Set camera view to sketch center
freedman
Postby freedman » Fri Nov 15, 2019 4:52 pm
Anyone have some code for a macro that can set the sketch to center screen? I found this (below) to start off, it looks like the thought was to find the object bounds but I want to do a sketch, I have no idea how to use TypeId. I want to be able to run this while in Sketcher. Oh! The problem I'm try to correct is that sketcher will open at the current location, I want the screen to center on the sketch where ever it is located in the model space. Thanks
def find_centre():
    doc = app.activeDocument()
    if doc is None:
        return app.Vector(0, 0, 0)
    xmax = 0
    xmin = 0
    ymax = 0
    ymin = 0
    zmax = 0
    zmin = 0
    for obj in doc.Objects:
        try:
            if obj.TypeId[:4] == 'Mesh':
                box = obj.Mesh.BoundBox
            elif obj.TypeId[:6] == 'Points':
                box = obj.Points.BoundBox
            elif obj.TypeId[:4] == 'Part':
                box = obj.Shape.BoundBox
            else:
                continue
        except AttributeError:
            continue
        xmax = max(xmax, box.XMax)
        xmin = min(xmin, box.XMin)
        ymax = max(ymax, box.YMax)
        ymin = min(ymin, box.YMin)
        zmax = max(zmax, box.ZMax)
        zmin = min(zmin, box.ZMin)
    return app.Vector((xmax + xmin) / 2, (ymax + ymin) / 2, (zmax + zmin) / 2)
mario52
Re: Set camera view to sketch center
Postby mario52 » Sat Nov 16, 2019 12:18 pm
hi
How to apply Near and Far clipping from a script?
just modified for object selected (or not) (in sketcher also)
#https://www.forum.freecadweb.org/viewtopic.php?f=22&t=26391
#How to apply Near and Far clipping from a script?
#https://forum.freecadweb.org/viewtopic.php?f=22&t=40938
#Set camera view to sketch center
view=Gui.ActiveDocument.ActiveView
view.fitAll()
from pivy import coin
try:
    ##### for first Subobject selected
    sel = Gui.Selection.getSelectionEx()[0].SubObjects[0].BoundBox              # sub element BoundBox coordinates
    b=sel
    ##### for first subobject selected
    ##### for first Object selected
    #sel = FreeCADGui.Selection.getSelection()[0]
    #b=sel.Shape.BoundBox
    box=coin.SbBox3f()
    box.setBounds(b.XMin,b.YMin,b.ZMin,b.XMax,b.YMax,b.ZMax)
    cam=view.getCameraNode()
    cam.nearDistance.getValue()
    cam.farDistance.getValue() # far distance is quite high
    cam.focalDistance.getValue()
    cam.viewBoundingBox(box,1,1) # focuses on the cylinder
    cam.farDistance.getValue() # ... but far distance is still quite high and the cube is not clipped away
    viewer=view.getViewer()
    rm=viewer.getSoRenderManager()
    # this does the trick
    rm.setAutoClipping(coin.SoRenderManager.NO_AUTO_CLIPPING)
    # now the cube is clipped away
except Exception:
    print("Select one object")
EDIT 16/11/2019 15h55 modify the code for selection and focus to SubObjects[0] (first selection)
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
freedman
Postby freedman » Sat Nov 16, 2019 6:56 pm
I will start looking at that, thanks. I need to add to my description of what I want, I'm a little weak on placement wording.
Every sketch that's created has a sketch center and a sketch boundbox, those sketch centers are spread all over as the model is created. I want to focus the camera on the selected (currently opened in sketcher) sketch boundbox, not sketch center. Here is the tricky part, if it's a new sketch then sketch center is where you are currently but if it's an existing sketch then sketch center is probably somewhere else. I feel like Sketcher should know the difference , maybe that's a bug.
Thanks
mario52
Postby mario52 » Sat Nov 16, 2019 10:14 pm
hi
just explanation of operation of the macro, case hexagon :
here (actual) you select the edge5, the boundBox center of edge5 is centred on screen
    b=sel
here (uncoment for use it) you select the edge5 or other the boundBox center of the complete sketch is centred on screen
opened in sketcher or not
mario
freedman
Postby freedman » Sun Nov 17, 2019 7:45 am
I don't see that working. I made a test file that has a feature on each end of a bar. The way I test: Zoom in to the left feature sketch, now click to open the right feature sketch, the camera view should zoom to the other end of the bar to view the right sketch boundbox. What I see running your code: The camera view moves to model off center.
