I had an workbench running on fc 0.17. Now i tryed to migrate it to 0.18 and python 3. I got it more or less started. The strange thin is, the Qt.Gui only opens up ones. If i close it and try to open it a second time it does not work. Has anyone an idea, what the issue could be?
thanks ikua
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
from PySide import QtGui, QtCore
from PySide2.QtGui import *
from PySide2.QtWidgets import *
import FreeCAD as App
import FreeCADGui as Gui
import numpy as np
#Gui = FreeCADGui
# UI Class definitions
DNarray = np.genfromtxt(App.__path__[0] + '\pipeExt\Resources\DN_Durchmesser.csv', delimiter=',', names=True)
RohrDef = np.genfromtxt(App.__path__[0] + '\pipeExt\Resources\Rohrdefinitionen.csv', delimiter=',', names=True,dtype=None)
GaebBereiche = np.genfromtxt(App.__path__[0] + '\pipeExt\Resources\GaebBereich.csv', delimiter=',', names=True,dtype=None)
#print(RohrDef.dtype.names)
#print(RohrDef)
# List all objects of the document
guiDoc = Gui.ActiveDocument
doc = App.ActiveDocument
sel = Gui.Selection.getSelection()
#loop through selection to search for pipes
iPipe=0
indexPipe = []
for o in sel:
#print o.Name
if "Pipe" in o.Name :
iPipe=iPipe+1
indexPipe.append(iPipe)
#if not FreeCADGui.Selection.getSelection() :
class ExampleModalGuiClass(QtGui.QDialog):
GaebExport = True
def __init__(self):
super(ExampleModalGuiClass, self).__init__()
self.initUI()
def initUI(self):
#here again (like above) for the update function
iPipe=0
indexPipe = []
for o in sel:
#print o.Name
iPipe=iPipe+1
self.result = userCancelled
# create our window
# define window xLoc,yLoc,xDim,yDim
self.setGeometry( 250, 250, 400, 220)
self.setWindowTitle("Rohrmanipulation H2Office")
self.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint)
# Rohrbezeichnung
self.label2 = QtGui.QLabel("Rohrbezeichung:", self)
self.label2.move(20, 20)
self.textInputBez = QtGui.QLineEdit(self)
self.textInputBez.setFixedWidth(150)
self.textInputBez.move(20, 35)
# Medium
self.label2 = QtGui.QLabel("Medium:", self)
self.label2.move(220, 20)
self.popupItems1 = [""]+RohrDef["Medium"].tolist()
self.popupMedium = QtGui.QComboBox(self)
self.popupMedium.addItems(self.popupItems1)
#self.popupMedium.setCurrentIndex(self.popupItems1.index("Faulgas"))
self.popupMedium.activated[str].connect(self.onpopupMedium)
self.popupMedium.move(220, 35)
# # DN
self.label2 = QtGui.QLabel("DN:", self)
self.label2.move(330, 20)
self.popupItems2 = [""]+[ '{:.0f}'.format(x) for x in DNarray["DN"]]
self.popupDN = QtGui.QComboBox(self)
self.popupDN.addItems(self.popupItems2)
self.popupDN.move(330, 35)
# # Material
self.label3 = QtGui.QLabel("Material:", self)
self.label3.move(20, 60)
self.popupItems3 = [""]+np.unique(RohrDef["Material"]).tolist()
self.popupMaterial = QtGui.QComboBox(self)
self.popupMaterial.addItems(self.popupItems3)
self.popupMaterial.move(20, 75)
# Gaeb Ja nein
self.checkboxGaeb = QtGui.QCheckBox("Gaebexport Rohrleitung", self)
self.checkboxGaeb.clicked.connect(self.oncheckboxGaeb)
self.checkboxGaeb.setTristate()
self.checkboxGaeb.setCheckState(QtCore.Qt.PartiallyChecked)
self.checkboxGaeb.move(20,100)
# Gaeb Bereich
self.label11 = QtGui.QLabel("Gaeb Bereich:", self)
self.label11.move(20, 120)
self.popupItemsGaeb = [""]+np.unique(GaebBereiche["Bereich"]).tolist()
self.popupGaeb = QtGui.QComboBox(self)
self.popupGaeb.addItems(self.popupItemsGaeb)
self.popupGaeb.move(20, 140)
# Gaeb Gruppe
self.label11 = QtGui.QLabel("Gaeb Gruppe:", self)
self.label11.move(220, 120)
self.textInputGaebGruppe = QtGui.QLineEdit(self)
self.textInputGaebGruppe.setFixedWidth(150)
self.textInputGaebGruppe.move(220, 140)
# cancel button
clearButton = QtGui.QPushButton('Clear input', self)
clearButton.clicked.connect(self.onClear)
