Widget addition with UI object not working
S.V. Honorio
Postby S.V. Honorio » Thu Nov 14, 2019 2:30 pm
Hello! I ve trying to add some interface add-ons to the software without success for the last days. I can make a window appear as a widget, but its empty and things only are added if I do it manually (which I don't want to, I want to use qt creator).
import sys
from PySide import QtGui ,QtCore, QtUiTools
app = QtGui.qApp
mw = FreeCADGui.getMainWindow()
path_to_ui = "C:\Program Files\FreeCAD 0.18\Mod\Beyond Cad\Layers.ui"
app = QtGui.qApp
myNewFreeCADWidget = QtGui.QDockWidget() # create a new dckwidget
FreeCADGui.PySideUic.loadUi(path_to_ui,myNewFreeCADWidget)
mw.addDockWidget(QtCore.Qt.RightDockWidgetArea,myNewFreeCADWidget) # add the widget to the main window
S.V. Honorio
Re: Widget addition with UI object not working
Postby S.V. Honorio » Fri Nov 15, 2019 4:24 pm
Do you recomend to compile a python code from the .ui format instead? I was trying to make the widget manually and stuff but oh boy. I don't get to work so many modules. Even copy-pasting from the documentation.
wandererfan
Postby wandererfan » Sat Nov 16, 2019 1:41 pm
I was hoping that a real python expert would pick this up, but FWIW...
in DraftGui.py, approx line 2440, this code displays a "Task Dialog" in the left hand panel.
        self.form = QtGui.QWidget()
        self.form.setObjectName("ShapeStringTaskPanel")
        self.form.setWindowTitle(translate("draft","ShapeString"))
        layout = QtGui.QVBoxLayout(self.form)
        uiFile = QtCore.QFile(u":/ui/TaskShapeString.ui")  #this has to change if ui not in Resource file
        loader = FreeCADGui.UiLoader()
        self.task = loader.load(uiFile)
        layout.addWidget(self.task)
This isn't quite what you want to do., but maybe it gives you a hint.
S.V. Honorio
Postby S.V. Honorio » Mon Nov 18, 2019 10:35 am
Thank you! I will give it a try.
S.V. Honorio
Postby S.V. Honorio » Mon Nov 18, 2019 11:37 am
Still not working. An empty widget appears on the size of the window.
import sys
app = QtGui.qApp
Layers = QtGui.QDockWidget()
Layers.setObjectName("ShapeStringTaskPanel")
#Layers.setWindowTitle(translate("draft","ShapeString"))
layout = QtGui.QVBoxLayout(Layers)
uiFile = QtCore.QFile("C:\Program Files\FreeCAD 0.18\Mod\Beyond Cad\Layers2.ui")  #this has to change if ui not in Resource file
layout.addWidget(loader.load(uiFile))
mw.addDockWidget(QtCore.Qt.RightDockWidgetArea,Layers)
