[SOLVED] Enumerating Property Types and Object Types before opening a Document?
Bayesian
Postby Bayesian » Tue Nov 12, 2019 8:42 am
Because I want to simplify my scripts and enable Autocompletion etc, I'd like to have an import module with all supported property and object types.
I know I can get the property Types from, for example a Body object with "body.supportedProperties()" and the supported object types from "document.supportedObjects()".
But that means I would have to create a document and/or an Object to enumerate those. Which works, but isn't exactly elegant.
Is there some kind of registry available?
DeepSOIC
Re: Enumerating Property Types and Object Types before opening a Document?
Postby DeepSOIC » Tue Nov 12, 2019 9:30 am
This information is not exposed. Exposing it might need quite some work.
Listing all attributes is easy. Listing all properties is more difficult. Listing supported objects for a body is doable, but in general it might be not.
Bayesian
Re: [SOLVED] Enumerating Property Types and Object Types before opening a Document?
Postby Bayesian » Tue Nov 12, 2019 9:40 am
Hm. So there are basically two options: prepare a list offline (which doesn't account for new or nonstandard workbenches) or use the create a document and an object method.
Site Admin
Postby wmayer » Tue Nov 12, 2019 1:49 pm
Yes, the central registry is the C++ class Type. At the moment we don't offer a way to access it from Python but it shouldn't be too difficult to implement a way.
Site Admin
Postby wmayer » Tue Nov 12, 2019 11:58 pm
git commit e1f85cd09
git commit d61bf15c4
t=App.Base.TypeId
t.getNumTypes()
p=t.fromName("App::DocumentObject")
p.Key
print(p)
p1=t.fromKey(97)
p1.Name
p.Name
p.isDerivedFrom("Base::BaseClass")
p.Module
pp=p.getParent()
pp.Name
pp.isBad()
b=t.getBadType()
b.Name
This can be done now with:
App.Base.TypeId.getAllDerivedFrom("App::Property")
App.Base.TypeId.getAllDerivedFrom("App::DocumentObject")
Bayesian
Postby Bayesian » Wed Nov 13, 2019 8:25 am
Thank you, I'm sure this will be useful!
DeepSOIC
Postby DeepSOIC » Wed Nov 13, 2019 9:29 am
t=App.Base.TypeId
t.getNumTypes()
p.Key
print(p)
Awesome!