clearButton.move(140,170)
# OK button
setButton = QtGui.QPushButton('Set Properties', self)
setButton.clicked.connect(self.onSet)
setButton.setAutoDefault(True)
setButton.move(20, 170)
# Pipe show Button
self.pipeShowButton = QtGui.QPushButton("Rohre ausblenden", self)
self.pipeShowButton.setCheckable(True)
self.pipeShowButton.clicked.connect(self.onpipeShow)
self.pipeShowButton.move(20, 195)
# Pipe lines show Button
self.pipeShowLineButton = QtGui.QPushButton("Rohrlinien ausblenden", self)
self.pipeShowLineButton.setCheckable(True)
self.pipeShowLineButton.clicked.connect(self.onpipeLineShow)
self.pipeShowLineButton.move(140, 195)
# update button
updateButton = QtGui.QPushButton('Get Properties', self)
updateButton.clicked.connect(self.onupdate)
updateButton.setAutoDefault(True)
updateButton.move(220, 170)
# update button
updateButton = QtGui.QPushButton('Set Selection', self)
updateButton.clicked.connect(self.onsetSel)
updateButton.move(300, 170)
self.show()
#Füllen der Felder wenn nur ein RohrDef
if iPipe==1 :
#get Name of Pipe, change to string from unicode, get only part without standard naming part
self.textInputBez.setText(sel[0].Label.split("_Rohr",1)[0])
if iPipe>=1 :
if hasattr(sel[0],"Medium"):
self.popupMedium.setCurrentIndex(self.popupMedium.findText(str(sel[0].Medium)))
if hasattr(sel[0],"Rohrmaterial"):
self.popupMaterial.setCurrentIndex(self.popupMaterial.findText(str(sel[0].Rohrmaterial)))
if hasattr(sel[0],"DN"):
self.popupDN.setCurrentIndex(self.popupDN.findText(str(sel[0].DN)))#
if hasattr(sel[0],"GaebBereich"):
self.popupGaeb.setCurrentIndex(self.popupDN.findText(str(sel[0].DN)))
if hasattr(sel[0],"GaebGruppe"):
self.textInputGaebGruppe.setText(sel[0].GaebGruppe)
if hasattr(sel[0],"GaebExport"):
self.checkboxGaeb.setChecked(sel[0].GaebExport)
#loopen durch auswahl, vergleich mit sel 0 wenn ungleich dann feld leeren
for o in sel[1:]:
if hasattr(o,"Medium") & hasattr(sel[0],"Medium"):
if o.Medium != sel[0].Medium:
self.popupMedium.setCurrentIndex(-1)
if hasattr(o,"Rohrmaterial") & hasattr(sel[0],"Rohrmaterial"):
if o.Rohrmaterial != sel[0].Rohrmaterial:
self.popupMaterial.setCurrentIndex(-1)
if hasattr(o,"DN") & hasattr(sel[0],"DN"):
if o.DN != sel[0].DN:
self.popupDN.setCurrentIndex(-1)
if hasattr(o,"GaebBereich") & hasattr(sel[0],"GaebBereich"):
if o.GaebBereich != sel[0].GaebBereich:
if hasattr(o,"GaebGruppe") & hasattr(sel[0],"GaebGruppe"):
if o.GaebGruppe != sel[0].GaebGruppe:
self.GaebGruppe.setText("")
if hasattr(o,"GaebExport") & hasattr(sel[0],"GaebExport"):
if o.GaebExport != sel[0].GaebExport:
self.GaebExport.setCheckState(QtCore.Qt.PartiallyChecked)
if self.popupMedium.currentText()=="" :
print ("leer")
def onpopupMedium(self, selectedText):
iii = str(RohrDef["Medium"].tolist().index(self.popupMedium.currentText()))
self.popupMaterial.setCurrentIndex(self.popupMaterial.findText(str(RohrDef["Material"][iii])))
def oncheckboxGaeb(self):
print(type(str(self.checkboxGaeb.checkState() )))
if self.checkboxGaeb.isChecked():
self.GaebExport = True
print("checkeD")
else :
self.GaebExport = False
print("uncheckeD")
def onClear(self):
self.textInputBez.setText("")
self.popupGaeb.setCurrentIndex(-1)
self.textInputGaebGruppe.setText("")
#self.result = userCancelled
#self.close()
def onSet(self):
print (indexPipe)
#Zuweisung der Bezeichnungen beginnt
Leitungsbezeichnung = form.textInputBez.text()
Medium = form.popupMedium.currentText()
DN = form.popupDN.currentText()
Rohrmaterial = form.popupMaterial.currentText()
GaebGruppe = form.textInputGaebGruppe.text()
GaebBereich = form.popupGaeb.currentText()
print ("Gaeb", GaebBereich)
iw=2
ir=0 # Laufvariable Rohr für Benennung
ia=2
#get the acutual selection
indexPipeSet = []
iPipeSet=0
for o in sel:
#print o.Name