2_sketch_bar.FCStd
(20.75 KiB) Downloaded 4 times
mario52
Postby mario52 » Sun Nov 17, 2019 8:54 pm
hi
try this : select the sketch run the macro the sketch is edited and centred
#https://forum.freecadweb.org/viewtopic.php?t=24788
#Sketch enter Edit Mode by Python Script
try:
    view.fitAll()
    sel0 = Gui.Selection.getSelection()
#    Gui.Selection.addSelection(App.ActiveDocument.getObject(sel0[0].Name))
    b = sel0[0].Shape.BoundBox
    box=coin.SbBox3f()
    Gui.ActiveDocument.setEdit(Gui.Selection.getSelectionEx()[0].Object)    # Edit the Object
except Exception:
    print("Error")
mario
freedman
Postby freedman » Mon Nov 18, 2019 12:35 am
That works great! Thank you :D
Here is a small macro I use to test, I run your code as soon as we go into sketcher. You can see I connect to a workbench change and have your code running as I enter sketcher.
Thank you
import FreeCAD
import FreeCADGui
import time
import FreeCAD as App, FreeCADGui
from PySide import QtGui,QtCore
import FreeCAD as app
import FreeCADGui as gui
class VariableWatcher(QtGui.QDockWidget):
    def __init__(self):
        super(VariableWatcher, self).__init__()
        self.setParent(Gui.getMainWindow())
        self.setWindowFlags( QtCore.Qt.WindowStaysOnTopHint)
        self.setStyleSheet("margin:10px; border:10px solid; ")
        self.setWindowTitle("Test")
        self.setAttribute(QtCore.Qt.WA_DeleteOnClose, True)
        self.initUI()
        mw=Gui.getMainWindow()
        mw.workbenchActivated.connect(self.wbChange)
    def initUI(self):
       self.layout = QtGui.QVBoxLayout()
       self.setGeometry(100, 180, 60, 800)
       self.show()
    def wbChange(self):
        active = Gui.activeWorkbench().__class__.__name__
        if active == "SketcherWorkbench":
            try:
                view.fitAll()
                #sel0=Gui.Selection.addSelection(App.ActiveDocument.getObject(sel0[0].Name))
                box=coin.SbBox3f()
          #      Gui.ActiveDocument.setEdit(Gui.Selection.getSelectionEx()[0].Object)    # Edit the Object
            except Exception:
                print("Error")
    def closeEvent(self, event):
        self.close()
form = VariableWatcher()
I just want to say this is amazing, I can center on any sketch while in sketcher. Wow!
freedman
Postby freedman » Mon Nov 18, 2019 1:40 am
I have a small zooming issue on my big monitor but other than that it seems to work great. Thanks very much for your time mario.
I am cranking all this into my 2D3D macro to be posted soon. :)
freedman
Postby freedman » Mon Nov 18, 2019 4:49 am
I see what's going on. I run FreeCAD on dual monitors; one is the full graphic window and the other panels. Apparently coin thinks my graphic screen is both monitors so it centers things messed up. Pretty sure I can add some calcs to the setBounds and make things right. I will try to do a Right and Left version for the dual monitor folks. I will also look at Coin to check for a different call.
Mario, is there an easy way to switch the camera to the opposite side, many times the sketches are based on the other side and I can install a button to flip the view.
Thanks again.
