 'QtGui' is not defined
I have this in my macro:
import FreeCAD
import FreeCADGui
import time
from pivy import coin
import FreeCAD as App, FreeCADGui
from PySide import QtGui,QtCore
openBrain
Postby openBrain » Wed Nov 13, 2019 6:14 pm
Before running the line in the console, you have to enter :
Honestly I didn't check the line and post it directly. :oops:
openBrain
Postby openBrain » Wed Nov 13, 2019 6:20 pm
The line correctly ends here (no error) but I don't see any effect... :?
Postby chrisb » Wed Nov 13, 2019 6:31 pm
Using the list of imports and executing this line I get no error and FreeCAD switches the tab in ComboView from Tasks to Model. The Sketch stays in edit mode in Sketcher.