iPipeSet=iPipeSet+1
indexPipeSet.append(iPipeSet)
#for obj in sel:
for item in indexPipeSet: #loop durch alle gewählten Pipeobjecte
print(item)
print (indexPipeSet)
obj=sel[item-1]
ir = ir+1
if not Leitungsbezeichnung =="" :
obj.Label = Leitungsbezeichnung + "_Rohr_" + str(ir)
if not Medium =="":
if not hasattr(obj,"Medium"):
obj.addProperty("App::PropertyString","Medium")
obj.Medium = Medium
R = float(RohrDef["R"][RohrDef["Medium"].tolist().index(Medium)])
G = float(RohrDef["G"][RohrDef["Medium"].tolist().index(Medium)])
B = float(RohrDef["B"][RohrDef["Medium"].tolist().index(Medium)])
print("color",R,G,B)
obj.ViewObject.ShapeColor = (R/255,G/255,B/255)
#dwire Line Anpassen
guiDoc.getObject(obj.Base.Name).LineColor = (R/255,G/255,B/255)
guiDoc.getObject(obj.Base.Name).DrawStyle = u"Dashdot"
guiDoc.getObject(obj.Base.Name).LineWidth = 4.000
if not Rohrmaterial =="":
if not hasattr(obj,"Rohrmaterial"):
obj.addProperty("App::PropertyString","Rohrmaterial")
obj.Rohrmaterial = Rohrmaterial
if not DN =="":
if not hasattr(obj,"DN"):
obj.addProperty("App::PropertyString","DN")
obj.DN = str(DN)
Aussendurchmesser = DNarray["Durchmesser_mm"][[ '{:.0f}'.format(x) for x in DNarray["DN"]].index(DN)]
obj.Diameter = Aussendurchmesser
obj.Base.FilletRadius = Aussendurchmesser * 1.5
if not GaebBereich =="":
if not hasattr(obj,"GaebBereich"):
obj.addProperty("App::PropertyString","GaebBereich")
obj.GaebBereich = GaebBereich
if not GaebGruppe =="":
if not hasattr(obj,"GaebGruppe"):
obj.addProperty("App::PropertyString","GaebGruppe")
obj.GaebGruppe = GaebGruppe
if not "PartiallyChecked" in str(form.checkboxGaeb.checkState() ): #wenn partially checked dann keine Veränderung
if not hasattr(obj,"GaebExport"):
obj.addProperty("App::PropertyBool","GaebExport")
obj.GaebExport = form.GaebExport
#print(str(form.checkbox.isChecked()))
#AB Hier scheinbar für Armaturen todo noch durchschauen
#ir +=2
#print("Name: " + Leitungsbezeichnung + "_Rohr_" + str(ir))
# object_A = obj
#print(object_A.Label)
# for obj in sel:
# object_B = obj
# common = object_A.Shape.common( object_B.Shape )
# if common.Volume > 0.0 and (str(object_A.Label) <> str(object_B.Label)) and "_Rohr_" not in str(object_B.Label) :
# print("Ueberschneidung "+ object_A.Label +" " + object_B.Label + " Nr " + str(ia))
#Nummer aus String entfernen und auch Leitungsbezeichnung um Anhauufung Leitunsart Name zu vermeiden
# object_B.Label = Leitungsbezeichnung + "_"+ filter(str.isalpha, str(str(object_B.Label).replace(Leitungsbezeichnung,'')) )+ "_" + str(ia)
#add property geht nur bei PythonFeature objects
#if form.checkboxGaeb.isChecked():
# print(str(object_B.label))
# object_B.addProperty("App::PropertyBool","GaebExport")
# object_B.GaebExport = True
obj.touch()
#for obj in FreeCAD.ActiveDocument.Objects:
#obj.touch()
def onupdate(self):
self.initUI()
def onsetSel(self):
#todo update selectin following properties from menue
def onpipeShow(self):
if self.pipeShowButton.isChecked():
for o in App.ActiveDocument.Objects :
print (o.Name)
obj = App.ActiveDocument.getObject(o.Name)
#print dir(obj)
#print o.Name
if not form.textInputBez.text():
Gui.ActiveDocument.getObject(o.Name).Visibility=False
elif form.textInputBez.text().lower() in o.Label.lower():
else:
Gui.ActiveDocument.getObject(o.Name).Visibility=True
def onpipeLineShow(self):
if self.pipeShowLineButton.isChecked():
print (o.Label)
obj = App.ActiveDocument.getObject(o.Base.Name)
Gui.ActiveDocument.getObject(o.Base.Name).Visibility=True
else:
print (o.Label)
Gui.ActiveDocument.getObject(o.Base.Name).Visibility=False
print ("text")
userCancelled = "Cancelled"
userOK = "OK"
form = ExampleModalGuiClass()
form.exec_()
if form.result==userCancelled:
pass # steps to handle user clicking Cancel
doc.recompute