mario52
Postby mario52 » Mon Dec 02, 2019 2:23 pm
hi
normally (0,0,-1) (and (0,0,1)) but no result
here little code to play with camera and collection snippets picked in forum and links for study
# -*- coding: utf-8 -*-
#from __future__ import unicode_literals
__title__   = "Titre"
__author__  = "Auteur"
__url__     = "http://www.freecadweb.org/index-fr.html"
__Wiki__    = "http://www.freecadweb.org/wiki/index.php?title="
__version__ = "00.00"
__date__    = "04/05/2019"
import PySide2
from PySide2 import QtGui ,QtCore, QtWidgets
from PySide2.QtGui import *
from PySide2.QtCore import *
global camera
Gui = FreeCADGui
App = FreeCAD
def errorDialog(msg):
    diag = QtWidgets.QMessageBox(QtWidgets.QMessageBox.Critical,u"Error Message",msg )
#    diag.setWindowModality(QtCore.Qt.ApplicationModal)            # la fonction a ete desactivee pour favoriser "WindowStaysOnTopHint"
    diag.setWindowFlags(PySide2.QtCore.Qt.WindowStaysOnTopHint)     # PySide2 # cette fonction met la fenetre en avant
    diag.exec_()
class Ui_MainWindow(object):
    def __init__(self ):
        self.window = MainWindow
        #self.path  = FreeCAD.ConfigGet("AppHomePath")
        #self.path  = FreeCAD.ConfigGet("UserAppData")
        #self.path  = "your path"
        param = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Macro")# macro path
        self.path = param.GetString("MacroPath","") + "/"                   # macro path
        self.path = self.path.replace("\\","/")
        #print("Path for the icons : " , self.path)
    def setupUi(self, MainWindow):
#        section horizontalSlider
        self.horizontalSlider = PySide2.QtWidgets.QSlider(MainWindow)                       # create horizontalSlider
        self.horizontalSlider.setGeometry(QtCore.QRect(10, 10, 400, 16))                    # coordinates position
        self.horizontalSlider.setOrientation(QtCore.Qt.Horizontal)                          # orientation Horizontal
#        self.horizontalSlider.setMinimum(-10000.0)                                         # minimum value
        self.horizontalSlider.setMaximum(100000.0)                                           # maximum value
#        self.horizontalSlider.setSingleStep(0.1)                                           #
#        self.horizontalSlider.setTickInterval(0.1)                                         #
        self.horizontalSlider.setInvertedAppearance(False)                                  # displacement rigth to left or left to rigth value "True" or "False"
        self.horizontalSlider.setObjectName("horizontalSlider")                             # object Name
        self.horizontalSlider.valueChanged.connect(self.on_horizontal_slider)               # connect on "def on_horizontal_slider:" for execute action
        MainWindow.setWindowTitle(QtWidgets.QApplication.translate("MainWindow", __title__+" ("+__version__+", "+__date__+")"))
        MainWindow.setWindowFlags(PySide2.QtCore.Qt.WindowStaysOnTopHint)        # PySide2 cette fonction met la fenetre en avant
#______________________________________________________________________________________
    def on_horizontal_slider(self, value):
        global camera
        value = value
#        value = -value
#        value = value/100#
#        value = -(value/1000)#
        print(value)
        #sel = Gui.Selection.getSelectionEx()[0].SubObjects[0].BoundBox.Center        # sub element BoundBox coordinates
        #print(sel)
        selb= sel.Shape.BoundBox.Center
        #print(selb)
#        #http://web.mit.edu/ivlib/www/iv/cameras.html
#        PerspectiveCamera. A PerspectiveCamera shows you the scene and applies foreshortening to give you a better impression of distance.
#        PerspectiveCamera {
#            viewportMapping  ADJUST_CAMERA
#            position         0 0 1
#            orientation      0 0 1  0
#            aspectRatio      1
#            nearDistance     1
#            farDistance      10
#            focalDistance    5
#            heightAngle      0.785398
#        Gui.activeDocument().activeView().setCamera(' OrthographicCamera { \n viewportMapping ADJUST_CAMERA \n position 0 0 1 \n orientation 0 0 1 0 \n aspectRatio 1 \n nearDistance 1 \n farDistance 100 \n focalDistance 5 \n height ' + str(value) + ' }')
        camera=Gui.ActiveDocument.ActiveView.getCameraNode()
#        print(camera)
#        focalDistance=camera.focalDistance.getValue()
#        Position      = 0, 0, 0   # XYZ
        Position      = selb[0], selb[1], selb[2]   # XYZ
        Orientation   = 0, 0, -1, 0
        AspectRatio   = 1
        NearDistance  = 1
        FarDistance   = 10
        FocalDistance = 5
        Height        = value
#        HeightAngle   = value
        #https://forum.freecadweb.org/viewtopic.php?f=22&t=10157
        camera.position.setValue(Position)
        camera.orientation.setValue(Orientation)
        camera.aspectRatio.setValue(AspectRatio)
        camera.nearDistance.setValue(NearDistance)
        camera.farDistance.setValue(FarDistance)
        camera.focalDistance.setValue(FocalDistance)
        camera.height.setValue(Height)
#        camera.heightAngle.setValue(HeightAngle)
#        print(position)
    def on_PB_Quit_clicked(self):
        self.window.hide()                                                  # hide the window and close the macro
        print("Quit ")
#print(Gui.activeDocument().activeView().getCamera())
doc = FreeCAD.ActiveDocument
if doc == None:
    doc = FreeCAD.newDocument()
MainWindow = QtWidgets.QWidget()    #PySide2
ui = Ui_MainWindow()
ui.setupUi(MainWindow)
MainWindow.show()
#https://forum.freecadweb.org/viewtopic.php?f=22&t=5576&start=10#p96188
#https://forum.freecadweb.org/viewtopic.php?t=26215#p207714
#how to change the distance of the camera?import Part
##http://web.mit.edu/ivlib/www/iv/cameras.html
##https://forum.freecadweb.org/viewtopic.php?f=22&t=6745
#            position         0 0 1
#            aspectRatio      1
#            nearDistance     1
#            farDistance      10
#            focalDistance    5
#    OrthographicCamera. A OrthographicCamera shows you the scene but doesn't apply any foreshortening.
#        OrthographicCamera {
#            position         0 0 1
#            aspectRatio      1
#            nearDistance     1
#            farDistance      10
#            focalDistance    5
#            height           2
#Gui.activeDocument().activeView().setCamera('#Inventor V2.1 ascii \n OrthographicCamera { \n viewportMapping ADJUST_CAMERA \n position 0 0 87 \n orientation 0 0 1 0 \n nearDistance 37 \n farDistance 137 \n aspectRatio 1 \n focalDistance 87 \n height 119 }')
##https://www.forum.freecadweb.org/viewtopic.php?f=22&t=26391
##How to apply Near and Far clipping from a script?
##https://forum.freecadweb.org/viewtopic.php?f=22&t=40938
##Set camera view to sketch center
##https://forum.freecadweb.org/viewtopic.php?t=24788
##Sketch enter Edit Mode by Python Script
#try:
#    view=Gui.ActiveDocument.ActiveView
#    view.fitAll()
#    from pivy import coin
#    sel0 = Gui.Selection.getSelection()
##    Gui.Selection.addSelection(App.ActiveDocument.getObject(sel0[0].Name))
#    b = sel0[0].Shape.BoundBox
#    box=coin.SbBox3f()
#    box.setBounds(b.XMin,b.YMin,b.ZMin,b.XMax,b.YMax,b.ZMax)
#    cam=view.getCameraNode()
#    cam.nearDistance.getValue()
#    cam.farDistance.getValue() # far distance is quite high
#    cam.focalDistance.getValue()
#    cam.viewBoundingBox(box,1,1) # focuses on the cylinder
#except Exception:
#    print("Error")
#from pivy import coin
#camera=Gui.activeDocument().activeView().getCameraNode()
#print(camera)
#camera.height.setValue(min(150, 150))
###https://forum.freecadweb.org/viewtopic.php?t=37841#p321922
##cam = Gui.ActiveDocument.ActiveView.getCamera() #store camera settings to 'cam'
##Gui.ActiveDocument.ActiveView.setCamera(cam) #restore previously stored camera settings
##https://forum.freecadweb.org/viewtopic.php?f=22&t=5576&start=10
##How can you zoom in and out of a document via scripting?
##https://forum.freecadweb.org/viewtopic.php?t=26215#p207714
##how to change the distance of the camera?import Part
#from FreeCAD import Base
#Gui.activeDocument().activeView().setCameraType("Perspective")
#camera = FreeCADGui.ActiveDocument.ActiveView.getCameraNode()
#center=coin.SbVec3f(0,0,0)
#orient=camera.orientation.getValue()
#viewdir=coin.SbVec3f(0,0,-1)
#viewdir=orient.multVec(viewdir)
#fd=100
#camera.focalDistance.setValue(fd)
##focalDistance=camera.focalDistance.getValue()
#position=center-viewdir*fd
#camera.position.setValue(position)
sorry
mario
